Question about RCA D52W19 52" Rear Projection Television
RCA 52" HDTV Rear Projection TV MM52110JX1
This is a March 2001 RCA 52", SRS Focus,Model# MM52110JX1/Chassis # MMC102G. There is a blue ghost/shadow above darker then blue objects, a wave of blue if  the object is blue or a line across screen. If the color is lighter then blue their is a yellow ghost/shadow above the object, a wave if  the object is yellow or a line across screen . The yellow seems smaller then the blue & seems to be below the blue. Cutting the settings to black & white only, it is not visible.  The whole screen is not affected, only a 7" area @ 11:00, Top & left edge is About 4" down 6" from the left going to the center of the screen. I removed the rear panel & cleaned the mirror,lenses & screen with no changes no bugs or dents found.Only a little better overall picture.  Almost looks like one or more of the lenses are stronger than the others(or weaker). Is their any adjustments I could do, or hidden settings I maybe missing?
  • adam_squires Nov 11, 2007
    its a covergance proble turn tv off wait 10 sec. press and hold col- and chan- till tv comes on and select convergance and use level 1 and that should fix it u might haft to do level 2. if u need help adam_squires@msn.com. i own a tv repair center
  • RCA Master
  • 5,138 Answers
Replace FL231 400ma fuse. this will fix your problem.
Posted on Feb 17, 2008
My RCA 52" HDTV Rear Projection TV Model #MM52110JX1 will not turn on. Neither the remote, nor the front panel switch will turn on the TV. When you press the power button on the remote, the red indicator...
you must check the light indicator if how many times does it blink which tell the main problem or the error code of the tv. either the power supply doesn't work normally or the lamp need replacement.
Sep 23, 2013 | RCA D52W19 52" Rear Projection Television
52" rca hdtv has a shadow ghost when it plays. It
convergence issue. Press menu and then scroll down to the setup option enter setup and scroll to Autoconvergence and activate the auto convergence feature that will realign the convergence . If that doesnt correct the issue you will need a Convergence power board, If the auto convergence feature is missing from the setup menu then you need the convergence option missing repair kit. Both the board and the repair kit are available from www.tvrepairworld.com
Jun 18, 2011 | RCA D52W23 52" HDTV CRT TV
I have a 52 inch RCA projection tv. Where are the color adjustment screws on the back of the tv that everyone keeps telling me about?
This is Chassis PTK195-There are screen/focus adjustment knobs (red green and blue) at the front of the set - behind the speaker grill and front access panel.
Oct 11, 2009 | RCA P52926 52" Rear Projection Television
3 year old rca rear projection just started going blurry. green blue and red line across the top of screen. objects have shadow.
Focus and screen control box / remove front bottom panel there you will find it / it has 3 controls on top 3 on bottom top are focus for RGB tubes bottom controls adjust screen drives for RGB.
Jan 25, 2009 | RCA D52W23 52" HDTV CRT TV
RCA SRS Focus turning on and off
the best thing you can do is take it to a shop and have it repaired as the problem has gotten worse..
Jan 08, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Flashing green power light on TV
have the power supply checked out sounds like it went out
Jul 09, 2008 | JVC AV-56WP74 56" Rear Projection...
Rca d52w23
you will need a new convergence board as that model doesnt have the conventional ICs so the entire board must be replaced. let me know if you need further info.
May 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear Projection HDTV-Ready Television
Yes,but what your set has is poor solder connections around the Flyback Transformer.ThankYou for using FixYa. Have a Nice Day.
Jan 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W19 52" Rear Projection Television Logo
1,057 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
