Question about Sullivan Air Express III Blow Dryer
Hot air not working - Sullivan Air Express III Blow Dryer
My Renault logan only blow cold air
So the AC is working, but when you select hot air, it doesn't work? Does cold air come out when you select hot air, or does no air come out? Please provide as many details as you can. What year is the car?
Perhaps the dial to select hot or cold air is not working. Does the dial feel the same as it always has, or has there been a change recently?
Is the engine warm when you try to select hot air? If the car hasn't been running a while you won't get hot air.
Jun 10, 2015 | Renault Cars & Trucks
2007 Hyundai Tucson - no hot air from heater.
Your car is low on coolant most likely.
Nov 04, 2014 | Hyundai 2007 Tucson
My air conditioner on 2007 suzuki reno blow hot air
it will need service,
check pressures.
hot air as in heater on, so turn off the heater,
test in pure A/C mode Cold.
when both A/C and heat are on this is called defrost mode
which adds cold dry air to hot air and dehumidifes the hot air and window.
Jan 18, 2014 | 2006 Suzuki Reno
Air conditioning blows hot and cold air
You will need to know if the compressor is working when it blows hot air to proceed. It could be an electrical problem, a blend door problem, or the a/c clutch on the compressor.
Jul 02, 2012 | 1999 Honda Civic
The heater blows hot air when in cool position on a 98 olds bravada
AC not working?
on a hot day it will blow warm/hot air if the AC is turned off or not working
If its hot air and AC is working then i would start by checking the fuse or relay. if its not the fuse/relay then i would look into the heater box there is a door that blocks the hot air
Jul 14, 2011 | 1998 Oldsmobile Bravada
Hp printer 2600n it give every print yellow background even demo or test page ,, but no back ground on engine test print
problem with formatter board
Open the back side cover
remove formatter board and resold with hot air work station(hot air work station is a hot air generator to remove or fix the surface mounted components )
be very carefully if you use very hot air more than 300C then he damage the board
Jan 18, 2011 | HP Office Equipment & Supplies
Air cinditioning blowing from cold to hot air
need to check ac fan or fans ,are they working? if not check fuses and fan relays,,,,,and fans (hot wire the fan to see if it/they work
Jul 05, 2009 | 2000 Acura TL
Blows hot air
My 2003 chevy suburban just started blowing hot air...it was working find , then i stopped to eat lunch, when I came out it started blowing hot air
Jun 25, 2009 | Heating & Cooling
Air conditioning blowing only highest setting but HOT air
Sounds like your freon has leaked out and your heater blower resistor is burned out. Deffinitly take this to the dealer.
May 20, 2009 | 2001 Honda Odyssey
Sullivan Air Express III Blow Dryer Logo
93 people viewed this question
Top Sullivan Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Sullivan Health and Beauty Expert? Answer questions, earn points and help others
