Question about Dell Dimension 8250 PC Desktop
Set up password
Have removed battery, and jumper as instructed on the net. no matter what i try i still cant reset bios password. can this be solved??
4 Suggested Answers
  • 7 Answers
SOURCE: remove or reset bios password on dell optiplex
DELL PASSWORD REMOVE 595B, REMOVE ALL DELL 595B D35B BIOS PASSWORD JUST EMAIL ME YOUR SERVICE TAG TO MARCUSPWP@LIVE.CO.UK AND I WILL SEND YOUR MASTER CODE £10 Via Paypal Only any questions email me 100% guarenteed or your money back
Posted on Apr 17, 2010
  • 10 Answers
SOURCE: i need help wih the
If you happen to lost windows os password, you could go into safe mode (F8 when booting up) to retrieve windows password when you did not remember user account password, but if you forgot administrator passwords, there is no way to change it, you need to use a software program to recover administrator password. Yesterday evening, I forgot my Windows admin password. Last, I successfully recover my Windows password by using Windows Password Seeker. It's worth trying.
http://www.passwordseeker.com
Posted on Dec 27, 2011
  • 62 Answers
SOURCE: how to replace the password jumper
make a wire bridge and short the terminals it should reset the bios to no password
Posted on Feb 25, 2012
Dell d340. need to enter admin password in bios to reorder boot sequence to accept usb first - its locked and i cant remember password. tried removing cmos battery and replacing but no good. help!
Try the backdoor password Dell
With a PSWD Reset Jumper Step 1Open the access panel to the password reset jumper if your Dell laptop has one. Consult your manual for the access panel's location. Some access panels have a tab you slide, while others are held in place with a screw.
Step 2Pry the plastic cover off the reset jumper with your fingernail. The reset jumper is a small pin port labeled "PSWD" with three pins. Put the plastic back onto the jumper over pin 1 and 2 instead of 2 and 3. Wait 90 seconds.
Step 3Pry the plastic off the reset jumper again and place it back onto the number 2 and 3 pins. Turn the laptop on. Repeat step 2 if the password is still present. Leave the plastic clip on pins 1 and 2 for a longer duration than last time.
Without a PSWD Reset Jumper Step 1Locate the reserve battery, also known as the CMOS battery, if your Dell laptop is not equipped with a password reset jumper. The CMOS battery's location varies among Dell laptop models. Consult your manual for the battery's location on your specific Dell laptop model. Many Dell reserve batteries are located underneath the main laptop battery. Remove the main battery and look for a sticker under it with instructions on removing the secondary CMOS battery.
Step 2Remove your Dell's reserve battery per the instruction manual or sticker located under the main battery. Removing the reserve battery resets the laptop's BIOS password. Wait 90 seconds, then replace the reserve battery. Reconnect the main battery.
Step 3Press the "Power" button to turn the laptop on.
Here is some youtube video with your problem:
http://www.youtube.com/results?search_query=dell+bios+password+reset+laptop&oq=dell+bios+password+reset+laptop&gs_l=youtube.12...2937.2937.0.5179.1.1.0.0.0.0.44.44.1.1.0...0.0...1ac.2.rXrXigbVpXM
Try also to call dell support in your country
They will be glad to help you out.
Good luck
Nov 08, 2012 | Dell Computers & Internet
Tip
How to reset or remove BIOS password
There are four common categories of solutions to remove or reset a BIOS password and here are the details on how to go about resetting your BIOS password.<br /> <br /><b>Manufacturer Backdoor BIOS Password</b><br /><br />Most of the BIOS makers have set a backdoor password on the older computer models. That is the master password for BIOS. To reset BIOS passwords first you need to check the manufacturer of your computer's BIOS. Most computers have BIOS include AMI, IBM, Award, and Phoenix. These are the most common BIOS. You can unlock your locked BIOS using this master password. It works, no matter what the user sets the password to. Many popular computer and laptop manufacturers such as HP and DELL lock the BIOS because they want to protect their machine's most sensitive areas (those areas which have warranty) from their customers. These passwords are usually used by computer technicians for testing and repairing. <br /><br /><b>Reset the jumper that holds the password<br /></b><br />Open the computer and locate on the motherboard the BIOS password jumper. The jumper is usually jumper 1 and often labeled as PSWD, PWD, CLRPWD, CLEAR, JCMOS1, CLR, CLEAR CMOS, PASSWD, or PASSWORD. Normally you would have 3 pins and to reset the password you just need to put the jumper on the 2 and 3 pins leaving pin 1 empty. After you move the jumper, turn the computer on to clear the password, then once password removed turn it off and put the jumper back to its original position.<br /><br /><b>Removing the CMOS Battery to reset the BIOS to default</b><br /><br />Switch off your computer, and open up the case. You'll see a circular metallic silver item on motherboard. This is called CMOS Battery. Remove it carefully, and leave it out for about 2 minutes. This act will remove the CMOS memory which contains BIOS password. Set the CMOS battery back and switch on the computer. Restore the CMOS configuration as default. Your BIOS password has been cleared now. <br /><br /><b>Using third party software utility to reset BIOS password</b><br /><br />To reset BIOS you can use third party software like Kill CMOS which wipes out CMOS, or CmosPwd which is a BIOS utility. Hiren's Boot CD has a few programs including the above two that will help you to reset the password. Here is a link to Hirens Boot CD website <a href="http://www.hirensbootcd.org/">http://www.hirensbootcd.org/</a>. To download the latest version, click on the Download link on the left side and go to the last page. You will need a CD writer to put the content on a blank CD.
on Dec 12, 2010 | Computers & Internet
I have a Lenova laptop and a intel MB I am having a problem. Trying to login but the supervisor password won't let me in no matter what i try Lenova G550 2958
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Aug 13, 2011 | Intel Motherboard
Cant boot up my toshiba lap top. it comes up asking for the BIOS password then shuts down after 3 tries! have tried all the F keys, shift key and removing battery!
the only way to get past the bios password is to open up the case and try to find a jumper on the main board that says bios reset, close that jumper and turn on the computer for one boot, power down and remove the jumper, after that the bios should be reset(bios passwords are usually set as a security measure that is not easy for the average user to bypass such as a windows one that can be removed by formatting the drive and reinstalling windows)
Jan 22, 2011 | Toshiba Portege S100-S1133 Notebook
Hello : my problem is i have laptop acer model 5230z : i cant access to the bios becuas is encrypted in passwoed and i try all way that found in web put is no result thank you i hope be help me
To reset BIOS you can use third party software like Kill CMOS which wipes out CMOS, or CmosPwd which is a BIOS utility. Hiren's Boot CD has a few programs including the above two that will help you to reset the password. Here is a link to Hirens Boot CD website http://www.hirensbootcd.org/. To download the latest version, click on the Download link on the left side and go to the last page. You will need a CD writer to put the content on a blank CD.
Please let me know whether this works or not.
Dec 26, 2010 | Computers & Internet
Reset emachine bios password
this is very simple to reset emachine bios password
simple open cabinet of cpu then remove litheum battery of emachie. restart the machiche with battery the password will reset.
Enjoy..
May 06, 2010 | Computers & Internet
Can anyone help me on how to reset the Bios password to default on an HP Compaq 6710b Laptop? I have an HP Compaq 6710b Laptop. It is booting but it cant go beyond bios boot and i cant enter setup as it is...
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Oct 16, 2009 | HP Smart Buy Notebook
Please i need your help
hello, open the case unplug the comuter, take out the litium battery,looks like a coin, near that a three pin header, with a jumper on move it to the other 2 pins..count to twenty-put it back the way it was-put the battery back in-plug it in-and you should be able to change the boot order. you may have to set other bios options. this is the way to reset the passwords, this resets it to default. hope this helps! goodluck!
Mar 15, 2009 | Acer Computers & Internet
Acer 3089
hmm which password ??? is it the bios password or the windows password.. Any way I will give you solutions for both
THE BIOS PASSWORD
1.) unplug the computer system
2.) remove the side panel
now you have two option
OPTION 1
3.) locate the jumper jp1 or jcmos1 you can use your manual for a refrence its a 3 pin jumper located cloase to the battery
4.) the jumper is currently on 1 and 2 , set it to 2 and 3 wait a few seconds and set it back to 1 and 2
5.) THATS IT BIOS PASSWORD RESET
6.) boot system enter setup and load optamised defaults.
7. save and exit setup
OPTION 2
incase you cant find the jumper
3.)remove memory
4.)remove the battery
5.)press the power button 5 times to empty any charged capicators
6.)replace battery and memory
7.)boot ystem enter bios load optimised defaults , save and exit
TO RESET WINDOWS PASSWORD
1.) dowload hirens boot cd from here
www.phazeddl.com
you will need to search hirens when you go to the site
2.)burn off cd
3.) boot from cd
4.) use the on screen menu to fine windows password reset tools,
5.) choose the appiorate one and follow instructions to change or reset password..
THATS IT WINDOWS PASSWORD RESET..
let me know if you need any more help good luck
Jan 10, 2008 | Acer Aspire L100 PC Desktop
Dell Dimension 8250 PC Desktop Logo
19 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
