Question about Samsung LN-T4671F 46 in. LCD Television
Tv shuts off when changing source - Samsung LN-T4671F 46 in. LCD Television
Why...TV shuts down when VCR is turned off and Tv will only go on when vcr is on
Because your tv is just a monitor for the vcr, If you've turned the vcr off you need to change the input source on the tv with the remote to anything else you have connected, like a freeview box connected in the hdmi or scart socket
May 10, 2014 | Zenith Televison & Video
Changes "source" by itself and shuts of on own.
Check and replace its main system memory IC.
Aug 30, 2012 | Samsung SlimFit TX-S2783 TV
I attempted to connect a Sony DVD player to a Philips 46 inch screen (Model 46PFL5505D), but only got frustration. At first I had audio, then video then a blank screen. Attempted changing the source, but...
Tries tv unplug,replug it back like about an hour later,that ur reset.If still getting the same result. The tv Tuner signal board is shorted and the causes,that why is shutting down.Tries websites like Shopjimmy.com,Ebay.com to buy a tv Tuner signal board for the replacement.
Dec 27, 2010 | Philips 46PFL5505D 46 in LCD TV
TV shuts off randomly along with lights on front of TV
Check ur power source,like the outlet?Check change the A/C cord?Still happened it ur tv power supply board have short somewhere,must change the whole board.Intermition prob.very hard to determin to troubleshoot,by parts to parts to changes.
Nov 04, 2009 | Samsung HL-S5087W 50" HDTV
Watch TV and it shuts off after 10 min.s
Its the power source of the TV, something is causing a change in the power supply or the TV is overheating...no sure but one of the two...I had the same problem...I think they changing the power source and its back to normal.
Sep 10, 2009 | Televison & Video
How do I get back to the right input? Model TXE2546 25" TV
To change the input source for your TV, you can use your remote to change the video source by following these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button. The current source appears on the TV screen.
  3. Press the TV/Video or Source button repeatedly to cycle through the available sources. Stop when you reach the source you want.
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
Aug 17, 2009 | Samsung TXE2546 25" TV
I signed on last night, asked a couple of questions, but the info sent to my e-mail didn't have anything to do with the questions I asked. Noticing in the forum, several people has the same problem:...
Howdy Mike-d. here, mikedee4@gmail.com
Hi CindyCee,
I have tried to post solutions, but they seem to be too long, so I will have to post more than once to get the info to you.
First part- the "Line-In" Video Source thing many people are having fun with. Try these options from the Samsung FAQs website.:
How Do You Switch Video Sources? spacer.gif Depending on the model TV you have, there are up to four ways to change the video source:
  • Through the on-screen menu controlled by your remote
  • Through the on-screen menu accessed through the Menu button on your TV's front panel
  • Through the TV/Video, TV/Component, or Source button on your remote
  • Through the TV/Video or Source button on the front panel of your TV
Your TV could provide any combination of these methods. Instructions for all the methods are below
Changing the Source Using the On-Screen Menu Controlled By Your Remote To use the on-screen menu of your TV controlled by your remote to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on your remote. The Main Menu appears.
  3. Select Input, and then press the Enter button. The Input menu appears.
  4. Select Source List, and then press the Enter button.
  5. Press the Up or Down arrow button on your remote to select the signal source, and then press the Enter button on your remote.
  6. Press the Exit button on your remote to exit.
Changing the Source Using the On-Screen Menu Accessed Through the Menu Button On The Front Of Your TV To use the on-screen menu of your TV accessed through the Menu button on the front of your TV to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on the front of your TV. The Main Menu appears.
  3. Use the Up or Down Ch button on the TV to select Input, and then press the - or + Vol button. The Input menu appears.
  4. Use the Up or Down Ch button on the TV to select Source List, and then press the - or + Vol button.
  5. Press the Up or Down Ch button on your TV to select the signal source, and then press the - or + Vol button.
  6. Press the Menu button to exit.
Changing the Source Using the TV/Video or Source Button On Your Remote To use your remote to change the video source, follow these steps:
  1. Turn on your TV.
Changing the Source Using the TV/Video or Source Button On The Front Of Your TV To use the TV/Video or Source button on the front panel of your TV to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button on the front of your TV. The current source appears on the TV screen.
Part 2 -next
Jan 20, 2009 | Televison & Video
Panasonic th-42px60u plasma tv not turning on
Power LED on front panel blinks several times, there is a delay, then repeats. After fiddling and fuming (mostly fuming) I found that changing the input signal source allowed the TV to be turned on. When I changed the input signal source back everything was ok.
In other words...
My TV is connected to my PC's video card via an HDMI connector. My card has 2 HDMI connectors. I moved the connector (the part that comes from my computer) from one HDMI out to the other. The screen powered up. When I changed the connector back to the original HDMI out I got my display back.
So yeah, try changing your input signal source. If you're using cable try switching to your Xbox/PS3/whatever, or vice versa. If you only have one possible signal source then I have no clue.
It's almost like the TV doesn't get any signal from the current cable then goes into sleep mode until it gets another signal. My problem had to do with me changing a bunch of sleep/timeout/screensaver settings on my TV/comp.
Hope this helps someone.
Dec 30, 2008 | Panasonic TH-42PX60U Television
No responding to remote
Unplug the TV from the AC Power source (wall socket) for about 10-15mins and then replug and see if it works.
Oct 12, 2008 | Toshiba 42HL67 42 in. LCD Television
Samsung LN-T4671F 46 in. LCD Television Logo
44 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
