Question about Toshiba e-Studio 350 Copier
2c69 failed to connect to smtp server
Hotmail pop and smp codes
  • POP server: pop3.live.com
  • POP server port: 995
  • POP SSL required? Yes
  • User name: Your Windows Live ID, for example yourname@hotmail.com
  • Password: The password you usually use to sign in to Hotmail or Windows Live
  • SMTP server: smtp.live.com
  • SMTP server port: 587
  • SMTP Authentication required? Yes (same as POP3 username and password)
  • SMTP TLS required? Yes
Aug 10, 2015 | Google Computers & Internet
Scan not going through . Log gives 2C69 message. What does it mean?
Failed to connect to SMTP server. Make sure that the SMTP server is correctly working, or the SMTP server address has been set correctly
Dec 08, 2014 | Toshiba Estudio 2330c Copier
IPhone 5S: I can text photos to other people, but I can't email them to myself. I use a yahoo email address. I get the message: A copy has been placed in your Outbox. The connections to the outgoing s
There is not an SMTP outgoing server called 'apple.smtp.mail.yahoo.com'. Try removing 'apple' from the beginning of the SMTP outgoing server name in Settings > Mail, Contacts, Calendars > Yahoo Email Address > Click on email address. If that does help, re-add your Yahoo email to your iPhone and test the account again.
Yahoo Email Settings: https://help.yahoo.com/kb/mobile-mail/imap-server-settings-sln4075.html
Oct 06, 2014 | Apple iPhone 5
Unable to send e-mails using windows mail
The connection to the server has failed. Account '<account name>', Server: '<SMTP server name>', Protocol: SMTP, Port: 25, Secure (SSL): No, Socket Error: 10051, Error Number: 0x800CCC0E
To resolve this behavior, change the SMTP server for your e-mail account to use the MSN SMTP server. To do this:
1.In Outlook Express, click Accounts on the Tools menu.
2.Click the Mail tab, select the account that you want to change, and then click the Properties button.
3.Click the Servers tab.
4.Under Server Information, delete the entry that is in the Outgoing mail (SMTP) box, and then type smtp.email.msn.com.
5.Under Outgoing Mail Server, click to select the My server requires authentication check box, and then click the Settings button.
6.Under Logon Information, click Log on using.
7.In the Account name box, type you MSN Member ID (everything before the at sign (@) of you MSN e-mail address).
8.In the Password box, type your MSN account password
9.Click to select the Log on using Secure PasswordAuthentication check box.
10.Click OK to close the Outgoing Mail Server dialog box.
11.Click OK to close the <Mail Account> Properties dialog box.
12.Click Close.
Mar 05, 2014 | Medion Computers & Internet
WorkCenter M118 it stop sending scan over email. Insted of sending it print the NDR with error E11202
Solution : Make Sure the SMTP (Mail) Server is an Open Relay Server or Uses POP-Before-SMTP Authentication The mail server being used must be an Open Relay server or use POP before SMTP authentication. If the mail server being used requires SMTP authentication, the scan to e-mail process will fail. The WorkCentre is unable to access the mail server when SMTP authentication is required. Contact your Internet Service Provider (ISP) or System Administrator for additional information.
NOTE: The WorkCentre was designed to send e-mail through internal corporate mail servers. In most cases, if using your Internet Service Provider (ISP) mail server, the scan to e-mail process will fail because most ISP mail servers require SMTP authentication to send mail. Contact your ISP for additional information.
Feb 24, 2011 | Xerox WorkCentre M118 Black and White...
We just got an MX-2300N and are trying to set it
I had the same issue the other day when installing one of these machines.
I find it alot easier to enter the details into the machine from it's web interface if you aren't already.. (Simply open your web browser and navigate to your copiers IP address).
If you ping the domain name of your mail smtp server and just get the servers i.p address and enter into the smtp box it should work. The particular one i used didnt need authentication either, give it a whirl and see how it goes.
Jul 15, 2009 | Sharp MX-2300N Color Copier
Toshiba e-Studio 350 Copier Logo
55 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
