Question about Sony KDL52V5100 52 in. LCD HDTV
Our KDL52V5100 shows a pastel or other coloured barcode across the screen.
The 'barcode' effect is mainly when you turn the TV on although it happened once randomly when we were watching TV. Today it displayed the colours and we had to unplug the TV, wait 30 sec. then turn it on again. Picture is fine... for now.
  • 7 Answers
SOURCE: picture and sound cuts off ,greem stb light keeps blinking
How many blinks do you get? Depending on the amount of blinks you can figure out what the issue is.
If it blinks 6 times you can get the fix at
No power RED Standby LED flashes 6 times/KDF55XS955, KDF60XS955, KDFE55A20, KDFE60A20
They have other fixes for E60A20
http://www.agoraquest.com/viewtopic.php?topic=31806&forum=70&keyword2=electronics
Posted on Jun 12, 2008
VOTIT
  • 2071 Answers
SOURCE: tv prob
This is the common symptom of defected IC memory 24COxx,replaced this IC so it will works normal again.
Feel free to ask whatever the result...
Hope this may help you;
DON"T FORGET TO RATE:
Posted on Sep 04, 2008
SOURCE: Vertical colour lines on whole screen
The problem is that the panel has failed. Apparently this is a common problem with LCD TV's between 18 mths and 3 yrs old. If it survives over 3 yrs it is likely to last for a few years longer. The cost of replacing the panel is more than a replacement TV!
Posted on May 26, 2009
freelance-au
  • 131 Answers
SOURCE: I have to unplug and plug back in to get tv on
This will be down to bad capacitors in your power supply, Take the back of your tv look at the power supply and look for bulged capacitors ( domed shaped on top ) they may also be leaking a brown liquid substance, replace these and that should cure the fault.
Posted on Mar 05, 2010
  • 35 Answers
SOURCE: sony bravia kdl40s20l1 lcd goes into standby mode ocassionally
Check the U24 (CPU reset IC) on the "A" board. It may be burned. If you have a DVM (voltmeter) check for 3.3V across SW1 connections near this device. If you don't have 3.3V, U24 is bad. This part is not available from Sony. The TV may work if you just remove U24 from the board. I posted this fix on Agoraquest also, you can read more there (I'm "Roundabout" on that forum). Hope that helps
Posted on Apr 11, 2010
Vertical pastel colours error
Did u try to use different monitor and the via /Dvi cable it normally caused by this 2 if you still have the problem than its your graphics card it needs to check for loose connection.
Feb 17, 2014 | Acer (9005210464), (64 MB) Graphic Card
I have a Haier Hl32d1 32 in. TV. When I watch for a while the colour gets all messed up and become bright pastel colours like a lava lamp.
Hi Jesse, This is interesting. Please open the menu in "Lava like state"If the menu comes ok it is the main board causing this problem and if the menu does not appear properly, it may be due to bad display unit. Please consult some qualified technician.
Jan 08, 2014 | Haier HL32D1 32 in. TV
Faulty tv screen coloured lines and looks like a barcode
Check this site. It has screen-shots to faulty TVs. You can compare it to that of your TV's and can make sure about the fault. google.com/+GopakumarGopalan
Nov 20, 2013 | Samsung Televison & Video
I own a 5 year old 40" sony bravia lcd tv, When
This sounds like what I managed to do to my screen, even though I knew better. Is there any chance you layed the screen face down at some time?
Even though you can still watch it OK, you probably have hairline fractures in the screen face (NOT the screen itself- be thankful for that- the cracks are in the screen coating). LCD screens are a very thin glass laminate with a thin protective glass-like coating. When they are laid flat (like I did to connect cables) if the screen bears any weight, microcracks develop on the front of the screen.
I am sorry to say that the effect is permanent.
Feb 24, 2011 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Daughter sprayed water on samsung lcd 32 inch on the front panel
electric and water are a bad mix as you know my advice to you unplug tv put it in very warm room for about 3/4 days do not plug in hopefully it can be saved.adrian
Feb 15, 2009 | Samsung LTN468W 46 in. LCD Television
Intense white & coloured horizontal line on black background on startup
I wouldn't attempt as the capacitors on a tv store around 25000 volts this is more than enough to kill you and they keep there charge even when the tv is off. Either take it to a repair shop or put that money towards buying a new tv - Do not even attempt to open the tv. (It sounds like maybe a tube has gone or the electromagnet that makes the beam move vertically is gone.
Sep 03, 2008 | Televison & Video
Bush RFT TV
The picture tube of the tv has 3 color in CRT Red, Green, Blue. The red cathodeof tv set has no function, its either the resistor become higt resistance, that why u need a repairman to replace it.
Apr 10, 2008 | Televison & Video
Sony ke-p42m1
dunguard, How long have you had this for, zazwpx
Jun 04, 2007 | Sony KE-P42M1 42 in. Plasma Television
Sony KDL52V5100 52 in. LCD HDTV Logo
42 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
