Question about Lexmark X7170 All-In-One InkJet Printer
What is error 1203?
My printer isn't working and says error1203?? what is this and how do I fix it??
  • FLEX2MEETU Dec 03, 2007
    hello my name is FLEX.. I try to print anything at all. it started when i went to print out and a sheet got jammed. so I went to the back plate to retrieve it out..But wait I check and cleaned as much of any thing... I gets nothing working.. then the message error 1203 pops up. I turn in on and then off.. I shut my computer on and off. and I checked my control panel for any solutions.. but i still have that error.. Please if this matter is easy to fit, I'd appreciated any answer.. thanks again FLEX (Fitness Trainer)
    Scholar:
  • 104 Answers
Hi, there is quite a long troubleshoot for this problem and so hopefully if you follow this link you may be able to solve it.
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:463:0:0&docid=ENUS25242
See how you go.
Posted on Oct 28, 2007
2 Suggested Answers
SOURCE:
Printerguy
  • 31 Answers
SOURCE: error code 1203
To determine whether this error is due to a cartridge failure or a hardware problem with the printer, do the following: Make sure the printer is powered on. Open the printer's top cover. The print cartridge carrier moves and stops at the loading position. Press down on the cartridge lever to raise the cartridge lid. Remove the cartridges. With the cartridges out of the printer, close the top cover. Power the printer OFF and then back ON. Check the operator panel to see if the 1203 error has returned or if a new message is displayed. If the message displayed is 1203, there is something wrong with the printer hardware. Please contact Lexmark Technical Support. If the message is Cartridge Missing, reinstall the cartridges into the printer. Insert the black cartridge in the left carrier. Insert the color cartridge in the right carrier. Snap the lids closed. Close the top cover. Check the operator panel. If the 1203 message is still present, you need to insert one cartridge at a time to determine which cartridge is producing the failure. With one cartridge in the carrier, close the top cover and check the operator panel. If the 1203 message is displayed, that cartridge is producing the error. If Cartridge Missing is displayed, the second cartridge is the defective item. Please replace the defective cartridge.
Posted on Aug 21, 2007
Error 1203 can u help
The 1203 error could be due to a communication problem between your cartridge and the printer or a short in one of the cartridges. Follow the simple steps below to fix the problem:
  1. Open the printer cover and remove both cartridges.
  2. Unplug and re-plug the printer into the power source to reset it.
  3. When the printer turns on, re-insert one cartridge first. Close the cover and check for any errors.
  4. If no error, re-insert the other cartridge.
  5. Replace whichever cartridge is causing the error to appear. You can also try to insert a different known working cartridge to determine if the other is faulty.
Source: Troubleshooting a 1203 Error Message on the Lexmark X5400 Series
Jul 12, 2011 | Lexmark X5470 All-In-One InkJet Printer
Error1203 what it means
Hello thanks for using Fixya
The error 1203 is a cartridge error. It
is an issue that occurs either when a cartridge is bad or the printer cartridge slot is bad
To solve it try this. This solution works
  • Try cleaning the copper contacts of the both carts and cart slot in the printer and try again OR
  • When error shows up, Turn the printer to Power Off. Wait one minute and turn it back on.
Your problem will be solved.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
Jan 28, 2011 | Lexmark X4250 All-In-One InkJet Printer
Printer does not work. is Lexmark x4270 . I replaced cartridge and it shows on panel this message: Error #1203
There are 3 step to repair lexmark 1203 error
If you got lexmark 1203 error then there is a 94% chance that your computer has registry problems. To repair lexmark 1203 error you need to follow the steps below:
* Step 1 - Download a lexmark 1203 error repair tool,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair lexmark 1203 error.
Here are the url of lexmark 1203 error repair tool:http://www.fixerrorquick.com/ttfix-lexma… http://www.fixerrorquick.com/ttfix-lexma…
Jun 29, 2010 | Computers & Internet
How to fix error 1203
ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Or try
Reset Factory Defaults on the Dellâ„¢ 964 or 966 Printer
To reset factory defaults on the printer, perform the following steps:
1. Press the down arrow button until Maintenance is highlighted and press the Select button.
2. Press the down arrow button until Reset Defaults is hightlighted and press the Select button.
3. The printer displays a confirmation message. Highlight Yes and press the Select button
Note:
Some settings such as phone lists, time, date, and country are not changed.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 15, 2010 | Lexmark X5470 All-In-One InkJet Printer
I get the error message: error1203 when I start my printer what can I do to solve this problem?
This is an ink cartridge problem. Go to the following site and see if it helps. I don't know which printer you have so you'll have to look at the site and pick out your model. Good luck! http://support.lexmark.com/index?page=answers&startover=y&locale=en&userlocale=EN_US&productCode=&segment=SUPPORT&question=error+1203#1
Mar 13, 2010 | Office Equipment & Supplies
I have error eading 1203 what is that and how can
I have an error reading 1203 that won't let me print. Message consult users guide.
Oct 08, 2009 | Lexmark X4270 All-In-One InkJet Printer
Error
error # 1203 how do fix it
Oct 13, 2008 | Lexmark X4270 All-In-One InkJet Printer
Error 1203 What do I do?
Cartridge Error: 1203 Your print cartridge has a short.
  1. Press Power to turn your All-In-One off.
  2. Unplug your All-In-One from the wall outlet.
  3. Plug in your All-In-One.
  4. Reinstall the cartridges.
Aug 12, 2008 | Lexmark X4270 All-In-One InkJet Printer
Error message 1203
This link should have the answer for you.
http://www.dellcommunity.com/supportforums/board/message?board.id=A940&message.id=13761
Jul 27, 2008 | Dell 924 All-in-One InkJet Printer
Error code 1203
Aug 20, 2007 | Lexmark P315 InkJet Photo Printer
Lexmark X7170 All-In-One InkJet Printer Logo
1,786 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
