Question about LG LRFD25850 French Door Refrigerator
GR-L207DTUA. frig drawers freezing. Freezer thaws at times. Compter settings show 'error and error.
3 Suggested Answers
Maytag317
  • 1136 Answers
SOURCE: ice under freezer drawer
Hi, Check in the back rear of the freezer and se if you have ice built up. MOST cases the defrost drain gets plugged behind the rear freezer wall under the evaporator.
Please let me know if I can assist you further.
Thanks
Vic
Posted on May 26, 2009
AndreaBl
  • 218 Answers
SOURCE: refrigertor setting out
hi there,
your problem can only be fixed by a professional, please call your local repairman to fix this.
Posted on Jun 11, 2010
Refrigerator would have water and ice under crisper drawers. We repeatedly unthawed. Now fridge and freezer wont cool. What could it be?
When you thaw it out it still isn't thawing the Air vent that brings cold air up to the Frig. This will usually freeze up the circulator fan.
Common problem with these side by sides.
Mar 02, 2016 | Samsung RF26XAERS 26 Cu. ft. French Door...
We just purchased the Frigidaire FGHC2378LP and hooked up the water line and it worked, no problem. Then we unhooked the water supply from the water shut off valve for 3 days and hooked it back up and now...
Sounds like its frozen, is why you arent getting water unfortunately until you fix temp problem or unplug it to thaw it, its probably not going to work.
Sean
Mar 27, 2011 | Frigidaire FGHC2378L Side by Side...
The freezer is working fine but the refrigerator part is warm on the coldest setting and the door has been shut for more than 8 hours.
Hi, I have seen this a lot in my 13 years in maintenance work, the most likely problem is ice build up in back of freezer behind the plastic liner.The drian tub freezes over and when the frig goes into defrost cycle the melted ice has know place to go and covers the air holes that blows into frig to keep it cool. You my have noticed water in the bottom of frig. You will have to either take freezer apart inside and remove ice and thaw out drain tube or unplug frig to thaw it out.
Mar 05, 2011 | Refrigerators
Hi I have A GE 18 cube frig model GTA18QBNBWW. Initially the food on the top shelf was freezing in the frig I discouver the coils were blocked by massive clumps of cat fur. i cleaned it out. next day i...
you have done a good job so far . so next ck the dampner at the top in the fresfood side . it may be stuck open causing the freezing . but the evap coil was frozen so you may have a heater out in the freezer so ck the defrost system heaters and defrost terminator . ..mm hope this helps feed back pls
Jan 19, 2011 | Refrigerators
Freezing problem in maytag frig
the probe from the temp panel is not sensing correct temp or the panel itself is bad...call a tech to check it out
Feb 04, 2010 | Refrigerators
Freezer not freezing & fridge warm at top and freezing at bottom.
Check and see if you have a fan that is not working. A condenser fan might just be your problem. The air is not circulating right. If this isn't the solution try turning the frig off for a couple of hours to see if it will correct the problem. BB
Dec 15, 2009 | GE GSS22SGPSS Side by Side Refrigerator
Ge profile refrigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 05, 2008 | Refrigerators
sounds like a defrost or sensor problem. or the main P.C.board. probably the board and sensors.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
LG LRFD25850 French Door Refrigerator Logo
15 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
