Question about DeLonghi EAM3400 Espresso Machine
When I turn on the steam function a steady stream of water comes out fow a few seconds and then diminshes to a few drops when the pumps comes on every few seconds , but no steam comes out nozzle. I ha
The coffee part of the machine still works fine
  • 3 Answers
This is similar to my Saeco. i only drink black coffee so the steam function is very rarely used. When i went to use it recently got same as your description. this then set a 'blocked' code on computer which meant NO COFFEE! EEEKKK.
I used an old soft drink bottle as a resevoir to operate the machine with covers off so i could see an issues. I started at the filter , blew that out with compressed air. then hoses...do 1 at a time ...tank to filter, filter to pump, pump to heat exchanger, heat exchanger to spout (watch this one as it is steam!)
after a thorough strip and assemble i descaled and was good to go. now i make sure to use steam at least once a month.
Posted on Feb 12, 2014
Water light is on ,Water tank is full but the light stays on
If the water tank stays full it indicates that the pump cannot function properly.
Before first use, the Sirena pump needs to be 'primed'. This is indicated by the blinking blue 'water' LED. On a new machine (or a refurbished one as in my case), empty the water container first, then
  • remove the plastic water container
  • activate the small spring valve mechanism built into the bottom of the water tank.
    This plastic valve mechanism could initially be hard to depress, because the small metal spring is too strong, or the entire mechanism may be stuck altogether. Exercise this spring and the small valve a few times (ok: 10 times).
  • once the spring-loaded valve moves freely (it becomes easy to depress with your finger), the pump will have no problem activating the spring mechanism and starts sucking water out of the tank:
  • refill with filtered water almost to the top and observe the floating magnet (fill indicator) now in its UP position. You will have to refill the water after a few shots and using steam.
  • Press the ON/OFF button and open the steam knob clockwise all the way until you can hear the pump working and a steady stream of water escapes... onto the floor, or if you're smart, into a small container.
  • Once primed, the pump can operate and in turn, the machine starts heating up.
  • Now you can make your espresso, and even try the steam wand after it shoots out a short stream of water. Once you have steam coming out of the wand, you can start getting serious about making your brew...
I believe that a lot of problems, like failure to heat up, machine doesn't work, etc. are caused by this small spring mechanism being a little hard to operate initially. The Sirena is programmed to operate ONLY if it can extract water out of the tank.
Try it and enjoy the superb cappucino, espresso, etc. -the beautiful Sirena was born in Italy and is a little temperamental, but will be your best friend with a little help in the mechnical department (Think FIAT). By the way: I am a German engineer -no kidding.
Sep 08, 2011 | Saeco Starbucks Sirena Espresso Machine
My CVA620 machine asks to "expel air " but
keep holding the hot water button down until you get a steady stream of water with no air. if you continue to get the error message after the water comes out, you will need to check the flow meter. if water never comes out, you have a leak inside the machine, a pump issue, or a blockage in the water path. That machine uses the same pump for steam and hot water, so if your steam is working, your pump is probably good. Blockages usually occur from not descaling properly. That machine is prone to leak at the hose fittings. the original o rings were black rubber, and failed fairly early. the replacements are red silicone and last much longer.
Jun 12, 2011 | Miele Coffee System
Hi. When the 1-cup or 2-cup filter is in, and the machine is set to run, the water comes through the delivery spout in a steady stream for about 2 seconds and then sprays water (espresso) and steam...
i can try and help you get this figured out1st thing i would try is to start a shot without the portafilter in the machine. does water come through the screen, or is there literally steam coming through, or both. i have a feeling your either not putting enough coffee in the portafilter (basket) and/or the grind is not fine enough. it should take about 23-33 seconds to get a total of 1 1/2 oz of espresso. let me know if this helps, brian
Mar 14, 2011 | Gaggia Classic Espresso Machine
Silvia leaking water
Hi
The solenoid valve needs back flushing the correct way with a espresso machine detergent like Cafiza, or Joe Glo. Place a 1/2 teaspoon in a blind basket. (don't come with Silvia). Place blind basket in portafilter and brew like making espresso, but run pump for no more than 5 to 10 seconds or until the pump starts to change tone (slow down). Stop the pump when either of these things happen or Silvia can be damaged. Repeat the pump 5 to 10 times leaving a 1 minute wait between cycles, or the suds comming out the 3 way valve turns pure white, with no coffee stains in the foam. Remove the portafilter and rinse then reinsert and repeat the cycles to rinse the internals. This should take care of the problem. If not you may have to replace the 3 way.
Nov 12, 2009 | Rancilio Silvia Espresso Machine
Miele CVA615
miele's parts are available direct through them only
Sep 22, 2009 | Miele CVA615 Espresso Machine
Ventilate will not drop from menu ventilate...what to do..how to get rid og msg
Open hot water valve, for a few seconds, water will stream out and pump will engage to vent out water circuit.
May 30, 2009 | Gaggia Titanium Espresso Machine
Problem with steam wand on my espresso machine
Did you try to prime the wand by running water through it for 4 seconds? After you do that it should work fine.
Aug 28, 2007 | Saeco Classico Espresso Machine
Open Questions:
See all DeLonghi EAM3400 Espresso Machine Questions
DeLonghi EAM3400 Espresso Machine Logo
75 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
83bj60
Level 1 Expert
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
