Whirlpool sm8525079 rev
My whirlpool washer will agitate but will not drain or spin, and I hear a ticking sound in the control panel. Model number sm 8525079 rev a
    Master:
  • Washing Mach... Master
  • 676 Answers
I will help you provided a serial I need a model number check the tag on the washer not the book. Whirlpool authorized
Posted on Feb 13, 2014
  • 3 more comments
  • james hollis
    james hollis May 07, 2016
    My Whirlpool washer SM8525079 will not finish a cycle at all. Seems like the timing is ******* up? Do you have a direction to point me to.
    many Thanks,
    James
  • james hollis
    SM8525079 was the number on the washer
  • james hollis
    On the inside lid, I was not able to find any numbers on the back panel. Maybe I am looking in the right place?
  • james hollis
    james hollis May 14, 2016
    Found it....3955816
  • Melissa Martin
    Melissa Martin Jun 09, 2016
    This is your model LSQ9600LW0 The part you need is 3954071 that is a timer. The model number is located below the bottom of the lid when it is in the open position. You have to bend down and look below the lid
5 Suggested Answers
tomsat69
  • 214 Answers
SOURCE: Whirlpool LSN1000KTO Quiet Wash II (Agitate but nothing else.)
you have a faulty lid switch you will need to remove the cabnet and replace.To open you will need to remove the star screws off the rear consel corners and pull control panel up and over.If there is no screws you will need to use a puddy knife and push the front corners between the top and consel there are 2 clips ther as you push the knife lift at the same time on the consel.Then there are 2 brass clips stick a flat screw driver in and pry up they should pop off..Then remove the wire harness from lid switch.The lid switch will be under the cabnet or on the toprear left corner.to take the top lide switch remove the 5/16 screw and lift the lid then switch will come off.install new on if older the switch hase 2 srews around the inside lid area where the stricker pushes down then remove screw under the cabnet as well.hope i helpes is give me a fixya thank you so much :)
Posted on May 13, 2009
Maytag317
  • 1136 Answers
SOURCE: My Whirlpool washer won't spin
Hi, It sounds like the coupler has broken. If the motor runs but doesn't do either of these things, here is how to Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can set it aside.
How to replace a coupler:
Now that the cabinet is out of the way, remove the pump from the motor and set the pump off to the side. Remove the two screws holding the clips on the motor and remove the clips. Unplug the motor harness and on some models you wil need to unplug the capacitor.
Now you will need to replace all three parts to the coupler. I use a ½” socket and a small hammer to force the coupler onto the motor and transmission shafts. Put the rubber part onto the coupler half on the transmission and then line up the post on the motor shaft with the holes on the rubber part and it should go on ok. Put the clips that hold the motor in place and plug in the harnesses.
Put the pump back on and the clips to hold it in place. Set the cabinet back on the frame. Make sure the lip on the front cabinet is under the front rail of the frame. Ease the cabinet on the frame making sure the two rear sides of the cabinet set down on the tabs of the frame.
Put the two clips back on that hold the cabinet and plug the lid switch back in. Fasten the control panel down and you are all set.
Please let me know if this helps you or if I can assist you further.
Vic
Posted on Jul 13, 2009
jumptrout51
  • 3361 Answers
SOURCE: whirlpool model SM 8525079 fills with water but
If you have motor sounds after water fill,but no agitation or spin it could be a broken direct drive coupling. If it will not pump out water,there could be something stuck in the drain pump.
Posted on Jan 17, 2010
rockeye007
  • 45 Answers
SOURCE: My Whirlpool model sm8525079 will not spin. It will make a humming noise that I assume is the agitator but no real clue. It will drain though.
this is not a modle #,try raising the lid if a top loader and look low center under lid. if top load you may have a broken drive coupling.pretty easy fix once you get cabinet off.2 phillips up front on older on back on some,all at the very out side edge of control panel,some newer have end caps to remove for front screws.newer have spring clips.use putty knife between washer top and panel out side edge.two spring clips remove pump,two screws and clips remove motor,coupling is next.
Posted on Dec 10, 2013
Dec 10, 2013 | Washing Machines
Whirlpool sm8525079
check your belt also pulleys and motor
RCA Whirlpool Model LSQ9665J will fill with water but does not agitate, spin, or drain on any cycle. Was working fine yesterday.
put the timer on spin,open the lid,with a screw driver push down on the lid switch,if the washer starts to spin and drain the lid switch is bad,also if nothing happens,lift up and push down on the switch if you don't hear a clicking sound the switch is bad,all it is is a safety so the washer won't run with the lid open.part number 3949247 and the lid switch is around 40 dollars,
Apr 02, 2011 | Whirlpool Washing Machines
Washer will not spin, making loud ticking noise, it will fill up and drain, but won't agitate or spin!
if it's a kenmore or whirlpool you have a broken motor coupling,you have to send the model number and brand name so i can help you
Jan 30, 2011 | Washing Machines
Whirlpool model SM 8525079 fills with water but will not agitate or spin
Jan 17, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My Whirlpool washer, model number WTW5521SQ0 won't spin
This problem is frequent and is usually caused by the lid switch. It wont activate the spin for safety reasons, however it will drain. You should be able to hear the clicking of the switch while you open and close your lid. If you don't hear a clicking sound it is most likely faulty and will have to be replaced, part number for the lid switch is 8318084. If the switch is okay it will most likely be a transmission problem, and will have to be diagnosed by a technician. Check for any large oil leaks around the inside of the cabinet. If so this could be an early indication of a transmission problem Hope this helps
Thanks
Nov 03, 2009 | Whirlpool WTW5521S Top Load Washer
Washer will not spin or agitate. Pump works.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
First, see the following Whirlpool Kenmore installation and service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If it drains and you can hear the motor trying to turn the transmission for the agitate mode, the obvious first answer is the Motor coupler. I'd replace it just to be sure.
If it's not the Coupler, the problem points to the transmission itself.
There are only two components of the gearcase that are used for both agitating and spinning.
One is the Agitator shaft which drives the agitator and holds the spin pinion that drives the clutch for spinning.
The other is the main "Bottom and pinion gearcase" itself.
Please see the following Whirlpool parts list for commercial top load direct drive washers although the consumer models use the same transmission parts.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Oct 24, 2009 | Kenmore Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Washing Machines Logo
483 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
