Question about Argox R-400 Thermal Printer
Ready light flashes - Argox R-400 Thermal Printer
Cant get the BELKIN to work
From the manual:
Resetting the Router
Push and release the “Reset” button. The lights on the
Router will momentarily flash. The Power/Ready light will
begin to blink. When the Power/Ready light becomes solid
again, the reset is complete.
b. Restoring the Factory Defaults
Press and hold the “Reset” button for at least 10 seconds,
then release it. The lights on the Router will momentarily
flash. The Power/Ready light will begin to blink. When the
Power/Ready light becomes solid again, the restore
is complete.
Feb 12, 2009 | Belkin (F5D5231-4) Router
Flash not working
There is no flash-ready light on DSLRs. Recharge the battery fully and try again.
Dec 22, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Sb600 display fine, but no longer flashes
Your flash has a bad flash tube . make sure the batteries are in corectly and youhave a ready red light .
Nov 08, 2008 | Nikon Speedlight SB-600 TTL Flash
Ready lamp on 283
When the flash goes into battery saver mode, which it does automatically, the light will blink.
If you are using the external power source, the light should remain steady.
Jeff
Oct 30, 2008 | Vivitar 283 Flash
Ready light on my SB-800 speedlight
put in a fresh set of batteries. The ready light won't turn on until the flash capacitor is fully charged. And if your battery is weak, it can take very long (minutes!) to fill the capacitor. You still can fire the flash even it is not ready, it will just dump whatever power it stored in the capacitor.
Jun 12, 2008 | Nikon Speedlight SB-800 TTL Flash
SB-600 Ready Light Won't Come On When Mounted on D-40X
Check that all the batteries are functioning properly, and that they have been inserted in the proper direction.
Jerry G
Dec 11, 2007 | Nikon Speedlight SB-600 TTL Flash
Open Questions:
Argox R-400 Thermal Printer Logo
64 people viewed this question
Top Argox Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
sahoo_sanjay
bvmihai
Are you an Argox Office Equipment and Supply Expert? Answer questions, earn points and help others
