Question about Vodavi Lands Phones
Where is reset button
System is completely blank and phone does not ring.
2 Suggested Answers
  • 1011 Answers
SOURCE: my phone went coimpletly blank can i reset it
Dear,
u mean that phone doesnt show anything even the startup display and went completely black... so it can be the cause of strip that joints the LCD to the circuitry because in most cases of filp phone it happens alot... get it repaired....if the display doesnt see at all, the format or reset will not work...its an other case dear
regards,
hope it will fix the issue so dont forget to rate it..
Posted on Jul 06, 2009
I was texting on my phone when my phone screen went completely black. i thought i was maybe dead or i powered it off but i didnt.
Have you tried force shutting down your iPhone? To do this, hold down the Power Button and the Home Button at the same time for 5-10 secs, then power on your iPhone again, check if it works. Or try to reset your iPhone using iTunes (Backup your data first). If not, maybe the display of your phone is malfunctioning, send it to the nearest Apple Service Center for repair.
Mar 10, 2015 | Apple iPhone Smartphone
Phone handset screen is blank. It says Searching and when I press a button it goes blank.
Try unplugging the battery inside and reconnect it and put it back on the charging stand
Mar 02, 2015 | Uniden DECT 6.0 Cordless Telephone...
Hey whats the button on the top left of the phone with the volume control?? my phones dead!! gaaayyy
The slider which is next to the volume button is ringing mode or ******** mode.
If the phones dead try charging it completely and try. If that doesnt work, then do a reset on the phone which will work.
Jan 06, 2010 | Apple iPhone Smartphone
My screen went blank so went to switch it off the slide to switch off came up and the cancel button but it wont let me, it still plays music via headphones and volume button wrks also rings?
Try a reset. Hold down the power key at the same time as the round home key until
phone powers down. Release buttons only when you see the apple logo,
then wait a min or two for phone to re-boot. You will not lose any data on the phone.
If this does not work, try an actual system reset. Sync iPhone to computer to back
up essential data ie contacts apps etc, then go to settings general and reset. Reset
all settings as a last resort. This will give you a fresh start and should sort out
the majority of any bugs the phone has. A resync with you computer will restore apps etc.
Hope this helps and if so please vote.
Thanks
Jim
Oct 10, 2009 | Apple iPhone Smartphone
I have a Lucent (Avaya) Partner 18 phone system. One extension will not ring when there is an incoming call. I have set the extension to immediate ring but it still does not work. Any other ideas to try?
see if the DND or do not disturb is on. It should be a lit button programmed on the set, if its not programmed press feature 00, press a blank button and press feature 01
Sep 11, 2009 | Lucent PARTNER18 Corded Phone
Since power outage phone lines do not ring - only to receptionist
Your system lost its programming. It will need to be reprogrammed completely. The lines are ringing on the extensions where I voicemail is, unplug voicemail and at least lines will ring in correctly.
Jun 15, 2009 | Avaya Lands Phones
When someone calls us, the phone does not ring. I can call out.
Try to reset the phones by unplugging all cables for ten minutes.
To get the manual, give me the exact model number.
Dec 11, 2008 | Uniden Cordless Phone
Telephone ringing problem
Okay first you'll need to know the 2 digit "Set" number for your Phone.
Press "Featire" *0 then Intercom to get the 2 digit number.
Okay Now we need to configure:
Press "Feature" **CONFIG or **266344
Press: Next until "Sets" appears "press Show" Top Right Button
Enter 2 digit "Set Number"
Press Next Until You Get Ringing Lines
Hit the "Change" Button to Turn the Line to "Yes" to ring
Do this for each Line you have that you want to ring.
Done, Please Rlease.
May 27, 2008 | NorStar M7310 Corded Phone
Siemens Gigaset 2420 corded unit resets when calls received
OK, here's what happened. I had the same issue of the phone resetting when a call came in, I thought it was a power issue and through some testing it was not. Here's the fix...Menu \ system settings \ enter pin (if you haven't changed it it is 0000) scroll to factory default and reset. This fixed the problem somehow for me, make sure to write down any impotant messages because it will erase everyting (silly me). I hope this helps.
Nov 14, 2007 | Siemens Gigaset 2420 Phone
Lands Phones Logo
16 people viewed this question
Top Vodavi Lands Phones Experts
george  peters
george peters
Matthew MacWilliams
ray gallant
Are you a Vodavi Lands Phone Expert? Answer questions, earn points and help others
