Question about Janome Sewist 500 Sewing Machine
Stitch width My machines stitch width is self adjusting while I am zigzagging. My stitch width will be on 3.5 and the stitch length on 2, but while sewing the stitch width will adjust to 5 on its own. Machine sent for repair 3 times. 3rd time stitch width part was replaced, but still having problems.
    Novelist:
  • 268 Answers
Could you be bumping it while sewing? Have someone watch while you sew. Otherwise, assuming this is a newish machine, I'd complain to Janome customer service and tell them it's been in for repair 3x and you'd like a replacement machine. You may need to be persistent, but I would definitely ask for that if I were in your shoes.
Posted on May 22, 2014
  • 3 Answers
SOURCE: Changing stitches
You probably have not adjusted you stitch width and length.
Also a manual for this machine is currently being sold on Ebay for $4+. Probably would be a good investment for you.
Posted on Mar 29, 2008
  • 323 Answers
SOURCE: Janome 1600P DB Stitch length
The machine is skipping stitches and is probably out of time. Change the needle, rethread the machine and try it again. If it still skips stitches, try lowering the needle by about 1/16 inch and see if it works better. If the timing is off you should take it to a technician for a complete service.
sewman7
Posted on Jul 15, 2008
SewTechWayne
  • 186 Answers
SOURCE: Zigzag won't enlarge
See if there is a twin needle lock out setting, if it is on it will cause this symptom. Otherwise there may be a bind in the needle pivot or linkage system to the needle bar from the cam or stepper motor (I don't know if this is a mechanical or electronic machine).
Posted on Feb 01, 2009
alicantecoli
  • 22219 Answers
SOURCE: I have a Memory Craft 8000. The computer screen
the mechanism is worn that makes the needle head move in a zig zag fashion ,need to be taken to a repair man to have the worn parts renewed
Posted on Oct 06, 2010
mvance01
SOURCE: my machine is missing stitches. on the zigzag
MY JANOME 4400 IS SKIPPING STITCHES, ITJUST STARTED DOING THIS, HELP!!!!
Posted on Sep 18, 2012
How can I change width of stitch
width has no way to be widened only length can be changed. try setting on zigzag and then to the max length on stitch.
Aug 02, 2017 | Sewing Machines
How i can adjust the stitch ?
A zigzag can be adjusted by the width and length of the stitch. If you start with a straight stitch it is easy to see what the length of the stitch will be. The width is adjustable. By adjusting the two together you can have a large choice of quality stitches.
Feb 07, 2015 | Sewing Machines
Directions for making a buttonhole with an Elna SU
A transcript from the Elna SU manual reads as follows, and the manual can be viewed on line at http://sewingonline.co.uk/instructions/elnasp/
First make a few trial runs with a scrap of material exactly as the buttonhole will be stitched, with the machine adjusted as you intend to use it.
1. Use the embroidery and buttonhole foot. It can be chnged without a screwdriver by using the fixation screw.- With the stitch width knob at "0", turn the selector to zigzag "1".
2. De-center the needle to the left.
3. Set the stitch width knob at 2, with the solid mark on top.
4. Set the stitch length dial between 1/2 and 1/4.
5. a) Mark the desired length on the material.
b) Sew the first side of the buttonhole. Stop with the needle in the material and the mark (right).
c) Raise the foot and pivot the material round the needle. Lower the foot and raise the needle.
6. a) Set the stitch width knob at 4.
b) Sew a few stitches. Raise the needle.
7. a) Set the stitch width knob at 2.
b) Sew the second side and stop just short of the length of the first. Raise the needle.
8. a) Set the stitch width knob at 4.
b) Finish off the buttonhole by sewing a few stitches. Raise the needle.
9. a) Set the stitch width knob at "0".
b) Sew a few stitches to fasten the threads, holding the material back by hand.
10. Open with the buttonhole knife, which you will find in the accessory box.
Oct 12, 2014 | Elna Sewing Machines
Straight stitch
Tension knob on any machine will be in the thread path and usually above the needle somewhere, while the stitch width and length knobs are usually on the right side of the machine. I cant identify your model but on any machine straight stitch is usually a length of 2.5 and width of 0, while a zigzag the width will be set somewhere between 2-4 depending on how wide you need it to be. There is usually a stitch selector of some sort too but many machines, providing the width is set to 0, you will get a straight stitch.
May 29, 2013 | Husqvarna Sewing Machines
My Elna SP suddenly stopped making the normal stitches regardless of whether I turn the stitch guide to "normal," "zigzag," or "overcast" mode.
Have you also turned the stitch width lever to 3 or 4 to form a swing needle type stitch?
Is this a Lotus SP or a Star Series SP? They should both have a stitch selector, a stitch width dial and a stitch length dial. Stitch width usually 3 or 4 and length usually at least 2 for a zig zag or overcast stitch. Also check the needle position dial, have you perhaps moved this off centre and not moved it back?
Mar 03, 2011 | Sewing Machines
Do not know how to set the machine for simple straight stitch.
I don't know your model but most machines have 2 common setting devices, namely a stitch width dial (how wide the needle swings) and a stitch length dial, how far apart the stitches are. So a normal straight stitch is "width" set to zero and "length" set to 2.5. If the machine has several different stitches then there may be a "stitch selector" too where you can choose the stitch style, ie zig-zag, 3 step zigzag, blind hem stitch etc.
You could try to locate a manual or threading diagram at various websites or visit sewing.about.com which gives good general information on threading and use.
Mar 01, 2011 | Singer 1725
I need to know how to make a button hole, can't find manual.
Hi there, don't know your machine but you can do a plaiin buttonhole manually.
Set machine up for zigzag stitch, needle to left side, mark out the size you need with pins or marker pen. Start at the top and set for widest zigzag with 0 length for the top bar, cannot give sizes as don't know the button you are using, about 6 stitches, set stitch width to just over half the width of top bar and length to approx 0.5. Stitch down to bottom marker and again set up ffor the wide bar, do the same amount of stitches as the top, finish with needle down at the outside edge, turn work so that you will now stitch down the other side to meet the top bar, not forgetting to adjust stitch length and width again.
Hope this helps
Ellie
Jan 09, 2011 | Necchi 3537 Mechanical Sewing Machine
Kenmore 2142 sewing machine won't zigzag.
Before you put the cam in did you make sure the machine was set on straight stitch and then select zig zag?
Nov 05, 2009 | Kenmore Sewing Machines
How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Mar 07, 2008 | White Sewing 1418 Mechanical Sewing...
Changing stitches on a White 1418 sewing machine...
I have a White 1418. Here's how you do it:
1. Attach the buttonhole presser foot (should have come with your machine) and place the fabric underneath.
2. Set the stitch length knob to 0, the zigzag width knob to 5, and set the needle position to center. Sew 3-5 stitches.
3.Change the stitch length to 0.5, the zigzag width to 2, and the needle position to left. Sew to the entire length of your buttonhole.
4.Set stitch length knob to 0, zigzag width knob to 5, and needle position to center and sew about 3-5 stitches
5. Set the stitch length knob to 0.5, zigzag width to 2, and set needle position to the right. Pressing the R button (reverse button), sew up to the top stitches.
6. Remove the fabric and open the button hole with a button hole cutter.
Sounds complicated, but it's really easy. I love this machine, you just have to know how to use it!
Sep 18, 2007 | White Sewing 1418 Mechanical Sewing...
Janome Sewist 500 Sewing Machine Logo
67 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
