Question about Hunter 44260 5/1/1 Program Digital Thermostat
Troubles setting up a thermostat
Work set
    Master:
  • 571 Answers
The work setting would be only used if everyone in the household has he same schedule. If everyone leaves @ 8am, then set the leave @ 8am. If everyone returns @ 5pm, set the return to 5pm. Most programming done by me does not use those 2 settings because most peoples schedules don't correlate. Some thermostats can even be set up to delete those 2 settings, and only use the sleep & wake for night setback.
Posted on Dec 05, 2014
AUTO FAN NOT WORKING BUT FAN ON WORKS
Sounds like the thermostat is either defective or has a bad connection. If you are familiar with using a multimeter (volt-ohm-current meter), it would be the device to use to trouble-shoot this problem. MAKE SURE THE HEATER IS UNPLUGGED!!!
With the meter set on Ohms, and the heater set on auto, set the heater to its lowest temperature setting. You want to see no resistance (close to zeor Ohms) when check across the thermostat (the temperature knob mounts on it). If you see high or infinite resistance, the thermostat's open and therefore defective. If the thermostat checks out OK, continue checking with the meter. You should have about zero Ohms between the hot pin on the power plug (the narrower one in N. America) and the heater motor lead. If it's open (high or infinite resistance), keep the one meter lead on the power plug and trace back, checking each connection until you find the defective one. Don't rule out a broken wire, maybe inside the insulation (but unlikely).
Apr 08, 2015 | Heating & Cooling
Trouble shooting codes
Code Error 53 is "defective outdoor sensor" error.
source: search engine keywords - Code Error 53
I am not familiar with this particular thermostat; however, here's some general t-stat information; I hope this solution will help you troubleshoot.
Multiple Thermostats set in 1 zone will conflict; the one with the lowest setting will be the determining Thermostat for the group. Here's an option you can try yourself; my solution is 'hard reset' the thermostat - afterwards, i'm outta options. invest in external thermometer battery/natural types; & manually turn t-stat ON or OFF; Additionally, keep an eye on how much draw your AC is doing on your meter.
disable auto & enable manual; however do NOT change settings or power-off t-stat. I'd keep it on what you had intended it from day1. However, some may debate to turn everything off beforehand. personally, myself, poweringOFF the switch connected to your t-stat works. Remove battery and reinsert inverted; wait (5sec-1min); remove; wait 1min ('debatable' timeframe 5sec - 1min); reinsert batteries correctly; if you have a programmable thermostat; do the same with the hit 'reset filter' held down & wait 5-sec1min; observe roomTemp reading. May I suggest to keep an extra thermometer around to determine if temperature reading from the thermostat correct? Friendly reminder to turnOFF 'auto' mode during this hard reset. If reset requires reprogramming your t-stat, do whatever required to set your desired setting. cheers. best of luck.
Apr 12, 2014 | Honeywell Programmable Thermostat Heater
How to set thermostat for garrison 052-2025-6
Hi my name is Dan I miss place my manual for my Garrison Convection Heather 052-2025-6 trying to set thermostat having trouble. My e-mail Danthehandyman@homail.ca
Nov 20, 2012 | Heating & Cooling
Kenmore dryer #86863800 suddenly stopped heating. Having trouble figuring which thermostat or element should be replaced. This dryer has no high/low setting. Only more dry or less dry. One big knob to set...
Hello & Welcome to FixYa
As everything in your dryer is working fine apart from it heating properly so the recommended repair will be thermal fuse/thermostat replacement. However, you can also test its continuity before replacement. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | Kenmore Elite HE4 Electric Dryer
My thermostat is set to 73 degrees when i get home at six it is set at 75 during the day when im not home the past couple of days it wont get to 73 it actually goes up to 76 77 it is working cool is on why...
may need charged a out of adjustment can cost lots is it old unit is outdoor temp. very hot may have trouble catching up to setpoint.on a 95 degree day good luck.
Jul 07, 2010 | Honeywell Electronic Programmable...
Need a "trouble shooting" guide for FocusPRO TH6000
i have the heat set at 73 the temp in the house is getting colder it is at 67 now and it won't come on . why?
Jun 12, 2009 | Honeywell Electronic Programmable...
Honeywell T87f 3855 Doesn't Activate Heater
thats becaue you need more than this zone working like you said about the master/slave this zone is a slave.
Jan 25, 2009 | Heating & Cooling
Replaced a thermostat on a 200 chevy blazer and the service light
low coolant, gas cap not tight, few other minor things. pay a mechanic 40 bucks to have them scan it in case it's something big.
Jan 06, 2009 | 2000 Chevrolet Blazer
Hunter 44260 5/1/1 Program Digital Thermostat Logo
Top Hunter Heating & Cooling Experts
Jay Finke
Jay Finke
Mack Baxter
Are you a Hunter Heating and Cooling Expert? Answer questions, earn points and help others
