Question about Pool & Spa
Looking for owners manual for Softub P-15 motor pack
I recently purchased a used softub model 220 and I believe it came with a P-15 motor pack, does anyone have an owners manual for this power pack? Thank you
efs_perpends
  • 1996 Answers
SOURCE: Need owner's manual for used Unisaw 36-812
You can download one from the Dewalt service center. Click on this link and choose the saw that most closely matches your own:
http://www.dewaltservicenet.com/Products/ProductManual.aspx?q=36-812
If you found this link to be helpful, please rate this response so I can become a trusted advisor. Enjoy your new saw!
Posted on Mar 24, 2009
  • 11 Answers
SOURCE: Missing Power Cord, Stand Base, Owner's Manual for Element 15" TV
The manfacturer has information for you about this model when purchased from Circuit City: http://www.elementelectronics.com/support2.html
The distributor Element uses provides parts at http://www.encompassparts.com/
(you may have to have a legitimate repair center login in and get parts from them)
Posted on Mar 30, 2009
  • 3 Answers
SOURCE: manual for Ridgid thickness planner model TP13002
Here is a link for a PDF file of the manual (in English) on your TP13002 Planner:
http://www.ridgidparts.com/pdf/TP13002.pdf
Hope this helps.
Posted on Apr 24, 2009
  • 47 Answers
SOURCE: I am looking for a owners manual for a Juki ddl 5500 machine
Www.ifixmachine.com has lots of manuals and parts for a cheaper price
Posted on Jul 24, 2009
SOURCE: jet model jwbs-14cs bandsaw purchased used, need manual
http://www.cpojettools.com/products/708115k.html
Scroll down and click the "Manuals" tab. Your free PDF awaits...
Posted on Aug 10, 2009
Awhy is a white grease forming & floating on top of the waterin my softub
thats either tanning oil or body oils get a scum removing ball usually floats or put in skimmer should remove it also clean your filters with a degeaser also to help it go away
Jan 12, 2014 | Pool & Spa
How to change softub liner
these places that do the one day instalation..watch them on tv comercials..
Jan 02, 2014 | Pool & Spa
Will the heatpump on the Softub turn on without water in the tub? I drained the tub for the summer and tried to test the pump and it tripped the GFI
That is a safety feature that you don,t burn out the pump,There has to be water going though the pump.You can not run them dry.
Oct 20, 2012 | Softube Valley People Dyna-Mite Dyna-Mite...
I want to convert my compressor from 115 V to 220volt? There is nothing in the owners manual on how to do this. Can you help me?
Your garage mate unit was made to operate on 120 volts. That one reason there is nothing in the owners manual. To convert it my be costly.First your electric motor must be able to handle 220 volts. you will need to look on the motor tag and see if it has 120v/230v. if not you will have to purchase a new motor that will handle 220/230 volts.If your motor will handle 220/230/volts you need to look at the the wiring diagram attached to the motor. you then will need to purchase a 220 v plug and outlet and correct wire size to install.
Jun 21, 2011 | Ingersoll Rand - Rand 2 - hp 24 - gallon...
Softub about 4 years old - I have a leaking water pump seal - does the impeller need a puller to remove it or can it be levered off ?
Thank you for posting your question here on Fixya.com.
Neither...it is threaded onto the motor shaft. Lock the shaft at the end opposite the impeller and turn it off counter clockwise.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Apr 13, 2010 | POLARIS SOFTUBE QUICK CONNECT - P-133
2 yr old softub Hot tub with connected GFI wire was emptied and cleaned out and filled; now the GFI trips when pluged in, and will not turn on!
Either the GFI is bad or it is tripping because there is a short in the system (obviously, right). I would turn off your panel break, disconnect the GFI and using a meter test to see if there is a short in the system. You would check the hot lead coming from the GFI to the tub and see if it is shorting. If you can't find a short, you should try replacing the GFI. If there is a short then you need to search for the short. Hope this helps and good luck!
Mar 14, 2010 | Leviton 8599 GFCI Receptacle
Looking for FREE owners manual for Halex electronic dartboard model number 64462-wal
Believe it or not I found the my original manual packed in a different box; I was actually looking for something else. Thank you
Jul 18, 2009 | Halex Toys
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
