Question about Dehumidifiers
After 30-40 second on it will stop working and make beep noise
I bought this Goldair dehumidifier GD 420 second hand.When I turn it on it will running about 30 - 40 second, it will cut off and make beep noise till I cut the power.Any suggestions what wrong? I also need the Instruction/manual for this. Do someone can help me with? Thanks for your help.
  • 1462 Answers
SOURCE: no instructions
only two fan speed - fast or slows. use fast humidity - cuts out appliance when required humidity is reached. set it about half way note that is f bucket if full, then a float switch will cut out the appliance
Posted on May 22, 2007
bozcro
  • 867 Answers
SOURCE: Kenmore Dehumidifier fan runs, compressor buzzes and quits
sounds like the compressor is seized.
Posted on Aug 01, 2009
  • 4736 Answers
SOURCE: Bought a Maytag 65 pint
You can find the manual and the parts online a Sears Parts Direct. However, when you enter the model number, drop the *A off the number.
FYI - This unit was made for Maytag by Fedders. And they make one of their own, with the same model number.
Hope this helps you.
Posted on Apr 01, 2011
Testimonial: "Thank you for your help and info. "
  • 4736 Answers
SOURCE: I just purchased a second-hand LG 45 pint
Jenifay, take good care of your dehumidifier and do all the routine maintenance that is recommended in the Owners Manual. As this model has been discontinued.
The following link will take you to LG's Knowledge Base. On the right of the page, you will see Dehumidifier Manual English. Click on that, and you can download and print the manual for a 45 pint LHD4SEL Dehumidifier.
Since I was able to get you a free manual, would you be kind enough to rate my response to you?
Thanks.
Posted on Apr 27, 2011
Testimonial: "I received a response within minutes and it was exactly what I needed!"
  • 4736 Answers
SOURCE: Dehumidifier still runs, blows air,
It may not need repair as, there are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have an analog unit
(no LED screen), turn the humidity extraction knob to Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helps you to troubleshoot & solve the problem without have to make any repairs.
Thanks for choosing FixYa.
Posted on Aug 19, 2011
I bought a cool works dehumidifier and have no manual for it.It is mdl-50aeni-ba9 serial no.:d205023130212c06200635. Could i have one sent to me please.
no
not from fixya site as we do not have any paper work for anything
get it from manufacturer web site on google
Nov 26, 2016 | Dehumidifiers
I just bought a second hand DEM 10 DEHUMIDIFIER. After starting it up (on every setting) the motor cuts out after a few minutes. All filters are clean. Please help. Kind regards Scott
assuming you have ck'd the water collection bucket full switch for proper seating , im sorry to say that short cycling on compressors are a sure sign of low gas pressure , and no its not easy to add more
Nov 20, 2016 | Dehumidifiers
When I press the power on button, why does it just beep and won't turn on?
There is an interlock that shuts down the dehumidifier when the bucket is not in place or not seated correctly. There also may be a "bucket full" sensor that shuts it down mistakenly. Another possibility is that the compressor has failed.
Dec 18, 2015 | Dehumidifiers
Goldair dehumidifier GD-2020 has stopped working? 'CONT' light on front panel flashing and now cannot get to operate?
cont button just means continuous run mode . the power light is lit , the full light is out . try reseating the water catch bucket a few times , most machines have a safety that wont allow the thing to operate if bucket isn't just perfect in its slot (you don't want water on your floor )
May 23, 2015 | Dehumidifiers
I have a Frigidaire 30 pint dehumidifier, the fan is running, but I do not hear the compressor. There was a lot of dog hair inside when I bought it second hand. Did I get screwed?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 04, 2011 | Frigidaire FDL50R1 Dehumidifier
BOUGHT THIS SECOND HAND AND IS NOT PULLING ANY MOISTURE OUT OF THE AIR. ALSO LOOKING FOR A MANUAL
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Mar 14, 2011 | Maytag M3DH30B2A Dehumidifier
My HDN455 45 pint Dehumidifier did not work
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 17, 2009 | Haier HDN455E 45 Pint Dehumidifier...
Dehumidifier not collecting moisture
Normal 0 When you push the power button, the blower fan comes on. In a few minutes you should hear a second "click"--that is your compressor starting. Do you hear that second click?
Jan 31, 2009 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
82 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
