Question about Mitsubishi WD-Y57 57" Projection HDTV
Wd-65c9 orange light flashing and i replaced bulb still no picture
Replaced bulb and orange light still blinking
  • 179 Answers
SOURCE: Status Light flashing yellow after replacing the bulb
your air filter cover is loose or not on.
Posted on Dec 18, 2008
  • 75 Answers
SOURCE: I have a mitsubishi tv model wd-52525 and the
Probley should check the DM board for bad capastors. DM board is inside of a metal case should be on left side of tv when looking from rear capastors should be marked 16v 1000 uF on them should be 4 of them about 1 inch tall green or black or blue or brown maybe even yellow in color if bulage on top then then thay are bad if not still could be bad common problem need to check may or may not be your problem does couse the power light to blink non stop.
Posted on Oct 02, 2009
SOURCE: I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Posted on Feb 10, 2010
  • 68 Answers
SOURCE: wd-52725 had blue screen no picture or sound
you may be on the incorrect input channel. look for an input or tv video button and choose each input until u get a picture
Posted on Mar 03, 2010
ladywinn
  • 5138 Answers
SOURCE: Mitsubishi DLP Model number WD-62725;
Remove the Lamp and see if you have an ark coming from the spark gap on the ballast board,
if you dont then problem will be the Ballast Board Also is the Lamp trying to light?
Ballast Board is what powers Lamp on.Encompass Parts Distribution has Srvice Manual and
List of Parts/PN# Prices. 1-800-628-3328
Posted on Dec 04, 2010
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
https://www.youtube.com/watch?v=_ONPuB5L-x4
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
www.fixya.com/.../t26028385-after_replacing_bulb_wd_82738_still_no...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
www.tomsguide.com/.../id.../mitsubishi-82738-blinking-green-light.html
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Amazon.com: Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
Mitsubishi model wd=65c9 when turned on green light blinks repeatably sound comes on but no picture
The bulb that lights your picture is burned out. Buy a new warranted bulb from shopjimmy.com $85 with the housing. You can replace this yourself in 5 minutes. Shop jimmy has a video showing replacement. Remove 2 screws that hold the housing in place, slide the bulb out and slide the new bulb with housing in and replace the 2 screws. Plug in and enjoy your tv.
Feb 23, 2013 | Mitsubishi Televison & Video
Flashing orange light on mitsubishi 60737
The orange blinking light means a light bulb needs to be replaced. You should go to a Mitsubishi store and see if you can get one. Good luck
Take the old one with if you can get it out.
Aug 01, 2012 | Mitsubishi WD-60737 60 in. HDTV
My WD-65c9 boots to welcome screen then shuts down with a flashing red LED.
42 is an error code for faulty "Lamp Sirocco Fan" part no. 299P321010. You have to replaced it with new one. I've saw it at shopjimmy.com ( http://www.shopjimmy.com/mitsubishi-299p321010-fan.htm )
Dec 15, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
All I get is a blue welcome screen on my Mitsu WD-65C9 DLP TV. After several seconds of blue screen, it always just shuts down. I downloaded the Mitsubishi software upgrade, but it did NOT solve...
Hi Mike,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Kind Regards,
Mjsazon
Nov 25, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
Tv is getting dimmer
Brenda, Your projection bulb is about to die. Go on eBay, so a search for the bulb. Only buy a genuine Mitsubishi bulb to replace it. Or order one of these;http://www.shopjimmy.com/mitsubishi-wd-65c9 Get one of the "assemblies".
Removing and replacing the bulb unit is SUPER easy. Unplug the TV!! You unscrew the one screw on the litle door and the lower right, back side of the TV, then unscrew those two screws that hold in the unit, and slide it out. Slide in the replacement, and tighten everything up. Put the door back on, and plug it in.
Nov 25, 2011 | Mitsubishi WD-60C9 60" DLP HDTV
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
I HAVE A MITSUBISHI MODEL 65C9 THAT WHEN I PRESS POWER BUTTON AND GREEN LIGHT BLINKS STARTS TO LOAD UP AND THEN TURNS OFF WHAT IS THE PROBLEM?
You need to replace the main board, call Mitsubishi help line, they did not charge me a dime (If your TV is less than Yr old)
May 17, 2010 | Mitsubishi WD-65C9 65" DLP HDTV
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi WD-Y57 57" Projection HDTV Logo
16 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
