Question about Horizon T70 Motor Control Board
Treadmill shuts off and won't run
The treadmill lights up, but when you attempt to set a workout program it beeps and shuts off. This is a new problem we've just begun to expeience
Check that the speed sensor is the right distance from the magnet on the drive wheel. If it does not pick up a signal whithin one or two revolutions it will shut down.
Posted on Feb 14, 2014
Treadmills are shutting down after persons are running on machine. The power is tripping, shutting down. After break or machine is turn on it works again
Chances are the treadmill started by shutting off in the middle of a workout and has gradually gotten to the point that it will not run long, or turn on at all, in some cases. This is most likely caused from a worn deck and belt. If the belt and deck is not routinely waxed, it wears down and causes friction. This friction builds up heat which can fry your electronics. The machines circuit breaker shuts the machine down to protect the major electronic components. This protective measure, built in by the manufacturer, will only help for so long. After a few times of shutting down due to the heat, it actually does damage to the electronics. The result and correction usually ends up being a new deck, a new running belt, and in most cases that have gone on too long, the motor control board. I am attaching a link for the service manual for further information. Parts for Matrix T3 Treadmills T3x T3xi Belts Rollers Decks SPORTSMITH...
Aug 27, 2013 | Matrix T3x Treadmill Deck Treadbed Parts
My horizon ct5.1 turns displays select workout, buttons all beep but do not respond
replace the old batteries with a new ones, type hybrid rayovac, with the same polarity. clean the contacts batteries with c. cleaner
2) Tight the ribbon cable inside the display board.
3) Adjust the REED swithc, see the diagram attached. Test for open or faulty. Clean it, tight the connector very well.
God bless you
Jan 09, 2013 | Horizon Exercise & Fitness
What kinds of workouts can I do on the elliptical machine?
Youcan do endurance workout, hill climbing workout, and interval training. Formore information on these workouts, check out this website: http://www.livestrong.com/article/100587-workout-programs-elliptical-trainer
Aug 05, 2012 | Exercise & Fitness
How does the e3200treadmill fat calories work with the regular calories burnt.
Add incline. Instead of keeping the treadmill on a flat surface, maintain an incline as you walk, jog or run. This will serve to replicate the wind resistance and terrain variation that you encounter when you run outdoors. Keep an incline of at least 1.5 percent on your treadmill throughout your workout.
  • 2 Increase your speed. If you run at the same speed every time you workout, your body will not be challenged and you may reach a fitness plateau. Up your speed by a quarter-mile per hour every few weeks.
  • 3 Vary your workout time. In order to challenge your body in different ways, variety is key. If you run for half an hour three times a week, opt for a one-hour run for your fourth workout. This will help to condition your body for endurance training, resulting in more calories burned.
  • 4 Use intervals. Interval training can dramatically increase your calorie burn in an average workout. Instead of running at a steady pace for your entire workout, mix in sprints. Jog at a steady pace for two minutes, and then increase your speed to a full sprint for 30 seconds. Return to the steady pace to recover. Your heart rate will rise on your intense sprint intervals and stabilize on your longer recovery periods.
  • 5 Incorporate incline into your interval training. You can use incline in the same manner that you would speed to interval train. Walk or jog at a 5 percent incline for two minutes. Increase the incline to 10 percent for two minutes and then to the 15 percent maximum for one minute. Decrease the incline back to 10 percent for two minutes and finally back to 5 percent for two minutes. Repeat this same pyramid interval a few times.
  • 6 Wear a heart rate monitor. This will monitor how hard you are actually working as well as how many calories you burn in each workout. You can then adjust your speed and incline accordingly to maximize your calorie burn.
  • 7 Drink plenty of water before, during and after your treadmill workout. If you are dehydrated, you won't perform as well as you can. You'll work harder and burn more calories if you're hydrated
  • Nov 03, 2011 | Exercise & Fitness
    My treadmill will light up an make a beeping nose when a button is pushed. The treadmill is pluged up and the red cord magnet is on when the buttons are pushed. However it just does the same beep for...
    If the screen is lit and the screen shows that the belt is moving then it’s the motor controller. If the screen does not show that the belt is moving then it’s the console.
    Oct 20, 2017 | Horizon Fitness T82 Treadmill
    Just purchased a new Nordic Track T7.3 treadmill. Set it up and completed one perfomance workout plus 3/4 of a weight loss workout when disaster struck. The mill was placed on pause and when the start...
    Just had mine delivered on February 11th. Ran on it once and the screen went to complete contrast darkness. You could still see the display but you could see it better at an angle than you could looking right at it.
    Got on it today and the screen was completely blank just like you (after 6 uses). Sears came and the guy said the screens on these treadmills were junk.
    Apparently Sears will be replacing our treadmill at some point!
    Mike
    Jan 10, 2011 | Nordic Track NordicTrack T7 si Treadmill
    Healthrider s5001 treadmill stops during workout, shuts down. Will run for appx. 10 min.
    check manual for maintance on walking belt lubercation- mtr shutting down to over heating-pulling too many amps to rotate rollers/belt and to move you. Friction problem
    Jan 08, 2010 | Quantum ® 3.3ESD Treadmill
    Manual Treadmills vs. Motorized Treadmills
    Treadmills come in two basic varieties, just like lawnmowers: manual and motorized. But, unlike a lawnmower, you will generally get a better workout from a motorized treadmill. Manual Treadmills - Getting Going On a manual treadmill, the action of your feet against the deck moves the belt. Pros * You provide all of the motive power and exercise your lower body. Cons * It can be difficult to get the belt moving intially. That straining against the belt can stress your joints. * You may have to raise the incline of the treadmill significantly to make it easy enough to get the belt moving. * Once the belt is moving, however, you would have to stop and get off to change the incline, so you are stuck with one incline level during each workout. Motorized Treadmill Advantages * The belt is moved by the motor, you don't have to strain to start it. * On many treadmills, you can adjust the speed and incline while you are still walking or running. On others, you may have to get off and adjust the incline manually, but you just have to turn on the treadmill to start the belt again. Manual Treadmills - Speed With a manual treadmill, you go only as fast as you push yourself. If you slow, it slows. If you stop, it stops. Motorized Treadmill Speed and Workouts The speed is adjustable and many motorized treadmills have workout programs that adjust the speed to give you a varied workout. This pushes you to go faster. The constantly moving belt of a motorized treadmill motivates you to keep up. Costs Manual treadmills are relatively inexpensive, in the $100-200 US range. Motorized treadmills for home use cost from $750-$5000, and generally the more you pay, the better you get. Most motorized treadmills under $1000 have underpowered motors and are less sturdy and have fewer options for adjusting the incline, programmed workouts, etc.
    Dec 01, 2008 | Endurance TF3i Folding Treadmill
    Horizon T70 Motor Control Board Logo
    173 people viewed this question
    Top Horizon Exercise & Fitness Experts
    Electro Med Services...
    Ross Metcalfe
    Ross Metcalfe
    Matt Olenzek
    Matt Olenzek
    Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
