Question about Mamas and Papas Skoot Pushchair
Broken harness need to buy new one ..Where??
    New Friend:
  • 37 Answers
Contact mamas and papas they may be able to help or you could try eBay. You can also get universal harnesses which might be worth a look at.
Posted on Feb 17, 2014
How do i fix power windows on 2001 chrysler sebring
if no door or window switches work in entire car start by checking FUSES , then by spraying compressed air into the switches on the drivers door panel whilst moving switches back and forth. then spray some WD40 or electronic componet cleaner into edges of switches whist moving switches hoping they come back to life. then pulling open drivers door rubber harness cover where it enters car. look for wires in the loom that are cracked and broken. this is likely.as wires bend each time door is opened. then remove drivers door panel and test then remove loom connector from door frame and use OHM /volt meter to find broken wires or switches in drivers door problems in drivers door. check for voltage at window motor first. . buy whole new door panel with wiring harness and switches at Pick n pull. if that does not work ..buy a haynes manual and look at wiring schematics. NEVER GIVE UP. NEVER BUY NEW PARTS.
Aug 31, 2014 | 2001 Chrysler Sebring
Wiring harness
your choices are replace harness (you can take one out of car in junk yard)or buy new.Or fix broken wires by sodering and shink wrap, or using but end conectors If this was helpful please leave me good feed back
Jun 28, 2013 | 1997 Chevrolet Cavalier
Recently, I changed the altenator of Toyota camry 2007 because the alternator is bad and the alternator harness connector was taped because it was broken already. The mechanics was trying to open the tape...
Costly, indeed. And dealerships don't like to fix broken things, they like to sell new parts. Guess you are stuck if you stay there. Do you know any good independent mechanics? One could probably repair it, or another alternative is a used engine harness, for less than half the cost of new.
Jan 16, 2013 | 2007 Toyota Camry
1993 ford taurus will not come out of park, brake lights won't come on even with new fuse
You likely have a broken wiring harness at the brake light switch connector under the dash above the brake pedal. You can buy a replacement stub harness from Ford parts.
Sep 13, 2012 | 1994 Ford Taurus
My magellan roadmate has a small ding on screen. I will not respond to touch on certain screens. Can it be taken appart for repair?
yes it can, but youll have to get the lcd with the digitizer, because the are soldered on the the lcd and very difficult to replace.
you can buy a good used, but broken 1200 off ebay for under 20.00 normally, because the 1200 has a problem with the usb port becoming damaged or broken and ask the seller if the screen is good
you can also by a new screen but its harly worth it, since yyou can buy a new 1200 for under 70.00
if you need further help, just reply to this post
bill
Jan 04, 2010 | Magellan Roadmate 1200 Car GPS Receiver
Broken wire in wire harness clip
i'm not sure what part is broken from your description but i will try to help...
you can purchase something called a reverse harness that looks identical to your vehicle's OEM harness that plugs into the factory radio. the only difference will be the wiring color on the new harness will be standard aftermarket wiring (ie 12volt yellow, ign red, ground black, etc.) and if you cut each wire from the OEM harness and solder it to the reverse harness location for location then the new harness will be good to go. i would personally do this as a single wire at a time so you are not staring at 16 cut wires going to the new harness. check at Best Buy and see if they carry the 71-1770 Metra wiring harness and that will be the one you need as the reverse harness and if you are installing an aftermarket radio get the 70-1770 also. if you aren't comfortable with all this your local installers should be able to do this job for you pretty reasonably.
Aug 18, 2009 | Pyle PLTDN71 Car Video Player
I have 2 power sliding door that are not working
there is harness at the bottom of the door traveling with the door every time you open or close in this harness is coverd with plastic rail for protection for the wire inside you will find one wire or two are broken you can fix that you need to find the broken wire or you can buy new door harness and installed should be 15-20min the same with the other door
Jul 15, 2009 | 2005 Dodge Grand Caravan
Fuel pump wires are frayed and wires are broken does a new fuel pump come with wires
NO but you can buy a new wire harness and i think it goes for around $15.00. It's common to replace the wire harness the same time you replace the fuel pump since they will have the same amount of corrosion. Good luck and hope this helps.
Jun 25, 2009 | 2005 Chrysler 300
Mamas and Papas Skoot Pushchair Logo
73 people viewed this question
Top Mamas and Papas Baby Gear Experts
Don Eagan
pamiejune
Level 1 Expert
Tom Chichester
Are you a Mamas and Papas Baby Gear Expert? Answer questions, earn points and help others
