Question about Kenmore Front Load Washer
Kenmore 417.4112 beeps when push start
Pau error code
3 Suggested Answers
SOURCE: Kenmore Oasis no error code keeps beeping low -loud
Just bought a Kenmore Oasis He Canyon Capacity about a year and a half, everytime i go and push a different button it takes me to the Clean Washer light. I have to fool around with it for awhile before i can get it to the one i'm wanting, and after going through all of that problem, it beeps about 2 time every 20 second through the cycle.
Posted on Mar 21, 2008
blueextc3221
  • 15935 Answers
SOURCE: kenmore frontload washer wont start no beep or error code
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 23, 2010
How to fix a Kenmore dryer model 417.8112 with error code pau
Is your washer still full of water? You may have something in the drain motor, that would also cause the error code 41 issue. I'd first check for an obstruction in the drain motor itself. Its very easy to get access to the drain motor. Lots of times I see these get clogged with stuff ...
Jul 27, 2014 | Kenmore Dryers
Kenmore dryer error code pau
Stopped up vent is the most likely cause for this error code. .
Code saids pau
If the PAU error does not clear after properly restarting the washing machine cycle, push "Cancel," then disconnect the power cord. Wait a few minutes and restore power to see if the error code goes away. If not, the control board may need to be replaced.
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
Kenmore 970
Do you have the customer user manual indicating what the Error PAU mean? I do not have my Error code log at hand as i read your post sorry. Provide as much info to get others to help you.
Most Error codes will lock out you machine, for safety reasons..so it wont start.
Oct 16, 2013 | Dryers
Keeps saying PAU
The PAU, or pause, error usually means that the washing machine cycle was interrupted and was not restarted properly. If you try to modify the cycle or start a new one before the first cycle is complete, the PAU error will appear on the display. If the washer was stopped midcycle and not restarted, the cycle must be canceled or completed before a new selection can be made. Push "Start/Pause" to allow the current cycle to finish before making a new selection, or push "Cancel" to stop the current cycle
Oct 15, 2012 | Frigidaire Washing Machines
Kenmore front load washer error code E 10 - washer stops and beeps periodically and needs to have start button pushed again to complete cycle. Seems to happen one minute into cycle and then a coupleof...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Jan 11, 2010 | Kenmore HE2 Plus Front Load Washer
Frigidaire ATFB7000ES0 ERR PAU 3 beeps
An E-45 code is a control board issue & needs to be replaced
Dec 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore electric built-in oven control panel beeping
Try this first!
The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. If that does not work, repalce the defective parts yourself. You can do it for about 30% of what a repair company would charge. it's either got to be 1. Control panel 2. Relay panel. Good luck!!!
Aug 08, 2008 | Kenmore 42161 / 42169 Electric Single Oven
We had the same problem. F7 error code and beeping. We turned off at the breaker- left it off for hours turned it back on and still f7 and beeping. We call repairman to come out and he removed the cover on control panel (3 screws on bottom of controll panel and it pops off). He unplugged the ribbon keypad connection - Cleaned the ends with a pencil eraser and said it is fixed and we would not have a problem.
Well, that was a fast way to spend 60 bucks but it has been a week and the oven has been great. No more beeps or error codes. SAVE YOUR MONEY DO IT YOURSELF!
Oct 08, 2007 | Ovens
Kenmore Front Load Washer Logo
119 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
