Question about John Deere 22HP VTwin 48" Riding Mower
I HAVE FUEL, COMPRECION AND GOOD SPARK, BUT WHEN A CRANK THE ENGINE IT TUNS BUT IT WONT RUN,
IT SEEM TIMMING ITS WAY OFF, ANY IDEAS? TOMORROW I WILL OPEN THE ENGINE TO CHECK TIMMIMG MARK AND PROBLEMS INSIDE THE MACHINE, DOES ANY BODY HAVE TIMMIMG MARK DIAGRAMS? ANY SUGESTIONS BEFORE A TAKE IT APART? THANKS
    Sergeant:
  • John Deere Expert
  • 187 Answers
Many things to consider but, let's try the simple things. You didn't say, so I am going to assume the mower is at least newish, not 30 years old. Let's say you have less than 300 hours on the engine. Let's further assume it worked last summer, or last week, but now it's acting up. Let's also verify the battery is in good shape and fully charged.
A mechanically functional (meaning all the internal parts are working, i.e. pistons, valves, etc) engine requires 3 things, air, fuel, spark. So the quickest way to start your diagnostics is to remove the cover over the air filter and then remove the air filter. I do not recommend spraying Quick Start.
  1. remove air filter
  2. put throttle on fast run (do not choke)
  3. pour an ounce or two of fresh gas into the carburetor
  4. crank engine (15 to 20 seconds, rest to cool the starter, repeat 3 times if it does not fire at first).
Removing the air filter and placing the throttle at full speed, no choke, eliminates the "air" question. Dumping in the fuel eliminated all fuel related questions. What's left? Spark. If the engine fires and runs a bit, then dies, you have eliminated the spark question. The engine started so Spark and Air are good; you have to track down a fuel problem.
If the engine does not fire, you have eliminated the Air & Fuel questions; you must tract down a Spark problem.
Tracking down fuel problems.
  1. Make sure there is plenty of fresh fuel in tank.
  2. Remove fuel line from filter and remove the filter, gas should pour out of the hose coming from the tank. If it does not, remove gas tank cap. If fuel flows now, you need to unclog the cap vent or replace the cap. If the fuel still does not flow then blow air from the filter end of the hose back up through fuel line to blow out blockage inside the gas tank. Once you have fuel flowing out the line to the filter, PUT ON A FRESH FILTER. Try cranking the engine. If it still does not start move on to the carburetor.
  3. Note: many systems have a fuel shut off solenoid. This is a small black cylinder on the bottom of the carburetor. It has two wires running to it. It should make an audible click when you turn the key on.
  4. NOTE: if battery voltage drops below 9 volts when cranking or while the engine is running, the fuel solenoid will not function. That means the engine will not start or will die soon after starting. So check your battery voltage before, during, and after cranking. If the battery voltage is good before but drops below 9 volts while cranking this is generally a sign the battery has one or more bad cells. Replace the battery. If the battery is in fact good and the voltage is still dropping you may have a bad starter motor and it is drawing to much amperage.
  5. Ck to see that the carburetor bowl is full of fuel, if not...you may have to disassemble and clean the carb at this point.
Tracking down Spark problems.
  1. verify battery fully charged.
  2. verify the fuel cutoff solenoid clicks when you turn the key switch
  3. get fresh spark plugs and verify gap
  4. install plugs and crank.Perhaps verify spark with a spark testor
If these simple steps do not solve the spark problem, you have a Spark problem that moves into the arena of complex. You will need to check coil gap and coil performance. If it still doesn't start you will need to diagnose the electrical system for wiring and safety switch problems, key switch problems, fuses, etc.
Once you get it running be sure to replace the Air Filter with a new one.
These simple steps solve most starting and running questions and problems.
Posted on Mar 14, 2015
2 Suggested Answers
  • 146 Answers
SOURCE: Lack of Spark
If all of your tests are correct, the thing remaining is the ignition coil. A bit of a pain to get at and expensive too. Parts diagram here. Before you buy a new coil, see if there might be just a broken spark wire or loose connection at the spark plug contact end.
Posted on Jul 17, 2010
Installed timimg belt on a 05 Chrysler Pacifica 3.5L V6. Marks are aligned correctly with engine on TDC. But car starts like timing is off. Has no power. No codes present. Running out of ideas. Can so
I have had this problem on one car where the inside of the gear has detached from shaft , another where the distributor had mal alighned its weights
Jan 06, 2015 | 2005 Chrysler Pacifica
Engine revs
helo,
try tuning up the engine properly.... tis wil help u
May 28, 2008 | 2002 Hyundai Accent
Timming chain install
You know that you have to completely remove the motor from the car, to replace the timing chain?
Mar 29, 2014 | 2006 Pontiac G6
1998 v70 xc timming belt , have problems setting up timming marks.
This shouldn't be a problem. I can't seem to send diagrams through this forum so please email me at iambanshee74@yahoo.com and please include the engine size and whether it is turbo or non turbo.
Aug 03, 2011 | 1998 Volvo S70
Dont know where to line up timming/ trying to line up notches. need a diagram
i can explain how to time an engine with no timing marks at all but i dont know or have a diagramn for this engine so if no one answers with a diagramn then get back to me tomorrow and i will explain but it takes me a good 20mins to explain so if you can get a diagramn so much the better
Nov 22, 2010 | 1996 Oldsmobile Achieva
Machine keeps stopping and says to turn it off
Hi. Is there an error number on the screen? may i have the exact error message that appears on the screen.
Sep 11, 2010 | Singer Quantum XL-5000 Computerized Sewing...
Timing mark location and set up for t-belt, engine broke t-belt, just replaced head assy
TIMMING BELT MARKS
NEED MORE INFO ON ENGINE 4 CYL OR 6 CYL
ALSO IF YOU JUST REPLACED THE HEAD ASSEMBLY MEANS YOU BENT THE VALVES WHEN THE BELT BROKE. TIMMING MARKS ARE DIFFERANT ON MANY MAKES PURCHASE A CHILTON MANUAL FOR THE YEAR AND MAKE OF YOUR CAR THESE MANUALS ARE GREAT AND TAKE THE GUESS WORK OUT OF THE TIMMIMG MARK ISSUE
Aug 22, 2009 | 1998 Hyundai Elantra
2001 oldmobile alero will not start timing chain &coils replaced
i'am a little confused here. are you saying it jumped time and you took it apart and put new timmimg gear and chain in? and don't know if you got marks lined up right, between cam gear and crank gear?
Jan 31, 2009 | 2004 Oldsmobile Alero
Water pump
On the 1987 plymouth voyager after market water pumps can cause shredding of the timming belt.
Use of a original maufacturer water pump can sove this problem but does cost more. Worth the cost unless you just like changing timmimg belts.
Oct 26, 2008 | 1987 Plymouth Voyager
How to set timming on Singer Touch & Sew 638 Sewing Machine
I have a timing problem with my Touch&Sew Singer model 638.
Jean
rlacasse@ntl.sympatico.ca
Mar 02, 2008 | Sewing Machines
John Deere 22HP VTwin 48" Riding Mower Logo
163 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
