Question about Samsung DMT800RHS Dishwasher
Reset button combination - Samsung DMT800RHS Dishwasher
How to change the 3 digit code of my samsonite ?
Luggage manufacturer Samsonite offers a variety of business, personal, travel products and accessories. Many Samsonite pieces such as attaches and other bags include a three-digit, built-in combination lock. When purchased, the locks are set on a factory default combination that you can change as often as you wish.
STEP 1
Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2
Locate the reset button, usually placed to the side of the combination dials.
STEP 3
Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4
Release the reset button after you set the numbers to the new combination.
STEP 5
Test the combination by turning the dials to the new code to open the lock. If the combination does not open the lock, repeat Steps 1 through 4 and test the lock again. If you still can't open the lock, contact Samsonite Customer Service at 800-765-2247.
Aug 28, 2016 | Luggage & Travel
Set combination lock
Step 1:
Step 2:
Step 3:
Try that :)
Jan 23, 2015 | Samsonite Leather Expandable Briefcase -...
What are the buton combonations for the factory reset on an android tablet
There are few combinations and you'll have to be quick to get the moment to press all 3 at once. Don't work every time as you have only a second or less to press the correct combination:
Each phone manufacturer has its own Recovery Mode key combinations.
You'll have to try each combination until you find the correct one for your Android phone or Tablet.
* Combination 1 - Volume Up + Camera button.
* Combination 2 - Volume Down + Power button.
* Combination 3 - Volume Up + Power button.
* Combination 4 - Volume Up + Home + Power button.
* Combination 5 - Volume Down + Volume Up + Power button.
* Combination 6 - Home + Camera button.
* Combination 7 - Home + Power button
Nov 29, 2017 | Tablets & eReaders
How do I reset a 4 dial Samsonite combination lock
Hello sstacy1,
You can follow the steps below to fix your problem on how to reset your 4 dial Samsonite combination lock:
  1. Set the dials to 0-0-0. Find the lever or button next to the dials.
  2. 2If your lock has a lever, lower it and turn the dials to the desired numbers. Return the lever to its starting position.
  3. 3For locks with a button, push the button towards the dials and turn them to the desired numbers. Release the button.
  4. 4The lock is now set to the new combination.
Read more: How to Reset Samsonite Luggage Combination Locks ' eHow.comhttp://www.ehow.com/how_4761466_reset-samsonite-luggage-combination-locks.html#ixzz157Q4Ap
Hopefully it helps.
Thank you for using fixya
Sep 08, 2011 | Health & Beauty
Resetting a kipling 3 digit lock
In order to set or re-set your Kipling lock, please follow these steps.
Step 1
Turn the dials to the preset combination and align the numbers to the Guide Line.
Step 2
Push the reset button with a pen (or other tools) all the way until complete turning the dials to your desired combination. (Do not let go of the button while setting the dials)
Step 3
Release the Reset Button after changing to your own combination. Your lock is now ready to open at its new combination
Jul 28, 2011 | Garden
I have Samsonite suitcase with the lock type B. When I used it last time, it was working. Now the code system doesn't work at all. I carefully followed the instruction to lock it but the code doesn't work,...
did you do this...
STEP 1 Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2 Locate the reset button, usually placed to the side of the combination dials.
STEP 3 Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4 Release the reset button after you set the numbers to the new combination.
STEP 5 Test the combination by turning the dials to the new code to open the lock.
if you did this then I'd contact Samsonite Customer Service at 800-765-2247.
Happy New Year
Jan 01, 2018 | Health & Beauty
How to set Samsonite combination lock
Step 1:
Step 2:
Step 3:
Try that :)
Sep 26, 2009 | Kwikset Locks & Locksmithing
We threw out the info that came with our new trek combination lock. now we have no idea how to open it or to reset it.
Try this....
My new lock didn't come with any instuctions. I followed the link above and located the "bike locks" heading. I found that the question:
- I have a Kryptonite resettable combination lock and can't find the instructions for resetting it. How can I change the combination?
contained a pdf titled :
- Resettable Combination Cable
(red reset buttons inside)
which is not the cryptoflex 1218 but is compatible anyway.
dont hurt your fingers trying to depress the nodules as the diagram says though. to my chagrin i discovered that they will turn easily if you just push them around into place.
here are the instructions:
To set your own combination
Your new lock is preset to open at 0-0-0-5 at the factory.
1. Open the lock by aligning the opening combination
number to the Guide Points and pull out the Lock
Post. (Figure 1)
2. Push down the two Reset Buttons simultaneously
with thumb and forefinger, and turn counterclockwise
until it comes to a stop. (Figure 2)
3.You are now ready to turn the dials to set your
secret combination, such as a phone number, birthday,
etc.
4. After setting your secret combination, turn the
two Reset Buttons again by Thumb and Forefinger
clockwise until it comes to a stop and back to its
original position.
5. Verify your new combination before using your
lock. Insert the Lock Post all the way into the Locking
Port but do not turn the dials. Pull out the Lock Post.
Your lock is ready to use.
6.The reset operation is now complete. Repeat
steps 1-5 anytime you wish to change your secret
combination.
Sep 16, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
Soft/hard reset combination keys doesnt work for nokia 6280
try this for soft reset
12345 is a standard code and 00000, but if you change it and you have forgotten your unlock code, you'll just have to reformat it
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot.
The trick is
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons...
reformatting your phone will delete all your data and also will restore all the defaults of your phone, and any corrupted application will be reinstalled, but if the formating doesn't work, you'll just have to re flash it, the safe way is to go to a near repair shop of your phone and have then to re flash your phone,
Mar 06, 2009 | Nokia 6280 Cellular Phone
I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
(see instructions above)
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Mar 05, 2008 | Master Lock 5400d: Portable Select Access...
Samsung DMT800RHS Dishwasher Logo
29 people viewed this question
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
