Question about Dynex RC-401-0A
Power Red light is on but when I press power on remote, it blinks and stays red. Just moved and can't find the manual
2 Suggested Answers
  • 8457 Answers
SOURCE: tv will not come on
Ur tv the power supply board is dead.Take the tv aparts,the board where the a/c power cord plug into it.That the power supply board,replaced it,ur power problems will be solved.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Jun 17, 2010
How do i get the code to program a jvc tv wth my universal remoteserrial # rc24922-c1122
Do a code search method as follows.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Dec 26, 2014 | Universal Remote Control Televison & Video
My toshiba TP48E60 model projection tv won' turn on, power light just blinks
Blinking of power LED are fault indications. Count the number of blinks occur at one time switch on. For this number, you can get an idea about the faulty section circuit inside it. It will make troubleshooting much narrower. If you wish to get more details about the blinking codes, check this link. Pull up older posts there.
Mar 08, 2013 | Televison & Video
How can I get my onkyo remote control (RC-693M) to control my Sony LCD tv?
Manual says: 1. While holding down the REMOTE MODE button for the mode in which you want to use the command, press the [ON] button. *** Hold both buttons down for 3-4 seconds *** 2. Press the button you want to learn the new command 3. Point the remote controllers at each other, about 2-6 inches apart, and then press and hold the button whose command you want to learn until the Remote indicator flashes. *** Hold them level with each other, 2-3 inches apart, and don't move them at ALL while you press the button on the old remote *** 4. To learn more commands, repeat steps 2 and 3. Press any REMOTE MODE button when you've finished. *** If the command was learned correctly, the remote indicator will flash *SLOWLY* twice - about a 1 second blink, and the red light will remain on. If the command was NOT learned correctly, it will blink twice *QUICKLY* - about .5 seconds, and the red light will go off. *** If the red light stays on, you're golden - keep going until you get to a button that flashes red quick and the light goes off. Some of the buttons I programmed took 6-7 tries in exactly the same position to learn.
Oct 09, 2012 | Onkyo TX-SR705 Receiver
Cant progam brookstone giant remote to phillips lcd tv
Three digit universal remote code for Philips are:
003/ 004/ 006/ 008/ 062/ 068/ 069/ 074/ 075/ 076/ 086/ 087/ 089/ 133/ 163/ 183/ 184/ 205/ 206/ 207/ 208/ 212/ 213
Four digit Codes are:
0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
  5. Code Search
    Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Jun 13, 2012 | Universal Remote Control Televison & Video
Lost remote-have universal remote
You can use any universal remote for any Electronics device
Here you can find almost all the Universal remote codes
http://kbase.x10.com/wiki/Universal_Remote_Code_List
you can also manually find it follow your universal remote control user guide If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
Manually turn on the device (TV, VCR, etc.) to be controlled. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit. Press and release MUTE to install the code. The indicator light goes off.
Mar 05, 2011 | Televison & Video
I lost the code to the ge universal remote jc024
hi...
From this website you can get the for your remote
http://www.jascoproducts.com/support/universal-remote-codes.asp
follow the steps to set up the remote
Method 1
Step 1: Press and hold the "SETUP" button until the red indicator stays on, then release.
Step 2: Press and release the desired Mode button (VCR, TV etc.). The red indicator will blink, then stays lit.
Step 3: Enter the 4 digit code for your device. After a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes!
Step 4: With your device on, press "CHANNEL UP" or "CHANNEL DOWN." If the device responds, no further programming is required. If some buttons do not operate your device, try one of the other codes for your brand. Note, when all codes have been searched the red indicator flashes rapidly for 3 seconds.
Code Search instructions
If your device does not respond to any of the codes listed with your equipment, or your brand is not listed, try the following steps:
Step 1: Manually turn on the device to be controlled.
Step 2: Press and hold the "SETUP" button until the red indicator stays on, then release.
Step 3: Press and release the desired Mode button (VCR, TV etc.). The red indicator will blink once, then stays on.
Step 4: Press the "CHANNEL UP" button repeatedly until the device to be controlled changes channel. The red indicator will blink, then stays lit.
Step 5: Press and release "MUTE" button to install the code. The indicator light goes off.
Jul 20, 2010 | Universal Remote Control GE174Universal...
Lost owners manual
I do not believe this is available on-line, but have some info that might help you use the remote.
To Search For A Code:
  1. Manually turn on device to be controlled.
  2. Press and hold the "Code Search" button until the red indicator light stays on, then release it.
  3. Press and quickly release the desired ode button (TV, VCR, etc.). The red indicator light should blink once.
  4. Press the "Channel Up" button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator light should blink off with each button press. If you accidentally overshoot the required code, press the "Channel Down" button to backtrack through the library until the device changes channel. Pressing "Channel Up" changes direction again.
  5. Press and release "Mute" button to install the code.
To Identify The Code That Was Found:
  1. Press and hold the "Code Search" button until the red indicator stays on. Release the "Code Search" button.
  2. Press and release the desired mode button (TV, VCR, etc.). The red indicator light blinks and then stays on.
  3. Press and release the "Code Search" button. The red indicator light goes off.
  4. To find the first digit for the code stored under the mode key pressed in "Step 2" press each numeric key from 1-9 in turn. When the red indicator light blinks off, the number you pressed is the first digit for the code you are searching for.
  5. To find the second digit, repeat "Step 4," this time when the red indicator light blinks off, this is the second digit in your number.
  6. Repeat again for the third digit in your code number.
I hope this helps out,
Chris
Dec 23, 2008 | Philips PH-DVD5 Remote Control
RC24912 - D
1 manually turn on the device (tv, vcr. etc) to be controlled
2.Press and hold the setup button until red indicator stays on, then release the Setup button.
3. press and quickly release the desired device button (tv vcr etc). the red indicator blinks off once
4. Enter the following codes then press the channel up button and if anything happens the light will go off.
Jenson TV codes 0004, 0009, 0133
If you can't get any of these to work then you will have to do the exhausting manual version.
CODE SEARCH FOR THE RM24912
4. press the channel-up button repeatedly (up to 300 times) until the device to be controlled changes. The red indicator blinks off with each button press.
5. press and release the mute button to install the code. Then the light will go off.
Jan 19, 2008 | GE RM24912 Universal Remote Control
How do i!
make sure the batteries are good and installed correctly. turn on device(manually) press and hold (setup) button until the red indicator stays on. then release the set up button. press and release device button(tv,vcr ect) the red indicator light will blink, then stay lit. press channel up until the device changes channel.The red indicator light blinks and stays lit.if you over shoot the code required press channel down to back track. now press and release the mute button to lock in the code.
Jan 13, 2007 | GE RM24912 Universal Remote Control
Dynex RC-401-0A Logo
32 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
