Question about Yamaha RX-V475
My fm radio does not seem to turn on. am works fine but no sound out of fm?
When i turned on my unit i mam not able to hear any FM stations. The AM stations seem to work but I have no sound coming out of the FM stations. Any idea what I need to do next?
techman
  • 3130 Answers
SOURCE: Not getting sound from right speaker
How do you have the audio hooked up from the TV set? If its s video or RCA plugs? If it is switch them around and see if it swaps channels that goes out . If it does then the output cable or the jack is bad. If your using an HDMI ir a scart cable. The cable or connections could be bad. Unplug it and reinsert it or while the units on mover it around and see if the audio comes back on.
Posted on Sep 22, 2006
easyq
  • 144 Answers
SOURCE: am/fm tuner is not working, there is no sound
Press teh AB speaker switch to see if it is working now, assuming you do have a station selected on your tuner.
Posted on Apr 17, 2009
smarthome2
  • 1114 Answers
SOURCE: Yamaha RX-V992 AM/FM stopped working & Right Speakers
Go to www.yamahausa.com then support then authorized serice centers. Hope this helps
Posted on Jul 06, 2009
  • 125 Answers
SOURCE: how to get am/fm stations to play. I have a hook
you can buy one online or you can make one out of audio, lamp, or antenna wire. cut about 10 ft of wire and split the wire about 1/4 to 1/3 of the way. that is to pull the two ends at one end of the wire in opposite directions. the wire looks like a T. the bottom of the T hooks to the receiver, the other end spreads out along the wall. the 2 ends at the rec. hook to fm and gnd or am and gnd. i hope i have made this clear.
reply if you need more help.
please rate bama46 and have a great day, thanks
Posted on Aug 23, 2009
smarthome2
  • 1114 Answers
SOURCE: Yamaha RX V 657 - No Sound Output, and No input detection
Bad DSP chip. The only other possibility is if you have the "Direct" on. On the front of the receiver it's a small button. Also make sure your "Speaker Select" A/B is "on" You will see it on the display, it's also a small button on the front of the receiver. If all this is correct and you still have no audio, it's a bad DSP chip. Not worth repair, it's 400-500 repair. Not very common in a Yamaha RX-V series, but I have seen it. I'm a Yamaha Dealer. If you need further help, post a comment and I will be glad to help you further.
2000 Silverado FM radio (only) no sound
You can try resetting the radio by removing power from it for a few minutes, reconnecting it and trying again. However, it sounds like an internal electronics problem that will either require a repair or replacement.
Jul 06, 2017 | 2000 Chevrolet Silverado 2500
No Sound
It seems to be that the antenna is at fault. If you can take it apart, you should resolder the antenna.
Nov 10, 2007 | Aiwa CR-LD120 AM/FM Radio
I get a picture but no sound. I bought the car with the dvd player already installed but no directions.
Hopefully you have a remote control for this unit. There is a FM select button. It's to turn on the FM modulator. When you press the button it will select different radio stations on the FM band. Once you select a station on the DVD, tune your vehicle radio station to the same and you will be able to hear the sound. Use this system to select the station with the best reception and less interference.
If no remote is available, there may be a FM button on the DVD player to perform the same function.
May 05, 2011 | Audiovox VOD102 Car DVD Player
I bought a '96 Mustang with an Alpine CHM 5620 CD player already installed. The unit appears in great shape and looks as if it were installed by a pro. It seems to load up the CD cartridge and change CDs...
This model of cd changer doesn't have the fm modual built into it. So I am wonder how this setup worked before. Most of these units had an FM tansmitter in them and you would just turn on your factory radio and set the fm tuner to a certain frequency like 89.5 or 91.3, not excatly sure on the right number, but somewhere low in the range. Turn on the stero and try tuning into differnet stations.
But like I said this model is desgined to be used with a aftermarket head unit with the proper wired connection going from the cd changer to the head unit.
Sep 21, 2010 | Alpine Car Audio & Video
What is the FM radio frequency to use the Hannah Montana Wireless Microphone?
FM 99.7 works best.... However if you have a local FM station using that freq your out of luck UNLESS your handy with a Jewelers screwdriver. Calling tech support will get you a "sorry" but there is nothing we can do. So if you are one of the unlucky ones with a Local 99.7 FM station here is what you can do.
1) Find a dead spot on the FM radio band either at the very low end or high end of the range. You should hear just fuzz (white noise) on your radio. However, on many newer FM tuners if there is no station broadcast there is nothing but silence.
2) Put batteries in the microphone.
3) Get a really really tiny flat head (Jewelers)screwdriver just like the kind in those eye glass kits they sell at the grocery store.
4) Sit right in front of the radio
5) Insert the screwdriver into the tiny hole in the microphone and tune the microphone until the radio goes quiet (no fuzz sound). Or.... you can keep pressing S to hear a beat and the beat is acutally heard through the speakers.
The hole is located just to the left of the screw that you undid to get at the battery compartment, but it's off center. Inside this hole is a small tuning screw. Slowly, slowly, SLOWLY turn the screw driver until you here a change or interruption in the fuzz sound on the radio speakers. This will indicate you found a compatible frequency. Then even slower - tune back to that "notch" until you hear nothing but silence on the radio. Test it by pressing the applause button "A" or by pressing the mic "M" button and talking.
There are multiple places on the FM dial that will "work" as you tune the little screw but you should have already manually selected where (the FM freq) you want to use your mic.
Once it's working it ain't perfect. I doubt you'd do a serious performance on it, but the kids love it.
The mic quality is not top notch for sure.
Fine tune as necessary....
Kelly
Mar 12, 2010 | Licensed Disney Hannah Montana Wireless...
No sound for Icon TV (DVD Player)
Try to look for a switch under the dash it should be a toggle switch , what happens is that the switch turns on the Fm modulater that transmitts the sound of the Dvd to the station. If that is not turn then you will hear the dvd player. If you turn the switch on then you will hear the radio become more static, that means that the Fm modulator is working
Jul 06, 2009 | Icon F701WL 7 in. Car Monitor
Radio reception
Say goodbye to this unit if FM matters to you
Mar 11, 2009 | Kenwood DPX-440
I have a 6 CD Changer but dont know how to use it?
This is an older way that makers of CD changers used to get CDs into cars that didn't have them.  This is what they tried to get people to by them.  I was never a fan of this system as the sound quality was never better than listening to FM radio.  There is a unit in the car, usually under the dash behind the glove box, that the CD changer is plugged into.  This unit has the FM antenna from the car plugged into it, and then a cable that is the same as that coming from the antenna going from the unit under the dash plugged into the FM antenna jack of the radio in the dash.  All this unit does is take the digital, high quality sound from the CDs, transmit it on an FM frequency (usually low on the FM band 80s, 90s or low 100s) and then you tune the radio into that FM frequency to get the sound form the CDs.  Problem is, the sound quality was only as good as FM radio.  A pretty poor way of getting CDs into cars.  But they sold millions of these things.  If it isn't working, the wiring may have come loose, the fuse to the unit under the dash might be blown, or something is disconnected.  if you go all through the FM dial, 0.1 at a time and don't hear it, it is time to get under the dash near the glove box and poke around.  Good luck.  If it were me, I would take all this gear out and put a new CD/MP3 player where the factory radio currently sits.
Jan 02, 2009 | Marantz ZS5300 6-Channel Amplifier
2007 Chrysler 300 , AM radio not working , but FM works fine
Usually when you lose only AM it is an antenna issue. Check for a loose antenna plug on the back of the radio or connection to the antenna.
Nov 15, 2008 | JBL - MR4W Am/Fm with CD Player White
Yamaha RX-V475 Logo
23 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
