Question about Tivo Televison & Video
Stuck on direct tvs weatherNation, channel won't change. Has been on it all day. SAID it recorded Dr. Oz, etc. but was on WeatherNation each time
The tivo will not change channels. WeatherNation is on. HELP me, pls.
5 Suggested Answers
SOURCE: Tivo won't change my TV Channels anymore with direct cable
I re-did the guided setup in the Tivo under Messages & Settings/Restart-Reset System/Restart menu section in Tivo. Once I did that, it cleared this issue, even though I didn't have to change any of my settings thru this guided setup. I tried a reset alone first, but that did not fix it. Only this fixed it. We had lost both power and cable during a recent tree fall in a storm, and when both were restored, this problem started. I have a cable coax directly in the back of the TV (no cable box/IR etc) and the system is on a home wireless network. I actually have 2 identical Tivo's in the house set up the same way but only one had this problem. The other worked no different after the outage.
Posted on Oct 13, 2008
SOURCE: TIVO DVR : Won't Change Channels
Set up your infrared blasters connected from your IR port on the Tivo and by placing the two lead lights in front of your cable box so it (the cable box) can read the signal.  Then go to Channel settings accessed through Tivo Central and follow the questions. It will ask you to change channels until the remote is working correctly.  This all worked on a different "input" on my Mitsubishi TV (it has multiple inputs.  I have the cable input on a different "input" to make it work.  Hope this helps.  Call TIVO tech assistance because they are the ones who talked me through this.
Posted on Jan 15, 2009
  • 17 Answers
SOURCE: When my TiVo stops recording a show on, say,
The end of the IR Cable that attaches to your cable box may have to be repositioned.
Try moving it a small distance (you are already close or you wouln't be receiving ANY channel changing info. from it) and see if that helps.
Posted on Sep 21, 2009
SOURCE: how do i reset my philips tivo to record two
to my luck my son reset it by going to direct tv on screen and following the promps which allowed the second satelite to load ,which corrected the problem thanks for your response
Posted on Jan 14, 2010
Do you take both capsules of garcinia cambogia 1300 at the same time or separately?
Take both at the same time.
"according to dr oz 3000mg per day, 1000mg (2 CAPSULES) 1/3 hour to an hour before each meal THREE TIMES A DAY"
Aug 19, 2015 | Coffee Makers & Espresso Machines
Does the JVC DR-MV5S DVD recorder/VCR combo unit have an analog tuner or digital tuner, so that you can record one channel while watching a different channel on your TV?
You can read what JVC is telling about the recorder. It is not an digital tuner, but still you can record a DVD and watch another channel or vice versa.
Want to read the whole manual? click the link:
DVD Recorder Hi Fi VHS Combination DR MV5S Introduction
Jul 25, 2014 | JVC DR-MV5S DVD Recorder/VCR
I have a Goldstar VCR and I want to record a tv program using it. How do I do it?
Most Goldstar VCRs only have an analog tuner. (TVs do not often have an option to output their video to another device.)
So first what is the source of the TV program? If it is an OTA analog or CATV cable. Set up the VCR normally by connecting the incoming signal cable to the VCR and then use the coax out to the TV. Scan for channels and set the VCR to record the desired program. (Either use the timed record or one touch record method.)
If your source is digital, you will need a set top box (either a digital to analog converter or cable box). To split an incoming OTA signal between your TV and the converter box, you can use a switch or a splitter. (A splitter will give lower signal strength to both the TV and the converter box.)
Depending on the box, you can either connect a coax cable from the box to the VCR and then to the TV or composite video from the box to the VCR. If you use coax, set the converter to channel 3 or channel 4 and record that channel. Otherwise set the VCR to record Line 1.
To record, put in a tape with sufficient space available with an intact safety tab. For One Touch Recording, set the VCR to the desired channel and tape speed. Then press Rec. Press several time for a timed recording. For Timed recording, press Menu > Program. Press Select and move through the list to program day to record, the start/stop time, and channel, etc. When done, press Menu to save the setting. The timer light should come on (most VCRs will turn off).
I hope this helps.
Aug 05, 2011 | Goldstar GBV241 DVD Player/VCR
Toshiba Hdd/Dvd video recorder. Moved unit to a static caravan,comes on ok but when using the remote to use it ,no matter what button I press I get the message 1. DR-OFF Can you please help ? I have the...
Got the same problem today. I found the solution online on the installation guide. You need to push the two channel changing buttons on the recorder at the same time for 3 seconds.
Jan 11, 2009 | Toshiba RD-XS32 DVD Recorder
Dr hd 100 quicktime clips
You cannot have one continous clip, the clips are recorded seperately
Dec 30, 2008 | JVC DR-HD100 (DRHD10040)
Oct 12, 2008 | Tivo Series 2 80-Hours Video Recorder
Hold both the channel up and down buttons on the front of the recorder for 3 secs until DR1 shows in the display. Try it and let me know if it worked..
Apr 16, 2008 | Televison & Video
DR-MV5S will not record
do you mean nothing at all happens?, or the program never recorded? check to see what input you're on.[channel 3, line in1,2,etc. also see what format the player records on.[dvd-r, dvd-rw, dvd-+r, dvd+rw or ram.
wg
Feb 16, 2008 | JVC DR-MV5S DVD Recorder/VCR
Televison & Video Logo
Top Tivo Televison & Video Experts
Henry  Thomas
Henry Thomas
Computer Repairing
Computer Repairing
Are you a Tivo Televison and Video Expert? Answer questions, earn points and help others
