Question about Maytag MZD2766GES Side by Side Refrigerator
Last week I had to empty ice box as it was overflowing
Now it is overflowing again and busting out the sides. Also the electric keeps tripping out, when I unplug Maytag everything is fine. As soon as I connect again this blows everything. Food in the fridge section has also started to freeze. Where can I find help? I live in London UK
  • Maytag Master
  • 4,655 Answers
The problem is serious and you will need a good local technician that is knowlegable with Maytag refrigerators, blown fuses is an indication that there is an electrical short circuit and the refrigerator must be serviced with hands on professional help, Thanks, Sea Breeze USA
Posted on Oct 27, 2007
106.57029 ice maker intermittent
there is usually an ice overflow switch or electric eye
sensor telling the ice maker that the bin is full. Something
may be obstructing this.
Nov 08, 2013 | Kenmore 57029 Side by Side Refrigerator
I have a ksra25ilss01 model side by side kitchenaid ref that will not stop making ice. It keeps overflowing the door tray.
The wire in the ice machine part is being heald down by ice I would guess, try and mess with it empty it all out of ice and let it start over again.
Jun 24, 2011 | KitchenAid KSRA25ILSS Side by Side...
Icemaker overflows water , repairman has replaced the icemaker twice, after this last time, it started making 1 tray of cubes per week, then after about 2 weeks, started overflowing water again.
Good day,
If it is erratic as you describe and replacing the ice maker twice has not resolved the issue it would make sense to replace the water valve in the back rear of the machine, if it hasn't been done so yet. It's the flakiest part of the system and has the highest failure rate. It's been known to fill too little, to much, and sometimes not at all.
May 26, 2010 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
Ice frozen over in ice maker, makes a clicking sound, the on off lever was obstructed and I think the tray did not empty the last cycle and more water flowed over the tray, how do I get it to empty?
Good day,
It won't empty itself, you have to remove the ice maker, and let it defrost and melt itself. Do not rush it. In fact leave it out overnight,
Re-install it, and check for performance. may take up to 6 hours for the first batch.
If it overflows, then the water valve in the back rear of the machine needs to be replaced. It's not opening and closing properly.
If the ice maker does not function, then it must be replaced, and it's smart to install a new valve at the same time.
Thank you for using FixYa
Jan 08, 2010 | Maytag MSD2454G Side by Side Refrigerator
Ice maker making little ice/Leaking water on floor.
The ice trays bust be cleaned to prevent calcium build up. This will prevent the ice from froming in trays.
The overflow could be caused by the freezer not being level, or by the water fill timer not shutting of the incoming water. This will keep the water temp. too high to freeze the water. Also check the fill valve for sepage.
Feb 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker broken
The ice maker likely needs replacing.
But ceck it to make sure its not hung up.
Does it have ice frozen in it or is it just turning arround.
Remove it and see if the heater underneath has a hold burnt in it.
Its just a plug in unit you can order one online.
Jan 13, 2009 | Freezers
10 yr old Frigidaire ice maker stopped making ice
try forcing the cycle by manually triggering the cycle a few times. Sometimes you can detach the trip arm or turn the tray by hand by disconnecting it from the gear. There may have been a switch bumped to turn it off or the switch somehow jammed. Maybe check for freeze-up. If there is water in it, it's going somewhere.
Sep 27, 2008 | Frigidaire FRS26R4A Side by Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
88 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
