Question about Cybex Cyclone 530c Upright Exercise Bike -- Remanufactured Refurbished-530c
530c feels like its slipping
Occasionally it feels as if its slipping
Check Engine Light P0740. Car stalls when starting (occasionally), and the transmission slips when stopped.
This code is set when the transmission control module detects improper voltage at the torque converter clutch. This can be caused by low tranny fluid/dirty tranny fluid/defective torque converter clutch solenoid/electrical connections to from solenoid
Nov 09, 2015 | 2001 Infiniti QX4
Feels like pedals slip once in a while. How do I repair this please?
replace the spring, maybe it has lost some of the loading and become "tired".
Jul 03, 2015 | Cybex Cyclone 530c Upright Exercise Bike...
Occasional bumping feeling in the steering column
I can think of one of two things:
Make sure your power steering fluid is full. My Bonneville was low, and it did some weird stuff.
But more likely it's your intermediate shaft. This shaft looks like a mini drive shaft with two miniture u-joints. It's located at the end of the steering column and passes thru the firwall. It's about 12 inches long. It has a slip spline that starts to not-slip, and you will feel a light thump in the steering wheel when turning. Sometimes thumps a little, sometimes alot.
There are several articles at the forum at: http://www.naioa.com/v2/modules.php?name=Forums
I decided to just pull my steering column on my 2002 Impala and lubricate the spline with regular grease.
Jan 02, 2011 | 2003 Chevrolet Impala
Going from Park or reverse to Drive occasionally
The trans probablely wasn't the problem.
Sounds more like solenoids or shift linkage issues
May 01, 2010 | 2003 Buick Rendezvous
Proform 840 belt feels bumpy when in motion. Treadmill is over 10 years old, but has not been used regularly over those years. I started to use again a few months ago for running and very occasionally...
I don't think it needs a part - I believe the walking belt just needs to be adjusted - if you don't know how to do this then give me a call and perhaps I can walk you through it - my name is Dewayne
Feb 03, 2010 | Exercise & Fitness
2003 Dodge 1500 transmission slips from overdrive
you may be feeling the torque convertor locking and unlocking....if you feel this on grade it may be normal. there is also the possibility that the brake switch may be acting up and causing it
Mar 17, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Dell 530c upgrade path
Yes,
if DELL have a launched new skims for upgradation in your systems, online,
so contact to administrator for your requirements & courier to therir production department they can do your best whcuih you want,
www.dell.com
THNX
May 18, 2008 | Computers & Internet
Cybex Cyclone 530c Upright Exercise Bike -- Remanufactured Refurbished-530c Logo
Top Cybex Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ray gallant
Electro Med Services...
Are you a Cybex Exercise and Fitnes Expert? Answer questions, earn points and help others
