Question about Topaz Systems Computers & Internet
Topaz model T-W751-h109 wont download drivers
Can't download drivers to use signature pad
I have a odd grinding Noise only when I'm driving this 2 door 1994 Mercury Topaz Car
check the wheel bearings for failure
check the disc rotors fir failure on the inside from brake pads worn out
Nov 20, 2015 | 1994 Mercury Topaz
Signature pad model st me105 2 u100 is not detect with computer
When connected with a USB lead, your computer should recognize it and download a driver. Try a new cable.
Oct 19, 2015 | Computers & Internet
Ie shuting down after clicking done on the pad
try to update ur application,or uninstall it and download a new ie.
Sep 24, 2010 | Signature Topaz SignatureGem LCD 4x3...
My touchpad on my compaq laptop wont work how do i fix it
You probably need to re-install the driver for the touchpad. Go to the Compaq support site and download the driver for your computer.
The pad is something like an ALPS, but you can search for drivers based on your exact model.
Apr 10, 2010 | Compaq (153515-001) Touch Pad
My gateway scroll wont wor9
Scroll on mouse pad may not be a "default" factory setting. Go to Control Panel and access Mouse Settings and look for this feature and activate it.
If this does not work then go to Gateway Website and look for SOFTWARE AND DRIVER DOWNLOADS ., Select your model and Operating System and look for MOUSE. Select Moust Driver Download and RUN and reinstall driver.
If both do not work than your mouse pad has to be replaced due to physical issue
Aug 20, 2009 | Computers & Internet
Driver probs
what is the brand of your webcam...? try to download the driver, simply go to the brand's site and chose the model and download the driver.. then try to install it again...
Apr 24, 2009 | Computers & Internet
Signature pad writes straight line instead of signature
you can either try to unplug the pad for a minute. or uninstall the pad and then reinstall it again. and if that doesnt work then someone watered or damaged your pad some how.so you would have to buy a new
Dec 01, 2008 | Computers & Internet
SigLite 1x5 Model:T-S460-B (with serial connector)
The problem was not the topaz pad but my laptop. I removed all software which needs the serial port and I finished all not necessary programs which were running in the back but the problem was still alive. Now I asked my administrator for more rights and I changed the name of the port from port "1" to port "3" (port "2" doesn't work). I've got the message "port 3 is already in use" but the pc accepted the exchange of the name. Afterwards I changed the portnumber in the ini.file of the Topaz Software and now it works without any problems... strange, strange.... my five colleagues who are using the same pad on the same type of laptop (Compaq nc 6120) haven't got any problems during installation of the pad.
Thanks for your interest - kind: regards Ben Gun
Apr 06, 2008 | Topaz Systems TOPAZ SIG.CAP PAD SIG.LITE...
I INSTALLED MODEL T-S461-HSB TO MY WINDOWS XP AND IT STILL DON'T WRITE OR SHOW THE SIGNATURE THATS BEING WRITTEN DOWN. CAN YOU PLEASE TELL ME WHAT I'M DOING WRONG.
you download the software eapp for using the signature pads here is the minimum requirements of install eapp software
The eApp software was designed to function on both laptop and tablet PC computers.
Below are the hardware/software requirements for each configuration.
Note: eApp should run under Windows 2000, Windows XP Home and Media Center versions but Windows XP Professional (32 bit) and Windows Vista (32 bit) are the only 2 operating systems that the eApp help desk currently support. Use of an unsupported operating system can inhibit your ability to use eApp as it was intended and cause extra 3rd party support expenses.
Laptop -
Minimum Requirements:
1.2 GHz CPU or faster
512 MB Ram
20 GB Hard drive
Windows Vista
Recommended Requirements:
1.7 GHz CPU or faster
1 GB Ram
60 GB Hard drive
512MB USB Flash
Firewall and Virus protection software -
Any third-party protection software will do. Firewall and virus protection software should be running at all times to insure that your computer is not compromised and that customer information is not stolen. In the event of a system error you may be asked to provide the help desk with the results of a current virus scan to insure your machine is functioning properly. Failure to provide the scan results may result in a delay in resolving the problem.
Signature Capture Pad - Topaz SigLite Slim 1x5
Tablet PC -
512 MB Ram
20 GB Hard drive
Windows Vista
1.5 GHz CPU or faster
1 GB Ram
60 GB Hard drive
512MB USB Flash Drive
Tablet PC Signature Capture Software -
Topaz Tablet PC Software $100.00 USD
A signature capture pad is NOT required but special software is needed for the Tablet PC.
Mar 14, 2008 | Computers & Internet
Computers & Internet Logo
205 people viewed this question
Top Topaz Systems Computers & Internet Experts
David Payne
David Payne
Are you a Topaz Systems Computer and Internet Expert? Answer questions, earn points and help others
