Question about Sony Muteki RDH-GTK1i Mini Hi-Fi System - 220 W RMS - iPod Supported - 30 Channels - FM, AM - 2 Speakers - WMA, MP3, CD-DA - USB - Remote Control
Ipod dock not working
Ipod cradle
SOURCE: Ipod dock plugged it, switch to DMPORT no sound from speakers
I had the same problem. I tried everything and finally following two fixed the problem:
Dock insert has to be put before inserting Ipod in the dock. Dock insert usually comes with iPod when you buy it....After inserting the doc I was able to hear the sound but it was very faint. Then I updated the ipod's firmware. My Ipod classic was two years old. I updated the firmware by connecting it to the PC and opening itunes. Clicked on 'ipod' link and clicked to update button.
After the update, this ipod started working with my home theater system's DMPort.
HTH.
Posted on Jul 18, 2009
partyd
  • 141 Answers
SOURCE: TMR-BT8iP not working
this was made to work with any older genegarion ipod that works on firewire power not usb
most ipods
this is not fully compatible with the new iPhone,iTouch new nano and the ipod classic
Posted on Apr 01, 2010
SOURCE: My sony ICF-CS10iPBLK will charge
i've had this problem since i purchased the unit. i have to unplug from the wall and replug to make it work again.
Posted on Dec 26, 2010
  • 6 Answers
SOURCE: Sony ICF-CS10iP iphone/ ipod dock will not charge
connectors on the dock are probaly faulty return to sony to get repairedv (it will probaly cost) contact sony to arrange
Posted on Feb 25, 2011
  • 52 Answers
SOURCE: my ipod wont play through
Please check the iPod connector on the Sony. If you can wiggle it, it is probably a bad connection. These model Sony radios have the connector directly soldered on a PCB and it tends to get loose after a while due to connecting/disconnecting the iPod. If it is loose, the connector needs to be re-soldered back into place.
I have had the following circumstances when there was a bad connection:
- iPod will not be charged
- iPod can not play music through the Sony
- iPod will play music through the Sony, but an iPhone won't
Posted on Nov 08, 2011
Why Does my speaker make my ipod shuffle
You need to use the correct cradle that came with your JBL speakers.
The reason for your problem it's "vibration" from, it makes your Ipod vibrate off the cradle just enough to shuffle your music.Try it let me know
May 23, 2012 | JBL On Stage Micro II Speaker Dock for...
Tip
How To Connect Your iPhone, iPad, or iPod To The TV
The following devices have support for TV out:
  • iPhone
  • iPad
  • iPod touch
  • iPod nano (3rd generation and later)
  • iPod classic, iPod (5th generation), and iPod photo
Note: Other iPod models may support viewing of photos or slideshows on the iPod display but do not support TV out.
The following docks support TV out when used with an iPod model or iPhone that supports TV out:
  • Apple Universal Dock (requires either the Apple Composite AV Cable or the Apple Component AV Cable-will not work with the iPod AV Cable). Search the store for part number MB125G.
  • iPod Universal Dock or iPod with color display dock (iPod photo dock)
Important: The iPhone dock does not support TV out.
iPod models that support TV out can support viewing on a television in several ways. Use the tables below to see which cables and docks can be used with each iPod model. Check the documentation that came with the cable or iPod for information on how to connect and enable TV out.
Note: If you choose to use a third-party cable, make sure it has the "Works with iPhone" or "Made for iPod" label. Learn more about iPod and iPhone accessories.
All you need to get TV out is a compatible iPhone, iPad, or iPod and the correct cable. If your device works with the component and composite cables, then the choice depends on the TV(s) you will be connecting to.
  • Apple Composite AV Cable (part number MB129LL) will connect any iPhone, iPad, or iPod to your TV using RCA Cables.
  • Apple Component AV Cable (part number MB128LL) will connect any iPhone, iPad, or iPod (except iPod with color display (iPod photo), and iPod (5th generation)) to your TV using Component Cables.
A dock can be a welcome addition if you're going to keep your cables connected to the TV. The Apple Universal Dock includes an Apple Remote so you can pause and adjust the volume from a distance. The docks and cables are sold separately.
on Feb 21, 2011 | Apple iPhone Smartphone
How to connect Ipod touch to the system
Samsung offers the ability connect your iPod to the receiver with an iPod docking cradle (included). Your iPod effectively becomes another Samsung component flowing through the system.
That is from the samsung site and there should be a dock that came with the system that you would plug in and be able to hook up you ipod to the system.
The manual is located here http://www.samsung.com/us/support/downloads/HT-X710
May 04, 2011 | Samsung HT-X710T Theater System
I purchased a Denon I Dock ASD-11R and a Denon Receiver AVR 2311CI. The iDock says it is compatible with the Gen IV ITouch. The dock is compaible with a gen III ITouch - worked fine. I plugged in a Gen...
I too purchased the DenonASD11R Ipod dock to connect to my Denon AVR2311 Receiver, and I too experienced the same problem. I think it might be software compatiabilty issues between Ipod Gen 4, the Dock and Receiver. Some other Denon Ipod Docks are not compatiable with Ipod Touch 4. I returned my Dock and received full refund, and will be waiting for Denon to bring out another Ipod Dock which will work with Ipod Gen 4
Dec 31, 2010 | Denon iDock Docking Station for Apple...
When iPod placed in cradle of my onkyo dock (model DS-A2X), linked up with my onkyo CR-515DAB mini system, the display on the iPod comes up 'OK to disconnect', then the Onkyo logo appears. With this I can...
Hello, I am sorry about your issue. When you plug in the Apple charging cable into the IPod are there any issues. Make sure that there no foreign objects inside the connector on the dock. Thank you, Onkyo USA
Jun 16, 2017 | Onkyo iPod 4th Generation Dock - DSA2X
I have a Belkin TuneCommand AV. It was given to me a couple of years ago. I found it this morning, and do not have a clue how to use it, nor even what its function is. I leave for Mexico, South America and...
  • Your device is used in conjunction with an iPod music player. It is a base to charge it and if you have the remote you can play songs from across the roo.
  • Compatibility: iPod 3G, 4G, 5G, 6G; nano 1G, 2G, 3G; iPod touch; iPod mini
  • Lets you watch and listen to your iPod player through your home entertainment system, while simultaneously powering and charging it through the docking station
  • Includes a remote control that uses wireless radio frequency (RF) technology and works from up to 120 feet away, regardless of barriers such as walls, ceilings or windows
  • Basic functions include: play/pause, next/previous track, volume up/down, song shuffle, and repeat
  • Cradle that comes with this unit connects to your home entertainment system via an included A/V cable
he Belkin F8Z065 TuneCommand A/V Dock with Remote for iPods lets you watch and listen to your iPod player through your home entertainment system, while simultaneously powering and charging it through the docking station. The included wireless remote control allows you to roam freely as you play your tunes from virtually anywhere in your home.The remote control that comes with the F8Z065 A/V system uses wireless radio frequency (RF) technology and works from up to 120 feet away, regardless of barriers such as walls, ceilings or windows, making it perfect for distributed audio systems. The TuneCommand A/V's eight basic functions include: play/pause, next/previous track, volume up/down, song shuffle, and repeat. Used with your iPod video or photo, TuneCommand A/V even lets you watch your downloaded videos, or view your photos on your home television. The cradle that comes with this unit connects to your home entertainment system via an included A/V cable, and it docks, displays, powers, and charges your iPod all at once.
Compatible with any iPod with a dock connector--including the iPod nano 1G, iPod nano 2G, iPod mini, iPod 3G, iPod 4G (Click Wheel), iPod color, and iPod 5G/5.5G Video--via the included interchangeable trays, the F8Z065 comes in a white that perfectly complements your iPod, and it's backed by a manufacturer's 3-year warranty.
What's in the Box
Belkin F8Z065 TuneCommand station and remote, interchangeable iPod adapter trays, surface mounting hardware, user's guide and warranty information.
Product DescriptionTuneCommand lets you roam and play your tunes from virtually anywhere in your home, delivering the flexibility and convenience that iPod users desire. Using wireless radio frequency technology, the TuneCommand Remote works from up to 150 feet away, regardless of barriers such as walls, ceilings, or windows that limit traditional remotes. Connect your iPod to headphones, your home entertainment system, laptop, or computer-even if you stash it away in the glove box, control of your iPod remains at your fingertips.TuneCommand includes a multi-clip, surface-mount hook and lanyard, providing a variety of options for securing your Remote on the road, in the car, or at home. It features eight basic functions: play/pause, next track, previous track, volume up and down, shuffle songs, and repeat. When used with the iPod photo, TuneCommand lets you scroll through your slide shows or presentations-wirelessly.
Jun 22, 2010 | Audio Players & Recorders
White screen ok to disconnect
With the ipod plugged into the dock, I reset the Ipod (menu and center button till Apple logo appears). Ipod reset and problem solved. I'm listening to the music now!
Dec 16, 2009 | Sony TDM-IP1 Media Port iPod Cradle...
When I set my ipod on the digital media port the screen lights up white and says Digital Media Port okay to disconnect. It worked fine until now.
Had the same problem today. I turned the receiver off, plugged in the ipod, turned the receiver back on. The white screen came back on again. With the ipod plugged into the dock, I reset the Ipod (menu and center button till Apple logo appears). Ipod reset and problem solved. I'm listening to the music now!
Sep 29, 2009 | Sony TDM-IP1 Media Port iPod Cradle...
Remote wont work with the ipod
Make sure the ipod dock connector is clear of any debris both the on the dock and on the ipod. Use a can of air to clean these and try reconnecting it.
Try updating your software on your ipod. Plug it into itunes and update.
http://repair-scratched-ipods.blogspot.com
www.huskyipodrepair.com
Jul 26, 2009 | Dual Electronics ihome iH9BR iH9 Alarm...
Teac sr-l200i, the ipod dock just started malfunctioning in the last hour. When I dock the ipod there is barely any sound. This is the case for all my ipods on this unit. The ipods are working on all my...
I had the same problem but with a different TEAC docking product.
My TEAC would not recognize my ipod therefore I was unable to control my ipod via the docking station remote control.
Plug your ipod into the docking station and power down (reboot) your ipod. Once the ipod powers down (in the dock) restart the ipod (yes, while in the dock).
Mar 09, 2009 | Teac SR-L200i-W Docking Station for Apple...
Sony Muteki RDH-GTK1i Mini Hi-Fi System - 220 W RMS - iPod Supported - 30 Channels - FM, AM - 2 Speakers - WMA, MP3, CD-DA - USB - Remote Control Logo
74 people viewed this question
Top Sony Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Sony Furniture Expert? Answer questions, earn points and help others
