Question about Radio Communications
Low outgoing transmission volume
Been advised my transmission volume is very low. need to turn it up
  • Radio Commun... Master
  • 1,654 Answers
Check to see your radio and the other radios are the same as to narrowband and wideband. A narrowband channel spacing radio will talk more softly to other radios which remain on the older wideband channel spacing. In the USA, all radios (with a few exceptions) were required to change to narrowband by Jan. 2013.
Another problem which commonly occurs comes from something (tape, sticker or debris) covering the mic hole on the transmitting radio. Look at the face of your radio and try to determine where the mic hole is, and then check it for obstructions.
Lastly, you can check the setting of your Mic Gain on radios equipped with this user programmable feature. Generally this setting offers the numbers 1, 2, or 3. Experiment to see which setting is best for your voice type.
Best regards.
Posted on Feb 11, 2014
HOW CAN I TURN UP THE VOLUME ON HANDSET. VOLUME IS SO LOW CALLERS CAN NO HEAR ME
There is no outgoing (microphone) volume control, if it is only your set try the handset from different extension. The microphone element may have been damaged (especially if dropped) and have to be replaced. Replacement handsets are not hard to find. If everyone on your system claims that callers cannot hear them, there are some settings on the central switch (KSU) which might help, but only after ruling out a problem on your particular set.
Jun 16, 2014 | Nortel Meridian M7208 Corded Phone
A180 just showing base and no response
Is the ringer turned off? Or is the volume on the ring tone set too low? Another possibility is that the phone isn't set to receive incoming calls - the Siemens phones I've owned allowed one to specify which handsets could handle incoming calls and outgoing calls on each line.
Jun 01, 2014 | Siemens Lands Phones
Volume low
While talking you can pull up and down the volume control button. It can raise or decrease the volume.
Car Tuning Chip
Aug 15, 2012 | Computers & Internet
GE Portable phone Model 2-9505 P/N 936772 Volume much to low. Need advise as how to increase the volume
I believe the ringer volume is low or at minimal or turned off, that's why the ring is very low. Try this; press the arrow (left and right or up and down button) on the phone constantly. This should increase the ring volume if actually it is low. Or, call the phone with another line, while the phone is ringing and press the arrow buttons without picking up the phone, this should increase the volume.
If the above doesn't solve the problem, please let me know so that I may direct you further.
Good luck.
Apr 05, 2011 | Cell Phones
While making incoming or outgoing calls the volume of the phone needs to be increased. Please advise.
It would help to know the model. It could be because the headset may have some dust clogging the speaker. Try using a condensed air canister from about 5 inches, and then see if volume level has improved.
Feb 11, 2011 | Cell Phones
Incomig calls are exremely low volume outgoing calls have normal volume. Is there an adjustment for this
hi
you can increase your sound by increasing the sound in profile settings.there you can find increasing sound for your ring tone.moreover you can set the ring tone that should have increased quality of your sound.then check the sound in call option.mostly samsung phones speakers have low sound quality
thank you
Dec 17, 2010 | Samsung SGH-A877 Impression Cell Phone
Can't hear my outgoing calls
While you're in the call, use the volume buttons on the right hand side of the Tour to turn up the volume.
If you still can't hear, you might want to try using the speakerphone -- it's louder. The speakerphone button is the same as the dollar sign ($) button, just press it during a call to activate the speakerphone.
If the volume button makes your outgoing call sound better, but then the next time you make a call the volume drops again, go into the phone's sound settings (Home folder > Options folder > Phone Options > General Options) and under Default Call Volume, change it to a higher number, or to Previous.
Jun 14, 2010 | RIM BlackBerry? Tour 9630 Smartphone
Volume to low, need to increase , please help.
install sigmatel audio driver and it will increase ur vol
May 20, 2009 | Computers & Internet
I have some doubts on alfatel mobile functions
increase the volume while you are talking on phone call. You can increase the volume by press silver FM button. To reduce the volume use silver MP3 button.
May 11, 2009 | Handmark Software MobileLists (950142) for...
How can I increase the volume of the radio
Check the grill in front of the speaker area for debris or plugged holes. Check the transmitting radio for debris blocking the mic hole. When turning volume up on the radio, do not max out the volume knob, back it off slightly for best sound. If these do not help, your radio is probably malfunctioning and needs replaced.
Jan 03, 2009 | Motorola Talkabout T5100 (14 Channels)...
Radio Communications Logo
54 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
