Question about Sony VAIO FRV26 Notebook
How can I get the cover off the Sony Vaio FRV26
Ok it seems that how to take the cover off this monster is a well gaurded secret or something, but I am really frustrated.
I have taken out all the screws and the front will seperate a bit but it is as if somewhere in the middle or back there are more screws "unseen to me" that are holding it together.
Can someone please tell me how to get the cover off.  My fan is making a noise as if hitting something and I need to check it out.  It's not the normal noise that this beast usually makes, and has nothing to do with it's overheat issues I solved that with an external cooling mat.
I would be so thankful for any help!
  • 83 Answers
Get a CAN O AIR and low the whole can through the fan inlet and outlet points its a $1.50 solution whatever it hitting will either be gone or moved outa tha way...VAIO's suck to tear apart
Posted on Oct 28, 2007
  • jknochelmann Aug 20, 2011
    surely this info will not be useful to the original poster, but i hope it helps someone. (i could have used a solid answer to this question earlier this week...)
    you can pop off the panel by the power button by inserting a small flathead screwdriver above the delete, F11, F5 and esc keys to release it. The panel is everything above the keys up to the screen. Once that is up, you will be able to unscrew the single screw holding the keyboard. Now the whole keyboard will flip down, and you can easily access the fans.
    My problem was a little worse... I had to take out the entire motherboard to reach the CMOS battery in an attempt to reset the BIOS. It was an epic fail, but if anyone is curious, the CMOS battery is in the front UNDER the motherboard, and you pretty much have to remove all but two screws from the entire laptop to get to it.
    Anyway, I hope this info is useful to someone.
2 Suggested Answers
SOURCE:
SOURCE: How do I get the cover off the Sony VAIO FRV26 PC Notebook
to open an FRV26:
the cover at the top of the keyboard must be removed, take a small screwdriver and run it along the lower edge of the cover behind the top row of keys. there will be 4 small slots across the edge. each of these slots has a small latch which must be pushed in to lift the cover.
once the top cover is removed, there will be a small phillips screw visible at the top of the keyboard, remove it and lift the keyboard out of the way.
under the keyboard is an aluminum shield. there are about 10 small phillips screws holding it down, most around the edges, 2 are down in small tubes. once all screws are removed, lift the cover. the fans will be visible.
WARNING: do not loosen the 4 screws around the fan cover housing. if you loosen these and lift the fans out, the main chip will come with them and must be removed from the heatsink to reinstall.
HTH
Posted on Jan 03, 2008
Moshi monsters havent gave me a secret code#
all you have 2 do is go 2 utube.com brodcasturself.and punch in (moshi monsters cheats).
Nov 25, 2012 | Moshi Monsters
Sony vaio pcg-grx550 problem
you may have hardware problems an may need to change something inside. if you have the manual check the part of beep codes
Feb 12, 2009 | Sony VAIO GRX550 Notebook
My Sony Viao will not start up
Easier to re-install windows,,,dont worry,,you wont lose any programs as long as you do a standard re-installation.
and NOT a fresh install.
Jan 16, 2009 | Sony VAIO FRV26 Notebook
Not rebooting
reinstall OS virus problem...
Jul 18, 2008 | Sony VAIO FRV26 Notebook
Sony FRV26
check all the cables and connectors..
May 02, 2008 | Computers & Internet
Laptop
it could be that
  • you got a virus that corrupted your hard disk or MBR (Master Boot Record)
  • your hard drive is dead
  • or your hard drive is corrupted
Try booting from a system disk (Windows XP CD, recovery CD or system floppy) and let me know what happens.
Nov 08, 2007 | Sony VAIO FRV26 Notebook
to open an FRV26:
HTH
Oct 26, 2007 | Sony VAIO FRV26 Notebook
Computers & Internet Logo
55 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
