Question about Samsung SMH9151ST Stainless Steel 1000 Watts Microwave Oven
I put foilpaper in the microwave. now it keeps sparking
    Champion:
  • 203 Answers
The may be some foil left in it have a good check and clean it out
Posted on Feb 19, 2014
Microwave not heating
Hi Edward
I should mention (although it's pretty obvious) that Microwave Energy is DANGEROUS.
So it's better not to fiddle with the internals.
A quick test can be done to check for electromagnetic energy (in the 2.45Ghz range) inside the oven. Put a glass of water in the Microwave Oven and place 2 strips of tinfoil across the top of the open glass above the water. Put the strips close together but not quite touching then close the door.
Start the microwave & look through the glass window. Listen & Watch for sparks between the tinfoil pieces. If there are sparks then your Microwave Oven is generating or transmitting electromagnetic energy from the magnetron tube unit.
If it's working Don't leave it sparking too long. The tinfoil can get hot enough to burn. The glass of water is to absorb any microwave energy.
There is an interlock switch on the door for safety to protect you from microwaves leaking out of the door cracks. This switch fails to function sometimes. But normally the oven won't even try to power on or spin the turntable (or Fan) if this interlock fails.
If there are no sparks then your Magnetron is shot. Its usually not worth fixing them unless you know of a specialist technician who is qualified and competent with microwave equipment.
Hope This Helps
..... Trevor
Jul 15, 2014 | GE Profile Spacemaker Over-the-Range...
Microwave sparks
If it sparks inside the oven then look inside for any powder paint missing... if so discard. If you has metal shelves or tin foil then don't put metal in when on microwave setting. Some of these metal shelves are for a microwave that is also a convection oven but only in the convection oven setting.
Nov 26, 2013 | Thermador Microwave Ovens
What cause sparks to shoot inside the Daewoo KOR-1B4H Microwave Oven when it is empty?
You should never run a microwave with nothing in it!! There is nowhere for the energy to go. The oven itself has a special coating that keeps the sparks from happening. Anywhere the coating is bad will arc. If it keeps arcing it will burn out the microwave generator.
Oct 02, 2013 | Daewoo KOR-1B4H Microwave Oven
When I turn it on it starts to spark as if I put a metal or alluminium foil inside the microwave oven.
Any carbonization on the turntable will attempt to spark like that.
Clean the cavity completely and the turntable with glass plate. There is a wave guide cover that sparks when it is contaminated. That will require changing if it is the culprit.
Contact your supplier for spares.
Jan 20, 2011 | Emerson 025806092806 Microwave Oven
Sprayed inside to clean now it sparks when i start it
well done you! you just shorted out the megantron it may dry out if you leave the door open but if its sparking you may well have done it in for good, never spray any thing inside a microwave!!! only ever wip it down with a damp cloth or better still if its gruby and its hard to get this dirt off put a bole of water inside and heat it up the steem will do the cleaning for you then,,,all you can do now is dry it out realy well before you try to use it again and keep your fingers crossed it works ok,,,
Jan 24, 2010 | Kenmore Microwave Ovens
The oven sparks and gives a loud hum during use with plastic food containers. This scares my wife and mom terribly. I have an Emerson 900W microwave oven (model:MW8999SB).
It seems as though the container has a small amount of metal embedded in it ... don't assume just because it is plastic you can put it in the microwave.
Tip ... put just the plastic container in empty and try it. If the plastic get hot then it's the wrong type plastic for a microwave
Oct 02, 2009 | Microwave Ovens
GE Spacemaker appears to be sparking inside/top
1.Needs to remove that disk and clean the grease under it.
2. With sand paper clean dark burn spots.
3. Apply touch paint on open metal spots.
4.Put everything back.
Nov 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Frame is sparking and smoking
Re-trade or go buy a new one this unit is not worth repairing. Go buy a new one their cheap nowadays.And for God sakes unplug it, keep fire extinguisher handy and tell the kids not to use it. You could have an electrical short in there.
Dec 09, 2007 | Emerson MW8102SS 1100 Watts Microwave Oven
Sharp selling bad microwaves
paddy paddy paddy i want i want, bet you were spoiled as a child, never continue to use a microwave that sparks, you can only do more damage to the appliance and maybe even worse is this sparking when you use it under normal conditions, place a plastic bowl with cold water in and see if it sparks then, if not then is it something you have done, i assume you know what you can not put in a microwave if sparking occurs anyway, and its only 6 months old, is it under guarantee, then its simple, send it back and ask for free replacement SHOUT AT THE RIGHT PEOPLE DON'T WASTE TIME ON HERE
Oct 04, 2007 | Sharp R-220BW Microwave Oven
Samsung SMH9151ST Stainless Steel 1000 Watts Microwave Oven Logo
26 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
