Solution of error CA20 of 203L toshiba coppier
What does error code E000202 mean? Who to fix this problem?
wrong voltage to coppier.
error code E000202
seek help from manufacturer
Aug 18, 2013 | Office Equipment & Supplies
Toshiba 233
REVIEW THIS PAPER UNIT CORRECTLY
REVIEW PAPER RUBBER SUPPLY PRIMARY AND SECONDARY
Jul 30, 2013 | Toshiba TEC Office Equipment & Supplies
Infotech is 2127
"I want, I want, I want".....I bet you do!
First, learn how to ask for things nicely ....but repair manuals are NEVER part of the deal
Quit messaging me!
Nov 27, 2011 | Ricoh Office Equipment & Supplies
My coppier is not working with the colour documents .. its looks very dark and the image is not reconised ..
try to clean the mirrors inside
if still dark and it makes over 50000 paper you need to change the drum & developer & blade
Jun 15, 2011 | Toshiba 2860 Copier
Toshiba 2060 gives Misfeed error. The copier is not picking the paper up out of the tray. There is no jam. What's going on ? Is there an easy fix?
sounds like the paper feed rollers are worn or dirty try cleaning the rollers if the problem persists then unfortunately you will have to replace the rollers
Apr 06, 2011 | Toshiba 2060 Copier
Error is coming E000002
Error E000002
Press the the " additional functions" button, then the numbers 2 and 8 simaltaneously,and then the additional functions button.
This will bring a new screen with several icons. Press "Coppier".
This will bring several more icons to view. At the top of the screen press "Function" and then "Clear" at this point a new icon will display "ERR". Press it and then "OK"
This should make the coppier recover from its critical error.
Disconnect the machine from the power source for 30 Seconds and power it up. If the reeor returns it will within 5 Minutes or so. If it doesn't, it is now OK, until the next time that is.
Hope this helps.
Nov 11, 2010 | Computers & Internet
COPPIER DISPLAYING SYSTEM ERROR E007
error codad E007 First make sure fuser plastic not damage? Or not move the proper place? if damage fuser plastic Replace by new one if the fuser plastic move keep proper place.
Oct 12, 2009 | Office Equipment & Supplies
Mp460 canon printer-coppier broke down error code 5010 mascine still under guarantee
my printer-copier is not under guarantee and is coming up with error 5010 can i fix this problem or do i buy a new machine
Apr 08, 2008 | Office Equipment & Supplies
23 people viewed this question
k24674
jasbo
jasbo
