Question about Precor 905e 9.2 9.20 9.20s 9.1 9.2s Motor Hood Cover
Precor 9.20s speed up switch and incline down switch does not function but same button will chagge weight
  • 14 Answers
SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
Posted on Apr 29, 2009
maxtreadmill
  • 832 Answers
SOURCE: I have a precor 9.2S. the incline does not function.
Call Precor they should have a servicer in your area.
U.S. & Canada Only: T: 800-347-4404. Monday, Tuesday, and Wednesday 6 a.m. - 5 p.m. PST Thursday and Friday 6 a.m. - 3 p.m. PST Email: custsupp@precor.com
Posted on Jun 11, 2010
  • 1196 Answers
SOURCE: the speed arrow. when I
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
Step 4 Repeat the process if the display does not read "Calibration Successful.
Posted on Sep 24, 2011
ercupa190
  • 12223 Answers
SOURCE: Precor 9.27 Control Unit will not turn on. I have already tried replacing the fuse, but that did nothing. The red switch illuminates but the unit with the speed and incline control will not turn on. T
SEE THIS video: and fix it. Test the outlet wall with a desk lamp if turn On the outlet is o.k proceed.
God bless you
Posted on Oct 01, 2012
jrw5483
  • 8 Answers
SOURCE: precor 927 stuck in incline position
How long have you let it run for after turning it back on ? Some treadmills have a re calibration test built in and will incline to the max and work its way down. During this time you should simply walk away and not touch anything as it trys to calibrate its self. If not i will need more information on it
Posted on Oct 10, 2012
The incline on our Precor c964i is stuck in a high position (approx. 10% incline). Other than being on a high incline, the treadmill seems to be working fine.
Hi There,
Precor uses a pair of Triacs to drive the lift up and down. These triacs live on the lower board but are driven by the upper console commands via a serial link between the upper and lower. Most precor lift issues we see are related to the lower board but with Precor it could be an upper board or the CPU Chip that resides on the lower board or a failed Triac. Good Luck
Apr 07, 2017 | Precor Exercise & Fitness
Cuts off and speed is variable and shows err 4
Precor Error E4, Incomplete Initialization Probable Cause Indicates that an incomplete upper PCA to lower PCA initialization occurred. When this error occurs, all lift motor and drive motor motion is ceased and the display will go blank except for the error displayed.
Corrective Action Run the initialization program. Caution: The treadmill's running belt will accelerate to the treadmill's maximum speed (12mph). DO NOT stand on the treadmill's running belt during the procedure.
  1. Set the on/off switch to the OFF position. Wait a minimum of 10 seconds to allow the internal power supply to discharge.
  2. Remove the safety key from the console and set the on/off switch to the ON position.
  3. Press INCLINE UP and SPEED DOWN keys together. While pressing these keys, replace the safety switch on the console. Continue holding the INCLINE UP and SPEED DOWN keys until the display goes blank. INIT will appear in the time window of the display. The EEPROM is now clear and reset. After a second, 1.25 will appear in the distance/calories window, 15.0 (the maximum incline) will appear in the incline window, and 12.0 (the maximum speed) will flash in the speed/pace window.
  4. Press QUICKSTART to begin the speed calibration process. Power bits will appear in the incline window, the target speed will appear in the time window and the actual speed will appear in the speed/pace window. At the beginning of the process, the target speed will be .5mph. The running belt will start. Once the actual speed reaches .5mph, the target speed will then change to 12mph and the running belt will accelerate until it reaches 12mph, then it will stop.
  5. When the running belt stops, the display will return to the user mode and the initialization process is complete.
Precor Error Code E4
Feb 27, 2013 | Precor 9.1 Mode 1 Treadmill Repair Parts...
Precor 927 stuck in incline position
Oct 10, 2012 | Precor 927 Treadmill
Jun 10, 2010 | Precor 9.21 Treadmill
Treadmill Tunturi T 20 keeps inclining upward by itself
Testing Mode 1. Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then‘SPEED DOWN’ and hold buttons pressed simultaneously 2. LED scanning mode for verifying display functionality 3. Press ‘ENTER’ to scan DATA LINES to verify display functionality 4. Press ‘ENTER’ to scan SACN LINES to verify display functionality 5. Press ‘ENTER’ to scan LED’s to verify display functionality 6. After pressing ‘ENTER’ the TIME window shows “test” and the keypad functionality can be tested (the value displayed changes when a button is being pressed) 7. Press ‘ENTER’ to enter IO mode (TIME display shows lift motor potentiometer value, SPEED reads speed from speed sensor and DISTANCE shows heart rate pulse) Press ‘START’ to test lower board relay (a “click” sound) and then press ‘ELEVATION UP’ for 2 seconds to increase the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum percentage 0% Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ to decrease speed value. Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
May 10, 2010 | Tunturi T20 Folding Programmable Treadmill
Increase speed button on Precor 945i not work
The problem is that the keyboard is damaged, and although some function buttons is likely that the form of this cut keypad. you should replace it. I leave the link here to a place that sold parts for treadmills.http://www.fitnessrepairparts.com/index.php
Feb 03, 2010 | Exercise & Fitness
Elevation has gone too high. foot rollers are hitting front plate
Apr 30, 2009 | Precor EFX 546i Elliptical Version 4
Precor 905e 9.2 9.20 9.20s 9.1 9.2s Motor Hood Cover Logo
22 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
