Fbii xl4600 Keypad stopped responding to touch. Tried removing battery to reset, but it did not work.
  • 174 Answers
SOURCE: keypad malfunction
You need to try and calibrate the screen. Turn on the unit and keep your finger on the power button. After 30-40 seconds the calibration screen will come on, release the power button and follow the instruction of touching the while dot as it moves around the screen. Once thisw is done your touch screen should work.
Posted on Jun 05, 2008
  • 45 Answers
SOURCE: HTC Touch screen not responding!
This is a common problem with many touch screen phones. There are about three reasons this can happen that I know of:
1. Hardware issue. Needs to go in for repair. Hopefully under warranty still.
2. Needs to be re-flashed with the OEM ROM. This is not likely, since you've already Hard Reset, but worth a try.
3. The EASIEST and FIRST thing to check is to run a 'business card' around the edge of the screen between the case and screen. Dirt or other objects can easily get wedged into that area and hold the screen pressed down. This would prevent a press from any other area of the screen. Also, a screen protector that has shifted might cause this. Hopefully this is it, as it's a simple fix!
Posted on Aug 28, 2008
SOURCE: Touch screen do not respond
At times, Touch screen does not respond and phone cannot be unlocked by no means, Problem do not get solved even after restarting phone, removing battery & reinserting etc.. This happend typically during nights when the phone is not used and in the morning, touch screen does not respond to do any activities. after installing a software i had a hard reset, after that my tuch screen did not work.please help meeeeeeeeeeee ! !
Posted on Sep 03, 2008
SOURCE: My tytn ii touch screen is not responding
I have had the same problem but have finally got past the alignment screen by putting a new text document called welcome.not onto the memory card. At least the phone is working now, but the screen is not. HTC have sent me the phone back wanting £360 because they say it is water damaged even though it is less than 12 months old.
Posted on Mar 03, 2009
SOURCE: My Samsung Star GT-S5233W touch
phine lock solution
Posted on Feb 01, 2011
Sharp fx plus screen unresponsive
Sounds like the touch screen is dead, the crack most likely broke the touch screen sensor
Jan 20, 2014 | Sharp FX Plus
Error code 05 appeared on screen. We have tried to reset. Hit stop, enter, & quickstart buttons as decscribed. We also tried the reset button. The error code remains. We unplugged and tried again, but...
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Apr 11, 2011 | Precor 933 Premium Series Treadmill
Hello, My samsung tocco ultra touch screen is frozen. It wont respond. Also the call button and the return button(the centre one) dosent function. I tries almost all options like switching off-on,...
Hello.
It could be a software problem (but you can't connect by USB cable) or a hardware problem. Unfortunately without proper tools you can't fix either. You just have to take it to a Samsung service.
Regards, Achil
Mar 09, 2011 | Samsung Tocco Ultra Cell Phone
Touch screen not responding at all
The touch pad is dead...it's a hardware issue...go to the vendor or workshop...within a year it is replaced for free.Good luck.
Feb 02, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Keypad won't work
You should take the cover off and make sure the wires are properly connected. I had the same problem and that is what was causing it.
Dec 05, 2008 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Jul 30, 2008 | i-mate JAM Pocket PC
Touch Screen does not respond to anything.
HI,
Have you tried to reset the Phone to factory defaults. To do this you need to keep the left and right (-) pressed and with the stylus press the reset button on the left. This would take the phone to factory reset.
If the screen still does not work its time to get it serviced and repair centre. Most probably it would have to replaced.
Thanks
mandeep
Jun 03, 2008 | HTC P3300 Smartphone
Help
This time I took my memory card out and pulled the battery out and restarted it, and it fixed it... must have had something to do with the memory card... thanks for your response.
May 11, 2008 | HTC Touch P3450 Smartphone
could you explain in detail what s happening with your phone??
u said that ur phone cannot be unlocked...but then u say that it happens typically during nights...do u mind elaborating?
May 10, 2008 | HTC P3300 Smartphone
My keypad does not work on my razor
My phone (in a cotton phone bag) was very slightly damped by a spilled drink about 4 months ago. The keyboard immediately stopped working (only power button works). My friend told me to blow dry it, so I tried and it worked.
Just today, my keyboard stopped working again even though there was no further water damage (at least not to my knowledge), I used the blower dryer trick again. and it worked again. So ... you can give it a try.
Nov 02, 2007 | Motorola Mobility RAZR V3
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
