Question about Epson 9880 stylus pro Printer
Epson 9880 prints half a job, then stops
Printer was working fine until this week. I'm using Photoshop and InDesign CS6 and trying to print various files, but the printer will only print 1/2 to 3/4 of the job then stop. I've tried deleting all jobs in the print spooler, but this didn't help. I've also tried printing different files, but have the same problem. I'm running Windows 8.
  • 3 Answers
I aint too sure if its the same but i had an epson printer with the same problem last year it would print half a page spit out and then print the same half a page again and just stuck in a loop even on printing disks it did the same i found out after by speaking to a printer specialist it was the printers eeprom which is the printers memory bank that was failing and nothing can be done with it
Posted on Feb 11, 2014
ohms
  • 1879 Answers
SOURCE: Printer hangs up.
1. check the printer, make a copy
2. check connectivity, open device manager - USB Printing Support(under Universal Serial Bus Controllers) must be there - swap cable/port if it´s not
3. uninstall, reboot then re install printer driver
Posted on Jan 04, 2008
SOURCE: New Epson RX595 won't print
Apparently the latest software doesn't work with Leopard 10.5.2. I uninstalled the Epson software and installed the earlier version [driver version 3.88] that come on the Installer CD with the printer. Printing now works.
Posted on May 19, 2008
yooperbud
  • 8637 Answers
SOURCE: Epson Stylus Pro 9880 Does Not Print
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 24, 2009
don_farr
  • 1018 Answers
SOURCE: i have an Epson CX4800 that just stopped printing.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Posted on Jan 28, 2010
SOURCE: I have an Epson Stylus
Hi, this maybe happening due to RAM or HDD space, often BIG complex color print jobs take up vast amounts of RAM and HDD space, the PC needs enough to "Spool" the print job, so that it can "Feed" it to the printer in "Chunks" of data. If you do not have sufficient HDD space or enough RAM then what you describe can happen.. so this is indeed worth a check.
Posted on Nov 11, 2010
Gray color prints as brown using Photoshop CS6
check your image mode.. click image, then mode, then cmyk color.
Sep 23, 2017 | Epson Stylus Office T1100
My Photoshop sends a print job 100 times to my Xerox 7800 instead of once for 100 prints.
I also have this issue running a xerox docucolor 550 and PS-CS6 the only soloution i have is to save the file as a pdf and send it from firey comand center if you are running a firey server command center is available from xerox website
Sep 11, 2012 | Xerox Phaser 7800GX LED Printer - Color -...
My color photos print darker then they appear on my monitor. I use Huey pro to callibrate, I use photoshop and print to an Epson 3880, using the Epson supplied profiles. I turn off printer management and...
You need to select the correct Printer Profile for the type of paper you are using. If you are using non-Epson paper, you need to download the ICC Profile from the paper mfg. website.
You also need to check if the paper is comparable to an Epson paper that the printer supports. If the paper your using is not comparable to any Epson paper the printer supports then you might want to try using another kind of paper. Epson prefers Epson Paper. You can also try any non-Epson paper as long as it is comparable to any Epson paper the printer supports. Try to go to their website and look at the printer's specifications. It lists all type of paper the printer supports.
Jan 16, 2010 | Epson Stylus Photo R1800 InkJet Printer
Jan 08, 2009 | Epson Stylus Pro 9800 InkJet Printer
Epson R200 print job suddenly slows down
Your printer memory is full and it needs to wait to take on more data files for printing.
Jul 13, 2017 | Epson Stylus Photo R200 InkJet Printer
Can't print from Indesign CS3 to Epson stylus photo 2100
It sounds like a buffer overun problem. Try reducing the resolution of your graphics. Have you contacted Adobe? You have one year free technical support with the software, I believe.
Jun 19, 2008 | Adobe Photoshop 7.0 for PC
Printing from Indesign CS3 to Epson CX11NF problem
hi-
Actually what i can suggest is that for you to try printing from a different application, such as microsoft word or paint. try printng a landscape image. now if its going to print it correctly call adobe since that might be an application issue. thanks for using fixya!!
May 23, 2008 | Epson ACULASER CX11NF All-In-One Printer
Lexmark c530dn wont print
disconnect this printer from your gigabit switch and try running it by itself. this printer should have its own on board memory. you may have uncompatible memories.
Apr 09, 2008 | Lexmark C530dn Laser Printer
Job stopped!
hey wildd, Try unplugging the printer from the electrical source for "several" minutes. Shutdown the computer too. Turn on the printer, then turn on the computer. If that doesn't work go the whole mile. Uninstall all printers and software. download the latest drivers from Epson. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=23952&infoType=Overview This link is to the epson site and your machine. Download the drivers from here. Have you had any paper jams lately? Make sure there aren't any pieces of paper stuck or any other debris. How about the print properties, or open print jobs? what does it show when the job stops. Let me know what happens. Good Luck, Tim
Mar 13, 2007 | Epson Stylus C64 InkJet Printer
Epson 9880 stylus pro Printer Logo
167 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
