Xmp3i delphi satellite radio no sound from headphones
Sound comes out of stereo through home docking station and works in vehicle but no sound from headset when plugged into jack. tried 3 headsets that work on other mp3 player. volume controls do not work so is not recognizing headset?
SOURCE: speakers won't work when Ipod is docked
The problem is that Atlec Lansing used a low quality (piece of ****) plug/interface for the dock. If you pull the top of the ipod forward while it is pressed fully onto the docking station, you'll get a surprise. It will work. This problem stumped me for days. Now, the next question is how much tension is the proper amount not to degrade the cheap plug further or damage the ipod itself.
Cheers,
Jeff
Posted on Feb 17, 2009
  • 76 Answers
SOURCE: Headset for 2006 Volvo XC90 DVD player
If the car is certified and the dvd player is factory the system is required to work to pass certification.
First, Look in the owners manual to make sure your doing it right.
Second, go back to the dealership and see your salesman, they should be happy to get it fixed for you.
Third, take it to the service department. The car is certified, so when the policy takes effect the service department will fix it for whatever the deductible is.
Fourth, Call Volvo customer relations and tell them about your issue.
Hope this helps.
Posted on Feb 23, 2009
  • 8 Answers
SOURCE: mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Posted on Apr 07, 2009
  • 23 Answers
SOURCE: Computer Does Not Detect Headset Microphone
Sound and Recording jacks stop working on the DV6000 series due to the ribbon cable running under the power button. when the power button is pushed it bends the flex cable and over time it breaks the connection rendering the front jacks useless you can buy a new upper button panel for about 20 dollars on ebay
Posted on Aug 02, 2009
noobcybort
  • 199 Answers
SOURCE: No sound from Sirius Sportster SP-R2R satellite radio
Hello there !
I suggest you fix it don't through it yet ,I want you to change this chip .
sound IC( Amplifier ) it could be damaged or something is loose inside .
good luck
Posted on Dec 08, 2009
No sound comes out of radio?
Turn up the volume by pressing the top of the center cluster of buttons. Does it work in the home dock or car dock without headphones?
Nov 23, 2012 | Tao XM2go Satellite Radio Receiver
XMp3i is stuck on "powering
Bad TSOP flash chip. No way to fix without disassembling, removing the flash chip, and placing a new flash chip on it. Doing so requires a donor radio (with another issue), and will change your XM Radio ID. You'll also need to have a hot air (or IR) rework station for desoldering the old chip, and a soldering iron for placing the new chip on the radio.
I'd say give pioneer a call since it's a design flaw, and a VERY common issue. My best guess is that it's caused by excessive heat & defective chips.
Aug 07, 2011 | Pioneer GEX-INNO1 XM Radio Receiver with...
Hello - I've had my SKYFi2 receiver for about 4 1/2 years. For the past 6 months it cuts in and out, as in, plays the station that I'm on, then it stops and just says "antenna". ...
Hi Kathy,
It sounds like its the antenna, although it could be the docking station itself, or even the receiver. The best way to narrow it down is by testing against other equipment (if you happen to have other docking stations and or antennas) If it produces the same result you know its the radio. If you swap antennas and it works, obviously the antenna; and the same goes for the docking station. You can find replacements at tss-radio.com.
Jun 15, 2011 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
When using headset with skyfy3 display says check antenna .
Are you using the special Delphi headphone with the built=in antenna? There is NO antenna built into the SkyFi3 like the MyFi - you must have the special headphones with the antenna built in. okay?
Jan 18, 2011 | Delphi SKYFi3 XM Radio Receiver
My Delphi XM2GO MyFi has stopped transmitting to an FM station on a house radio. Is it repairable? If so, is there a facility in the Cleveland, OH area where I can take it?
IF you take it out of the home dock and run it on batteries, I'll bet you it works again. The newer home docks TURN OFF the FM transmitter. Try a car dock, or try it with just the power plug plugged into the bottom of the MyFi, without the home dock and see if you can now get the FM transmitter to work. Let me know. Thanks and good luck.
Aug 09, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
Cannot power up xm onyx radio in docking station; will turn on when not in docking station..what's wrong?
I had the same problem, Bought a new Onyx and tried the supplied 12v power cable on existing Onyx and it worked, So it appears to be the power cable, Hoping now I can find a new power cable,
Dec 30, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
No signal
Here is a site that cares a lot of sat. radio things
http://www.xm-radio-satellite.com/
This maybe what you are looking for a "Delphi XM Radio Wireless Signal Repeater System"
May 08, 2009 | Delphi SKYFi XM Radio Receiver
Antenna
Wear the antenna headphones around your neck and use ear buds. Works like a charm!
Jun 04, 2008 | Delphi SKYFi3 Satellite Radio Receiver
Audio stuck on high
You cannot adjust the volume when the stereo cord is plugged into the back of the dock. Instead, plug the stereo cord into the front headphone jack of the dock. You will be able to adjust the volume then.
Mar 11, 2008 | Sirius Stiletto 2 Satellite Radio Receiver
90 people viewed this question
 Grubhead
Grubhead
