Vizio L30WGU 30 in. HD-Ready LCD Television Logo
Victor Lambarena Posted on Feb 11, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Learn about tv
I just bought a 50" hdmi big screen from a friend and I want to know if I would be able to plug in my internet device and access youtube or any other internet sites?
Bestway
Level 3:
Master:
  • Master 966 Answers
  • Posted on Feb 11, 2014
Bestway
Master
Level 3:
Master:
Answers
966
Questions
13
Helped
188671
Points
2495
Yes if you have a pvr or another box top.
2answers
Set up OptiPlex 755 dell pc to my element big screen tv
how to, setup?
no screen stated. (real model numbers matter)what?
a wild example:
"Element Electronics" 50" TV = 1080p 60Hz LED HDTV Television Set: Model# ELEFW504
1 x Component Video, 1 x Composite Video, 1 x Digital Audio, 3 x HDMI, 1 x Headphone, 1 x RCA Audio L+R, 1 x RF (Coaxial), 1 x VGA, and 3 HDMI ports
-------------------------------------4 classes of video supported----------
755 comes in 4 case options, see link below last.
no options in the 755 stated, that you want to use.
HDMI is best ... for most folks,
That is mini desktop, PC and as such can have vast numbers of
option cards fitted inside for VGA/DVI or HDMI.
no cables stated. HDMI , got those?
no OS you run in the 755 stated.
No photos PC rear nor what cards fitted there..
is this an HDMI question, how to connect HDMI.?
did you even try first? plug it and and pray?
see this photo? DELL. actual.
the top blue jack is VGA, if that is all you have
then buy VGA to HDMI adapter cable device.
or add new hdmi video card in the bottom slots.
answering for HDMI only here,there are 3 other ways to get video to TV screen (per its manual)
This PC comes in slim models is yours SLIM?
Mini Tower Computer (MT)
Desktop Computer (DT)
Small Form Factor Computer (SFF)
Ultra Small Form Factor Computer (USFF)
755r-fgfu1yqclolqjzlaezm34mry-1-0.jpg The best way is HDMI card added to above.
here I will do slim + HDMI for you.
cards come in different heights, that must match and fit.
https://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007709%20601107673%20600038363&IsNodeId=1&bop=And&Order=PRICE&PageSize=36
what case matters if you put in a new video card here for HDMI
we have no clue as to what 755 PC you own.
Why cant the hdmi cable work on my vivo tv ?
You need to change the input on your tv to match where you are plugged into. Ex....if you are plugging your device into HDMI input two on your tv then you need to change the input with your remote to HDMI input 2
1helpful
Suddenly lost Laptop to Mitsubishi 60c9 connection using HDMI
never plug in hdmi when comp.is on you may burn your hdmi port
I am able to stream netflix, however, I was told I should be able to access everything else from my PC on the TV, as well. Therefore use my TV as a laptop. How do I do that??
If your Television has netflix installed on it, you will need to connect the television to the internet and follow the on screen instructions to enter your information.
If it doesn't, you will need a device that has netflix on it that can connect to the computer (an xbox, PS3, Wii, or compatible player) that can connect to the internet. Again, connect the device, choose netflix, and follow the onscreen instructions.
I can provide more details about these on screen instructions if I know what device you are using.
As a third option, you can connect your laptop to the TV with any video or audio cord. HDMI is a favorite if your computer has an HDMI output port and your TV has an HDMI input.
Can i use the dv port on my monitor to display a movie on a led tv? i bought a dvi to hdmi adapter and plugged into my monitor dv port and the hdmi cable into my hdmi port on my tv and i'm getting nothing...
Ports on the monitor are for receiving the signals from the sources, not for sending signals out to another devices.
Your TV HDMI should be connected directly to the video source output, not through the monitor.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
2helpful
2answers
How do i get on the HDMI input channel?
Hello Jeff. I just have a basic question for you. Was the Blu Ray player turned on when you first plugged it into the tv? TV's are becoming so complicated that they are becoming less user friendly. Try setting your tv to the first HDMI input using your tv remote's input button. Then unplug the HDMI cable from the tv, make sure the player is turned on then plug the HDMI cable into the left most input if horizontal or top input if vertical. Hopefully if you do that and have the input selected, it should work for you.
Also: Whi9le attaching the cable, I find it helpful to have it in a position where I can see the tv, because when a device hooks up the screen usually flashes or turns blue or something similar.
Hope this helped
-Chris
PS3 not working on 42'' JVC via HDMI cable port
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
