Question about Epson Office Equipment & Supplies
Epson workforce 633 ink pad reset - Epson Office Equipment & Supplies
SOURCE: Need To Replace The Waste Ink Pad on my Epson Stylus C66
I modified a little what Worldvet had done. I opened the door as if to change the ink cartridges. I first used a pair of needle nosed pliers and carefully took out the sponge type pad which is along bottom of the printhead travel lane. One will see the two center plactic guides within this lane. The sponge is very delicate, so be very gentle in removing it. It has ink residue in it so use gloves if necessary and upon removal place the sponge on a paper towel folded in triplicate so the ink does not bleed through the towel. Remember to what position it was before removal, so there is no problem when you try to replace the sponge after cleaning.
The second sponge I removed as follows: With the power on, I pressed the ink cartridge removal light (red) (far left) once. This moved the print head to the "far left", before the position to change cartridges. With the power still on and the printhead to the far left, I was able to very gently (with the same needlenose Pliers) remove the sponge under where the printhead was parked. It too is very delicate and be careful not to rip it. It too, one will find, has two plastic slots on the botton which the sponge will have to be returned into. I then turned the printer off, which caused the printer head to return to the parked position.
I took both sponges, and with Alcohol (Pharmacy type), I placed the sponges in a disposable plastic bowl and filled it with the alcohol. I gently used the needle nosed pliers (Closed) as a device to gently press on the sponges which were submerged into the alcohol. I continued to alternate up and down the sponge pads, causing the alcohol to dilute and clean the pads. When the alcohol became saturated with the ink from the pads, I took the pads out of the alcohol bowl and placed the pads on a triple folded paper towel so the remaining ink would not bleed through anything.
I then took the bowl of alcohol/ink and while I flushed the toilet and the water was going down, I emptied the alcohol down the middle of the water spout as the toilet water was completing its flush. This keeps any ink from touching any porcelion.
I then refilled the plastic bowl again with fresh alcohol and resubmersed the pads, just incase there was any ink still left in them. Upon pressing on the pads and the alcohol remained clear (indicating all the ink was removed) I again used another set of paper towels, trippled, and placed the pads onto the paper towels, and squezzed them dry. I disposed of the alcohol the same as before.
I then, first replaced the large pad onto the printhead travel lane, back into the same position, being careful that the holes and slots fits back into its proper position and the edges are tucked under the proper hooks (little plastic hooks attached to the side of the travel lane).
Upon reinstallation I pressed gently on the pad to make sure it was secure.
Replacing the second pad, I again turned on the printer and pressed the ink replacement light (red), same as before, causing the printhead to travel to the far left as before. I then very carefully replaced the second pad into the slot from which it came from.
After I made sure the second pad was secure in its proper position, I pressed the ink replacement light twice, causing the printhead to return back to the parking position. I had already reset the counter, so that was not neccessary. I returned to the computer and printed a test page to make sure the printer was working properly, at which time it was, so I therefore returned to what I was doing and the Service Warning was cleared. My fingers got a little ink; but what the heck, soap will take care of that! Good for another 20,000 pages. Hope this helps, not as bad a it sounds.
Posted on Mar 26, 2009
tigertail
  • 163 Answers
SOURCE: waste ink pad saturated. EPSON STYLUS PHOTO R360
Replacing the pads is costly, messy and requires the printer to be taken completely apart. If you have little or no experience of stripping down printers it is best left to a proffessional. Contact Epson to find your nearest service centre, but remember to get a quote as it may be more economical to replace the printer. Sometimes the counter can "jump" to the end of life number, this especially happens where 3rd party or refilled inks have been used. If you believe this to be the case and there is no sign of ink leakage and the pads look fairly clean then you can just reset the counter using special software called the SSC utility. See these sites:
http://www.ssclg.com/epsone.shtml
http://inkjetprinterhelp.us/epsonSSC.html
More information about this issue and the "official" Epson resetter is available from the Epson web site, please read this link:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Please take a moment to rate this solution. Thanks.
Posted on Apr 14, 2009
websnail
  • 419 Answers
SOURCE: reset ink-pad counter on epson stylus photo 1400
The simplest way to do this is to grab a copy of the A10_IPR utility that Epson distribute to their customers...
The utility is available to North American customers if you register no this site page http://www.epson.com/ipr/
The utility is also know to be available in the wild if you search for "waste ink ipr".
Just remember to scan any download using a virus and malware scanner before you attempt to use it as some utilities contain trojans or similar nasties.
Hope that helps.
Posted on May 12, 2009
  • 11 Answers
SOURCE: Epson printer says "cannot recognize ink cartridges".
Are you using genuine epson cartridges? Many generics simply dont work on the newer printers. Once the printer decides the cartridge is empty, it sends a signal to the chip and that's it. You might hear ink, but if the chip says empty you can't use it. It also has the annoying habit of doing this when there's still 10-15% of the ink left.
I use reusable cartridges from http://www.ccs-digital.com They hold 2/3 more ink and the chips automatically reset to full if you remove and re-insert the cartridge. Instead of replacing the entire cartridge when it's empty, you pop out an internal ink tank and replace just that. So you know the chip has already been recognized by your printer. The ink tanks cost under $3. I think these are a brilliant invention.
Posted on Jul 07, 2009
  • 13433 Answers
SOURCE: reset code for epson px700w ink pads showing full
Hi
You can purchase a service manual and the service program for your printer from. http://www.2manuals.com/index.php?cPath=56
the computer program is used to reset the waste ink counter, follow instructions in the service manual to first replace the was ink pads, only then reset the waste ink counter with the service software for your model.
It would be recommended to take this to a epson service center, but you may do this at home if you wish.
Thanks and good luck,
Ekse
Posted on Aug 14, 2009
End of service for epson wf 7610
If your Epson WorkForce WF-7610 printer shows error message "The Printer's Ink Pads at the end of Their service life" and Epson WorkForce WF-7610 printer has a red light blinking problem: You should be download and reset Epson WorkForce WF-7610 printer Waste Ink Pads Counter with Epson WorkForce WF-7610 Resetter.
Go to this link, you should be able to download the resetter and follow the procedures step by step.
Reset Epson WorkForce WF 7610 End of Service Life Error message Wic Reset...
Jul 22, 2017 | Epson Office Equipment & Supplies
Cant get my Epson Workforce 633 to print. WILL NOT print black.
check if ink came out of the head or nozzles if not then first open the nozzles and head with warm water.
Feb 10, 2015 | Epson WorkForce 633 All-in-One Inkjet...
My epson WF 840 has had counter reset, and waste ink pds changedbut, message reads, printers ink pads at end of life, switch off printer
Google epson waste ink pad resetter.this is a small program from china.you may be in luck and be able to reset the counter.download program run it, select printer from drop down menu.right click icon, reset waste ink pad.switch off printer restart.you may need to do this again.this program also resets cartridges before they become empty so you can get more out of them.
Nov 27, 2014 | Epson Workforce 840 Wireless Inkjet...
Reset Epson WF-7610
I've seen a program reset function which is downloadable from the internet. You will have to google it. I think it's only available on a windows operating system.
Sep 07, 2014 | Epson WorkForce WF-7620 Wireless Color...
Reset wsh ink
whenever i put on the printer it brings the message that, "the printers ink pads are at the end of their service life please contact Epson support"
May 02, 2013 | Epson WorkForce 600 All-In-One InkJet...
Ink pad is at the end of its service life workforce 645
is there a cheat to reset the counter for the workforce 645? similar to the r320 you listed above?
Feb 05, 2013 | Epson Workforce 645 4x Ink MFC
Epson workforce 633 warning paper jam when no paper jammed power wifi and fax auto lights flashing can not get to menu
I had success by turning the printer off and on again with the top pieces up (as if changing the ink). I found this trick also works when I have a scanner error that won't go away. Good luck!
Apr 23, 2012 | Epson WorkForce 633 InkJet Printer
21 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
