Question about Uniden Radio Communications
Bcd436hp keypad will not unlock - Uniden Radio Communications
I can't unlock my vteck 15300 dect6.0 cordless pH handset help
I guess you mean the Keypad Lock/Unlock!
You can turn on the keypad lock of a handset.
In idle mode, press * button and then LOCK to turn on the keypad lock. "PRESS UNLOCK TO USE KEYS" is displayed on the LCD.
In keypad lock mode, press UNLOCK to turn off the keypad lock.
Aug 27, 2016 | Lands Phones
How do I Reset BCD436HP?
I can't find anything about a reset for the scanner.
Perhaps you refer to the manual, for setting back to factory settings?
Or how to program or put in a new program, using a micro SD card. http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/BCD436HPom.pdf
May 31, 2014 | Uniden BC346XT Handheld Scanner
What is the best scanner to receive local police reports
The all depends on what the police are using in your area. If the police are on a simplex frequency or a local repeater, just about any scanner will do. If you are in an area with P25 digital trunking, you are going to need a more expensive scanner such as the Uniden BC396XT or the brand new Uniden BCD436HP.
Uniden BCD436HP HomePatrol Series Digital Handheld Scanner
Mar 25, 2014 | Radio Communications
How to program Uniden BCD436hp
If this is the new HOME PATROL scanner, all you have to do is enter your ZIP CODE and it will program itself. It's that easy. See "radio reference DOT com" for more info. Hope this helps. 73
Mar 16, 2014 | Uniden Radio Communications
How do you unlock the key pad on a Nokia phone
Hello
To unlock your keypad press the top left key on your keypad and the star (*) key on your keypad, this unlocks the keypad...
Apr 11, 2011 | Nokia 6085 Cellular Phone
How can I lock the keypad?
Keypad lock: To lock the keypad press Menu then Star (*) key. To unlock the keypad press Unlock (Menu key) then Star (*) key. Press both keys in a fast way.
Hope this help and if helpful RATE please
Feb 22, 2011 | Nokia 6310i
Forgot my keypad unlock code
i have a sprint pocket pc-6700 i forgot my keypad password how can i unlock
Apr 11, 2009 | RIM BlackBerry Pearl 8100
How to lock and unlock keypad Motorola VE240
To Lock your phone
Hold down the # symbol on your phone until it says: "Phone Keypad is now Locked"
To Unlock your phone
The screen should now read in the bottom right hand corner "Unlock". press the corresponding key. It then asks "Unlock Keypad?" "Yes" or "No". Select Yes and press Menu button (also the play/pause button).
Hope this helps you all!
Jan 02, 2009 | Cell Phones
Radio Communications Logo
540 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
