Question about YouTube Videos
Kenmore dryer 70 series wont start - YouTube Videos
My Kenmore Dryer 70 series wont start when I press the start button.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Feb 04, 2011 | Kenmore Dryers
I have a Kenmore Series 70 dryer wont start, just hums
Check for correct voltage at the terminal block on the back of the dryer, where the power cord attaches to the dryer.You should be getting 220/240 volts, check by way of a voltage tester.
If the voltage is correct, then could be the motor capacitor or the motor itself, or start button?
Good Luck !
Feb 07, 2010 | Kenmore 63942 Dryer
Kenmore 70 series dryer has power just wont start when push the button is it the start switch?
could be the start switch or it could be the safety switch in the bottem of the dryer that turn the dryer off incase the belt brakes.
Oct 02, 2009 | Kenmore 63942 Dryer
Dryer wont start.
can you hear the motor or does the unit humm or vibrate when it is turned on
if yes then have a look at the belt
if not it's time sor a service call
Aug 04, 2009 | Kenmore 700 6972 Dryer
Kenmore 70 series dryer wont start. I was going to replace the start button but cannot figure out how to get it off with out breaking stuff. do i need to pull all the panels off?
There is a switch that sits behind that start button. To get to it, unplug the dryer and pull it away from the wall. There is a metal cover that runs along the upper rear side of the dryer -- remove that and you will see the switch behind that button. You can disconnect the wires going to it (you may want to mark them) and pull the button off of the front of the switch. Then pull that plastic tab up and the switch will pop out if you twist it clockwise.
May 29, 2009 | Kenmore 60172 Electric Commercial Dryer
TUMBLE DRYER SUDDENLY STOPPED WORKING. ALL LIGHTS FULLY FUNCTIONAL BUT THE PROGRAM WON'T START WHEN START BUTTON PUSHED. RED LIGHT IS FLASHING ON START BUTTON. mODEL WTE6920
I have a kenmore dryer, bought used, and it was working good but it now wont turn on. The light inside comes on when the door is opened, but no matter what the setting, it wont start. It's the Kenmore 70 series, front loading electric dryer. Is there a fuse or reset button I can try?
Sep 15, 2008 | Dryers
YouTube Videos Logo
19 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
LP
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
