Cars & Trucks Logo
a
ann fitch Posted on Feb 11, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sloppy loose steering
2007 saturn vue, i slid on ice into curb hit right front tire,they replaced front reflex struts, rear reflex strut, labor for R&I or R&R front shock&/or stut assembly-both and same on rear, also cam and bot kit, wheel .. i then had 4 new tires place. it was stiff steering for a week, now loose and it seems front left tires wobble.
keith29717
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 72 Answers
  • Posted on Feb 11, 2014
keith29717
Expert
Level 2:
New Friend:
Greenhorn:
Answers
72
Questions
0
Helped
21845
Points
216
First check the lug nuts... second, jack the vehicle up one wheel at a time move it every possible way while looking for anything behind it that might be loose.
3 Related Answers
dennymulford
Dennis Mulford
  • 1055 Answers
  • Posted on Feb 24, 2009
SOURCE: in 4 wheel drive front wheels wobble bad
i had the same problem,i endend up changing the hub bearings and ball joints and front u joints the main problem was the hub bearings
Anonymous
  • 564 Answers
  • Posted on Apr 28, 2010
SOURCE: starting at 65 mph steering wheel shakes. 4 new
could have bent rim,,even thow,,balance was done,,depends on how mush weight was used to balance?? rotate tires from frt to rear,,see if problem still exits,,ck bearing play,,hoped it helped
Anonymous
  • Posted on Jul 15, 2011
SOURCE: 99 ford expedition ,changed
Give some more details of the problem.
1helpful
2006 Saturn Vue--Rear hatch does not stay up--ouch!
Hi
Just buy new and replace1Pair Rear Liftgate Lift Supports Shocks Struts
https://www.ebay.com/itm/2-New-Rear-Liftgate-Tailgate-Hatch-Lift-Supports-Struts-For-Saturn-Vue-/182121013015
Thanks
Saturn vue 2008 shakes when driving over 70
A few possibilities (in order of probability):
  1. One or more tires out of balance (by far, most likely);
  2. Bad front suspension or steering component;
  3. Worn strut(s); or
  4. One or more bad wheel bearings.
Steering not responding well
Automobiles: 2006-2007 Ford Five Hundred 2WD & AWD, Montego
If the steering is getting a little hard to turn at low speeds, this would indicate a loss of Power Steering, and the steering is reverting to "Non-Power" steering, just like the days of the Ford Model T or Model A. Loss of power steering is usually caused by low level of PSF (Power Steering Fluid).
So first on my checklist would be checking the PSF level in the reservoir.
Also bleed (air) from PS (Power Steering) pump.
The Ford Five Hundred has front MacPherson struts, so check these for leakage (of the dampening fluid in the strut cylinder), or breakage of their coil springs.
These springs can actually weaken over time, but this is impossible to see - you must "feel" it by bouncing the strut up & down - preferably with your hands on the top of the strut tower in the engine compartment (rather than on the exterior finish).
If the MacPherson struts have weak/broken springs, these components are not separately serviceable, and the strut would have to be replaced as a unit (and preferably both left/right to maintain smooth/even ride).
The Five Hundred also has rear shock absorbers with springs - check for leaks/breakage/weakness here too.
Steering losing responsiveness/wander - checklist
Priority Action Part Type Cause
1 Inspect Rack & Pinion - Center Wear From Internal Fluid Leaking Around The Rack Piston.
2 Inspect Steering Stabilizer Bracket - Loose or Broken Steering Stabilizer Bracket.
3 Inspect Front Lower Control Arm - Front Lower Control Arm loose/missing bolt(s)
4 Inspect Front Lower Ball Joints - Front Lower Ball Joint(s) Worn/Loose
5 Inspect Front Upper Ball Joints -Front Upper Ball Joint(s) Worn/Loose
6 Inspect Tire Pressure - Tire Pressure should be 35 PSI for the Five Hundred and Montego's P225/55R18 OEM (Original Equipment Manufacturer) tires.
Harsh ride - checklist
1 Inspect Rear Shock/Strut - Shocks/Strut failing/leaking.
2 Inspect Front Shock/Strut - Shocks/Strut failing/leaking.
3 Inspect Coil Spring - Incorrect Coil Spring Selection or Installation.
4 Inspect Coil Spring - Coil Spring broken.
4helpful
I have a noise coming from the left side front wheel are. It is a rattle - took it to a local Toyota dealership who said it was the steering RAC well that was a $1000 mistake because the noise did not...
1) Take car to non dealer shops willing to give FREE opinion
2) Not likely you have a shock in Driver Front wheel, more likely a strut. Not likely strut needs to be replaced, but strut has a STRUT MOUNT (3 bolts of which can be seen when opening your hood) below this it is connected to STRUT BEARING which below it connects to UPPER SEAT OF STRUT or SPRING INSULATOR, that if loose will rattle. Usually, shops will not tighten, because to tighten is same labor as replace the parts. (Since you already dropped $1000 on ToyotaDealer, ask them to tighten FOR FREE since rattle is still there.)
3) There is a part called a "link," connects strut to stablizer bar, that if bushings are bad will rattle.
4) If stabilizer bar bushing(s) bad, will rattle early on but eventually clunking
5) Bad ball joint or tie rod can rattle as well
Never permit any shop to do expensive work on your car w/o first getting a second opinion somewhere else first. Do not tell second shop that you are there for a second opinion.
Shaking steering wheel at highway speed, no braking
1) Bad tire in front, bad tires in front, verify inflation of tires
2) Wheel alignment may be out
3) Front suspension parts (mentioned several above)
Highway speed to suddenly braking shakes steering wheel
1) Front brake rotors need to be inspected for warping
2) Test calipers on empty road at 40 mph, going straight on very LEVEL ROAD, hit brake pedal SOMEWHAT hard while barely touching steering wheel. If car jerks to one side, instead of braking straight on, you may have a caliper, ABS, or brake fluid pressure regulator off.
3) If brake rotors are warped, may as well replace front brake pads at same moment. Use ceramic.
4) When you drive on VERY LEVEL road on highway, steering wheel must be centered, let go lightly of steering wheel. Did car stay in middle of lane? No? Get a 4-wheel alignment.
I slid in the winter with my passenger fron tire banginging against the curb. a noise started in that area. I was told that my rotor was loose on my 2007 pontiac g6. does that sound right?
The rotor is tight up, by 5 lug nuts. Tight up to 75 ft/lbs each lug nut in right sequence. I hope this will help, but you must have a bad knuckle bearing too. This can be repaired by changing the spindle only, but you have to remove the knuckle from, front suspension, and separate it from the strut.
1helpful
When is the recommended mileage to change the shocks/struts on my 2007 Honda Pilot?...currently about 45k miles...
HONDA Pilot struts do not require replace at specific mileage intervals or maintenance. Your vehicle’s struts should be checked annually. Struts wear out slowly and you may not notice gradual losses in ride comfort, handling and control. Excessive bouncing, rocking back and forth, drifting or nose- diving while braking, swaying, or cupping wear on the tires are some signs that your vehicle may have worn Struts. If you are purchasing new Struts for your HONDA Pilot consider premium Struts. Upgrading your struts usually improves overall ride quality, control and handling. Warn struts can increase the wear of tires, ball joints, steering linkage, springs and C.V. joints. Some original struts may be getting weak after 40,000 or 50,000 miles.
Failure symptoms: Vehicle continues to bounce after hitting bumps in roadway. Front suspension dives severely during hard braking. Swaying or rolling when at higher speeds. Signs of oil leaking from the shock rod seal. Clunking and banging noises coming from the strut may be signs of internal shock failure or strut mounts.
2helpful
Back right wheel tilts inward. strut broke or bent?
It could be a damaged strut but if it hit a curb it would more likely tilt out. Some of those had an eccentric bolt that allowed adjustment of the camber. Have a tire shop look at it and determine if a bolt has come loose and allowed it to slip.
2helpful
3answers
When i hit the brakes or go over 60 miles the wheels will start to shake
It sounds like you may have more than one problem here. First I would investigate Front End Alignment and ALL Steering/Suspension components for excessive wear and/or looseness. Second I would Inspect the Brake Rotors and Pads for uneven wear. Third I would check the Tires for uneven wear and balance. Many things can cause these symptoms: Worn out Ball Joints, defective Shock Absorbers/Struts. Worn out Tie Rod Ends, Idler Arm, even the Steering Gear Box can be part of the problem. Brake Rotors and Tires can be out of Balance with either one causing the problem over 60 MPH. I strongly suggest having your vehicle inspected by an ASE Certified Front End and Brake specialist immediately. It is very dangerous to drive a vehicle with these symptoms.
3answers
Steering Binding
Is sound like u need to do a front wheels direction.take your machine to the closer garage.
Top Saturn Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Saturn Expert? Answer questions, earn points and help others
