Question about Traulsen Refrigeration 48'' Wide x 24'' Deep Reach-In ''Ultra'' Wine Refrigerator With 2 Clear Blac...
Traulsen urs36dt center wall frezzes up - Traulsen Refrigeration 48'' Wide x 24'' Deep Reach-In ''Ultra'' Wine Refrigerator With 2 Clear Blac...
3 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: Traulsen URS36DT:
checking a def system is kind of easy. if you have located the defrost timer just turn the little knob on the timer until the unit shuts off, shortly you should hear "hissing and pooping" from water dropping on the heater. this lets you know that the defrost thermostat is good. if you dont hear this noise check your def thermostat and heater for continuity. if you put it into def and the heater comes on then you have a bad timer..
Posted on Dec 12, 2007
  • 10865 Answers
SOURCE: ice maker isn't making as much ice
Begin by turning the freezer temperature control dial to a colder setting and see if this solves your problem.
Posted on Aug 19, 2009
What does a feezer comp cost for a traulsen freezer model URS48DT
Fixya does not sell Traulsen freezer compartments.
May 04, 2018 | Traulsen Freezers
Traulsen freezer with intella true continuously frosting the evaporator coil and blocking the air flow?
Your defrost circuit ... should (about twice each day) gently warm up.. and remove the frost to an evaporation tray at the bottom of your FREEZER (refrigerator?)...
Regardless of the design...
THERE are only two reasons for excessive FROST.
- massive air intrusion (check seals & gaskets)
- defective defrost circuit (check defrost timer/controller)...
EZ trouble to fix...
Post comment reply: 7/3/2016...
In general... there are only three elements to the defrost circuit:
- 1st failure is usually the "timer" (in your case (other cases it is being replaced by the power control board (do remove power: line voltages present).
- 2nd failure (inside ... usually atop the evaporator) is the "DEFROST THERMOSTAT" (designed the keep the heating element from getting much hotter than 55 degrees Fahrenheit, ("failing" = open.. prevents the heater element from being energized at all).
- 3rd the heating element... itself goes open (usually below the evaporator (caution: line voltages on 2nd & 3rd)).
Anytime you don't feel you've got this surrounded just comment me back... I'll be around.
Go to Bing homepage
http://www.bing.com/search?q=traulsen+freezer+wiring+diagrams&qs=AS&pq=traulsen+freezer&sk=LS1AS5&sc=8-16&sp=7&cvid=47349AEC29CA4E1D8902F3954D86C0BF&FORM=QBRE&ghc=1
Jul 02, 2016 | Traulsen Freezers
Traulsen Ultra freezer quit and right wall is leaking water--why?
The fridge is twenty eight years old and not worth putting another dime into it. A fridge that old will just keep dimeing you to *****.
Mar 06, 2017 | Traulsen Refrigeration 48'' Wide x 24''...
Very loud compressor in traulsen freezer
It's probably a hermetic compressor. Nothing can be done. It's got an internal rattle, possibly defective valves, or freon was avercharged.
Aug 02, 2009 | Traulsen 7 cu. ft. / 198 liter Commercial...
Reference manufacture date
Hello Rob,
I called Traulsen with your model and serial # and was able to ID the manufacture date, Oct 4, 1989.
We specialize in cooler/freezer gaskets. We also sell refrigeration hardware & accessories. We can get many Traulsen OEM parts below list price. We'd be happy to help you locate the parts you need.
Shoot us an email to orders@coolergaskets.com or call toll free at 855-288-2259
Thanks,
Matt
Coolergaskets.com
Dec 19, 2008 | Traulsen Refrigerators
Electrical schematic
the only way to get diagrams is from Traulsen. They are not very forth comming with this info unless you call them with the model and serial number.
1-800-825-8220
May 15, 2008 | Traulsen Reach in Freezer - G12010
Traulsen URS36DT:
Dec 11, 2007 | Traulsen 7 cu. ft. / 198 liter Commercial...
Furniture Logo
Top Traulsen Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Traulsen Furniture Expert? Answer questions, earn points and help others
