Question about LG LCRT2010ST Microwave Oven
Fuses Check fuses
Why my rationla keep blewing fuses every 7 months and over heating.
Maybe you didnt put acorrect fuse size so check it on its body or onthe nameplate
Sep 16, 2014 | Microwave Ovens
LG microwave oven does not heat up
Open it and check its fuses forcontuinity using amultimetter in ohms if there are fine check yo capacitor if its fine check yo magnetron check the magnetron with ameter it must give 0,2ohms if i5s fine but ithink its yo fuses
Sep 14, 2014 | Microwave Ovens
What internal fuses for goodmans st101ss microwave
the modern microwaves has 2 fuses lines fuse+thermal fuse. You must see the diagram or instr. manual section troubleshooting for indication for specification of fuses. Lines fuses has 240vac and 20amps. Thermal fuses you must see the instr. manual
Jan 24, 2013 | Whirlpool GH8155XM Microwave Oven
Neff b6774 turn microwave on but in switches off asfter 2 seconds heard it could be the fuse. how dfo i change it
You could have it checked by a professional technician, (the fuses are INSIDE the microwave), if you have electronic skills you can check them yourself but you need to open the oven to reach the fuses !!!REMEMBER TO ALWAYS UNPLUG THE POWER CABLE!!! before any attempt to open the oven, (to avoid all risk of electrocution) than look for ceramic german type fuses and check them with a multi-meeter, it could be a defective SAFETY SWITCH in the door latch as well... there are usually 3 switches or more, again you can verify the switches with a multi-meeter...
Jul 07, 2011 | Microwave Ovens
Help not cooking
Hi, fuses are common problem in ovens, try to check fuses including the ressetable thermal fuses.
Mar 07, 2011 | Emerson MW8991SB Microwave Oven
My frigidaire GLMV169 manufactured in 2005 and purchased in 2006 stopped working. There is no power. The clock, buttons - everything. Tried changing the outlet and flipping fuse switch and still...
Hello there:
If your microwave oven doesn't seem to work at all, check these: Fuses Door switch Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Nov 19, 2010 | Frigidaire GLMV169 Microwave Oven
Whirlpool microwave lost all power, circuit breaker is live
Sounds like your fuse has blown. Remove the unit if it is an undercounter unit. Unplug. Remove the case by taking all screws out. You should see the fuse in a holder on the top or on the side where the electronic boards and display are. Check the value and replace with a ceramic fuse OF THE SAME VALUE. The fuses are special fuses and are not glass fuses for a reason. They are ceramic (you can't see through them). You can get the fuses at www.mcmelectronics.com . Let me know if you need more help.
hardrocko
Thanks for using FixYa
Feb 24, 2010 | Microwave Ovens
Fuse location
Check for Manufacturer specific schematic
If you do not know what a schematic is, have proper tools, DVM and knowledge, please stop repair attempt.
Most microwave MAIN fuses I have seen are the BUSS type which are typically clipped into a fuse holder. Other BUSS fuses may be internal to the power supply or in a line fuse holder (Black Plastic)
Larry Hanson EH&S Specialist
Apr 04, 2009 | Panasonic Microwave Ovens
I have a goodmans microwave. a few weeks ago i opened the door and it blew the fuses. i have changed the fuse in the plug but still no power going to unit, please can u tell me if there is any fuses...
Firstly check the light.
As the light comes on when the door is opened - this could be the cause.
If that's ok, you could open it up to check the condition of the wiring, and that the door interlock is functioning.
As long as you don't damage anything, or remove the magnatron you should be fine.
I don't think there are any other fuses inside this model.
If it's anything else I would not attempt repair.
Double check that all is secure before using again - and turn off BEFORE opening the door each time.
Jun 11, 2008 | Microwave Ovens
LG LCRT2010ST Microwave Oven Logo
61 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Devabhakthuni...
Devabhakthuni...
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
