Question about Boston Acoustics Recepter Radio(r) HD
Reset boston cd player - Boston Acoustics Recepter Radio(r) HD
I have a 2005 Boston Accoustics micro cd/radio. My elderly father has put a cd into the unit which is stuck. I think he forced it in. What do you suggest? I can see the CD but can't grab it.
You'll have to take the cover off to expose the CD mechanism and retrieve the cd. You may have to dismantle part of the player to get the CD out.
Oct 24, 2016 | Cars & Trucks
My boston innovative products protable dvd player
is power supply problem, replace transformer
Feb 20, 2010 | Televison & Video
Can the Boston BA 7900 be converter to use with TV or DVD Player?
Yes, but so far I can only get the 2 front speakers and subwoofer to work.
You need a wire that converts a headphone-style jack (like the green one with the Boston speakers) into a red and white AV connection (typical CD/DVD, etc. connection). I've had this connector for a long time and I'm guessing it's under $15. You connect the green Boston speaker connection to the converter end (mine connects to the back end of the headphone-jack (which has a hole for the connection) and the red/white AV connectors to your TV.
I'd been trying to solve the problem too for a long time. Only problem is that I can't get all 5 speakers to work because I think the red/white connector doesn't work with all 5 speakers. I have yet to figure out how to make all 5 work, but the system gives great sound anyway. You will have something like a 5.1 system with your computer speakers, the Boston speakers and subwoofers.
One more issue is that if you connect it directly to the TV, you have to manually turn the Boston speakers on and off.
Nov 06, 2009 | Boston Acoustics BA7900 Computer Speakers
Can you help? Stereo does not take in any discs
I think you have a mechanical problem with the load and eject mechanism. Either a spring or a gear has popped out of place or may be a switch got stuck and malfunction. If you are mechanical incline just open the unit up and look for anything that look out of place, becareful and remember what goes where so you can put it back in order. That is how I fix mechanical problem. Good luck.
Apr 01, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Jensen VM9511TS : Doesn't take in discs
It sounds like a mechanical error. It's not a quick fix. You (or more likely a repair shop) would have to pull the transport and reallign a bunch of parts and possibly resurface the rollers. It's a GIANT pain in the @$$.
External speakers do not play
It is not an issue with the speakers or the sound card as you get sound in media player and also while playing cd's.
It could be the volume settings on the player tht the websites use to play the audio or the video,
Jan 30, 2008 | Neovo E-19A 19" LCD Monitor
Car Audio & Video Logo
29 people viewed this question
Top Boston Acoustics Car Audio & Video Experts
xxxxxx xxx
Are you a Boston Acoustics Car Audio and Video Expert? Answer questions, earn points and help others
