Question about Vizio VX42L 42 in. LCD TV
Have cable with converter box for extra channels channels would not change pick up old remote control and hit a button now channels will change but have no picture says no signal
Does code need to be reset.blank screen no signal
    Master:
  • 966 Answers
On your remote control there is input button. Press that to the tv level.
There are other settings for box tops etc
Posted on Feb 11, 2014
SOURCE: Vizio L37
you probably changed the input mode.
Posted on Nov 10, 2007
  • 19 Answers
SOURCE: Vizio L37
try to go to the menu,then find the words,blue on or off,turn it off,then you will see the changers.
SOURCE: channel button on tv and remote control dosent work
Just press menu go to auto search
problem fixed and you'll have more digital channels as well
Posted on Mar 29, 2009
  • 3 Answers
SOURCE: Digital channel signal blue screen only
Press the "INPUT" button and make sure "TV" is highlighted.
Posted on May 18, 2009
RATTROD
  • 8 Answers
SOURCE: i have a 50 inch lg plasma tv and the picture is to big.
Ok take your Vizio remote control go to the Lower section of the buttons and look for the - Zoom + button than decrease the zoom.
Posted on Jun 22, 2009
Tivax STB-T9 DTV converter - remote control audio buttons no longer controlling TV audio
Maybe the remote got dropped by the cleaners. If you could control volume with the remote previously and now can't, I suspect the remote needs to be replaced.
Jan 26, 2014 | Televison & Video
I have a vcr/dvd combo. Can't record on it, was told that was because the cable here is digital. Is there some sort of adapter I can attach to enable my vcr to work again?
The only way to get your cable company's digital cable into the VCR is to provide a separate cable TV converter box for it.
This will be "an additional outlet" as far as the cable company is concerned - which means you'll pay extra for it. The other problem will be that you will have to locate the VCR cable converter away from the one used to send a program to the TV. This is because there is a very good chance that when you aim the remote to change the channel on the TV's cable converter - it will also try to change the VCR cable converter box.
If however, you have HD service on your TV you should not get an HD box for the VCR - unless there are stations that only exist on the HD converter box. This is because your VCR (like all the others in the world) are only capable of recording the old, analog "SD" or standard definition video signals. If you decide to go the route of an HD and an SD converter setup, you may not have a problem with one remote controlling both converters. Ask the installer (or test yourself) before setting it all up and merely assuming it will work as you expect.
If you end up with two identical converter boxes, you're going to need to either separate them so that the remote will not operate both at the same time. If this isn't doable, you might consider placing electrical tape or similar to block the remote signals from reaching the the VCR converter, and use the channel up / down controls on the converter box itself to tune instead. Since the VCR will only record what is sent to it - you'll have to make sure the converter box is not only on, but tuned to the correct channel before each time you want to record something. This brings up the last caveat, you'll need to set your VCR channel to match the output of the converter box (usually ch 3 or ch 4) and record only that channel. You could simply connect the converter audio and video output to the VCR's audio and video input instead. If you do this, make sure the VCR is programmed to record only the audio and video input ("A / V") instead of a channel.
This can sound a little complex - and it is to some people, but with a little work and some time, you'll be able to do this fairly easily. I wish there was an easier way to do this - but not yet with cable companies so far. The satellite providers are ahead on this with "multi-room viewing" service. Something to think about the next time your cable company announces a rate hike.
I hope this was helpful and good luck!
Sep 21, 2011 | Televison & Video
Im not sure how to hook the converter box up to it
For a digital to analog converter box, connect your antenna cable to the converter box. Then pick your output connection. Either set the TV to channel 3 or 4 and connect the coax out from the converter to the TV or connect the composite video (AV) to one of the A/V inputs on the TV (change the TV source to the appropriate input). The source is changed with the remote (TV/Video button).
If you have other devices like a VCR in the connection sequence, you could connect the converter box to the VCR (and record on channel 3 or 4) and then connect the VCR to the TV as above. You will be limited to recording and watching the same program unless you get another converter box or tuner.
Programming the remote will depend on the box. For other set top boxes, the connections will be very similar.
I hope this helps.
Feb 17, 2011 | Sony KV-32FS10 32" TV
I have an older Sanyo (approximately 8 years old) and my remote control is damaged (only the buttons/controls on the right side are working, volume turns up but not down, most of the left keys do nothing)....
If you are feeding the signal from your digital converter into the TV antenna input, I would input the converters signal to the TVs video input instead. I am assuming your converter has a video output signal and left & right audio so you will need cables for your audio also. If your converter has only rf output for the TV tuner input it is generally on either channel 3 or 4 and there may be a switch to set this. It is possible that when the TV scanned for channels the converter was off and it did not find a signal on 3 or 4. If you can get the TV to re-scan, be sure the converter is turned on and on an active channel. All your channel selection should be via the converter after that and the TV simply stays on 3 or 4. I would suggest looking in to getting the original remote. Try partstore.com and see if they have one for your model.
Nov 18, 2009 | Sanyo DS27930 27" TV
It wont pick any channels while scanning
There's several possibilities here:
1. You could have the cable plugged into the wrong port.
2. How old is the TV? If it isn't brand new, It's probably analog, and won't work if you're trying to pick up an antenna signal. For that, you'd have to buy a digital converter.
3. Do you have a cable box? If so, your TV should be set to one of the "Video" channels, not the numbered ones. Try hitting "TV/Video" on your remote until you see a picture. Make sure your cable box is on.
4. Everything else would pretty much boil down to poor signal, or broken equipment. Call your cable company if you have cable to determine if it's a signal issue.
Oct 29, 2009 | Televison & Video
I have installed a Digitalstream DTX9950 converter box with my TV attached to a rooftop antenna. I can turn the TV off and on with the DTX9950 remote, but I can't bring in any stations, other than the DT...
Are you using the coaxial cable to connect the converter box to the set, or have you hooked it up with rca type video cables? The latter are highly recommended if you want a better connection and have audio/video inputs on the back of your television. But you don't want both A/V & coaxial.
Also be aware that some older antennae will not pick up digital signals well. Try to use a coaxial cable all the way up to the antenna junction. Find out where most signals are broadcast from in your area and aim the antennae appropriately. (Use a compass.) See helpful link here. Your converter remote should have a signal strength button that you can use to check the various channel strengths. If you're using a coaxial link to the tv and have little signal strength, expect a poor picture. You'll also want to select the Mono option for Audio Output in the converter menu.
Finally, depending on the age of your set, if you're using rca video inputs, use the TV/Video button or the AV button on the TV or universal remote to switch the input from the channel on your TV to the video 1 setting (or whatever picks up the digital converter signal) so you'll get that clear signal. Then you can use the converter remote to change channels, adjust volume, etc.
Jun 14, 2009 | Philips Magnavox 20MT133S 20" TV
Magnavox, channel buttons cycle through sources
You need to reprogram your TV if you do not have a cable box or satellite box, otherwise those are going to be the only channels that the unit will pick up. If you do have a cable box or satellite box, just hit 0-3 or 0-4 if you are using a coaxial wire. If no box is present, you can just go into the menu and hit autoprogram - select cable for direct cable from wall, and antenna for antenna. Note: this particular TV is going to need a box in another 5 weeks due to the DTV transition, so my solution will only carry you for another few weeks.
-Tha Mp3 Doctor
Jan 11, 2009 | Philips Magnavox 20MS233S 20" TV
Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Nov 21, 2008 | Zenith DBZN-311 Remote Control
Thanks but i need more help
Don't be panic.
Check the batteries of your remotes control. FIRST
Be sure to aim the control to the sensor of your tv.
Usually you have one remote for your tv and the other to control the cable box or digital box.
You have to set the RMC10 again using the code of your tv Silvania (like the first time)
Then set your tv on channel 3
Another thing, be sure that you are hitting the right buttons.
The control doesn't work if you hit on the top any key instead of cable
What i mean?
The remote has on the top 4 key usually (tv, cable, vcr, aux, etc).
You must hit first cable to set the control to cable
1, Manually turn on the device(TV, VCR, etc.) to be controlled.
2. Press and hold the code search button until the red indicator stays on, then release the code search button.
3. Press and quickly release the desired mode button (TV, VCR, ect.). The red indicator blinks off once.
4. Press the Channel up button repeatedly(up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press channel down button to backtrack through the library until device changes channel. Pressing Channel up changes direction forward again.
5. Press and release Mute to install code.
Don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Let me know how it is going!
Oct 18, 2008 | Electronics - Others
Sat/cbl button defaults to channel 17
maybe you programmed it with the wrong code sometimes that happen try the other codes that come with it make sure everything works before you think u got the right one.
Jul 01, 2007 | RCA RCR450 Remote Control
Vizio VX42L 42 in. LCD TV Logo
53 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
