Question about Grundig G6 Aviator Radio Buzz Aldrin Edition
Shuts off a short time after I turn on a station
Lost bothe picture and sound when watching. A bright scene in the show happened and all went dead, thought it was the station so checked others and nothing. Any ideas?
The Audio/Video section seems to have short circuit or if there is overdrive experienced this section would Shut-Off automatically switch-off and Switch-on after a time gap
Jun 26, 2015 | LG 42LE5400 Widescreen 42 Class 42.0...
Tip
Fix the 80010514 error on your PS3
If your Play Station 3 (PS3) gets the 80010514 error somewhere, you can try this to resolve the problem:
1. Make sure that the power indicator on the Play Station 3 system is solid red. To do this, press and hold the power button until the PS3 beeps and the light blinks. Once the light has turned solid red, turn the power switch in the back off.
2. Turn the switch back on, then press and hold the power button.
3. Keep holding the power button even after you hear a short beep after 5 seconds.
4. After 10 seconds, you will hear another short beep and the system will shut down (release the button at this point).
5. Press and hold the power button again.
6. Continue holding the power button even after you hear a short beep after 5 seconds.
7. Release the button when two short beeps are emitted after 7 seconds.
8. As instructed by the on-screen message, plug in the controller and press the PS button
9. Select restore Play Station 3 system.
This should not affect any of your save games, demos, etc. but just to be safe you might want to back up to an external USB hard drive.
To backup saves, go to the Play Station 3 Save Data Utility, select the save you wish to copy and hit the Triangle button. Copy should come up as one of the options. If it does not then the save game is copyright protected and can’t be copied. If you can copy it, make sure you have a USB drive attached and copy it to that.
on Feb 02, 2010 | Video Game Consoles & Games
My 2007 chrysler 300 radio makes a popping noise a d then sound stops after a while turn radio back on and sound is working
the speakers maybe blown out, there mite be a short in the system, the antenna maybe loose or have short in the connector, there a short in an electronic component in the radio, it also could be a grounding issue, when you hit a bump it looses it connection or the unit has short in the receiver and it cuts out the signal in the radio station, losing power some where, if i was you go to stereo shop or buy new radio, all the money you would spend looking or trying to repair would cost you a lot of money, troubleshooting, radio, speakers, wiring, shop supples, no warranty after wards,
good luck
Apr 21, 2015 | 2007 Chrysler 300
I have a 6 station orbit timer and I have problem with station 2 odd days coming on again after station 4 odd days the time is set to come on at 6 am and run for 60 min an10 min after it shuts off to start...
I am somewhat confused about your station numbers. How many stations do you have? What is Ihappening with stations 1, 3, 5, 6?
Regardless, this is probably what is happening.
No matter how many stations you have, YOU ONLY PUT IN ONE START TIME. That one start time begins the cycle that starts with station 1 and proceeds to the other stations based on your station RUN times.
If you have one start time of 6:00 am, and a run time of 60 minutes for each zone, then
At 6:00 am station 1 starts.
at 7:00, station 1 shuts off & station 2 starts.
at 8:00, station 2 shuts and station 3 starts, etc.
You are not programming the individual start times for each station.
If you put in more than one start time, the timer remembers and will run all stations then go back and begin again and if there is a third start time, it will begin a third time.
Gary
Sep 02, 2011 | Orbit 57882 9 Station Super Dial...
I just got an Orbit 4 Station Sprinkler Timer with Easy Dial from the landscaper who did my sprinkler system a week ago, he set the timing at 6:30 AM I changed it to 5:45 and SET it and now its running...
You don't program each station. You only program one start time that begins the cycle that consists of the three stations.
Remove all start times but the first one and make that 5:45.
Set the station times to whatever you want, 12 minutes.
At 5:45, station 1 starts.
at 5:57, station 1 shuts off, station 2 starts.
at 6:09, station 2 shuts and station 3 starts.
at 6:21, station 3 shuts.
Your FixYa Texpert,
Gary
Aug 26, 2011 | Garden
Can you solve the problem of loosing all digital channels overnight on the L19H01UB television. Thanks Trevor.
Every time you shut down it may have arcing that zaps the memory of DTV stations. Just turn it on again might regain the list of stations. If not then scan the stations again in setup menu.
Oct 21, 2010 | Hitachi Televison & Video
TV turns off by itself or volume goes out usually within the first 15 minutes. The volume will go off and then I'll try to change stations and tv is black, I have to turn off, wait till the VIZIO light...
your Audio output chip has gone south and shorts out after warm up The unit will shut off to protect itself you need a tech to replace it try Pinicle Service solutions in Haverhill ma
Nov 02, 2009 | Vizio GV46L 46 in. LCD Television
05 Suzuki Forenzo Radio Problem
Display connection faulty, take apart and check connection from the display screen.
Apr 21, 2017 | 2005 Suzuki Forenza
Kodak DX4330 shuts down
Unscrew some of the screws (the ones you can manage to remove), press on the little connector on the bottom, put some batteries in and try it. When I put the batteries in, it worked for me, and so I screwed it back up, and it's continued working pretty much. I think something might have gotten loose on these cameras. I thought mine was through, but it seems to work now!
Nov 03, 2007 | Kodak EasyShare DX4330 Digital Camera
Grundig G6 Aviator Radio Buzz Aldrin Edition Logo
52 people viewed this question
Top Grundig Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Grundig Toy Expert? Answer questions, earn points and help others
