Question about Dynamic American Dynamics ADTTE Keyboard, RS232, Touch Tracker, trackball control, desktop
Tracking ball will not move cameras - Dynamic American Dynamics ADTTE Keyboard, RS232, Touch Tracker, trackball control, desktop
When i push scroll button down nothing works only side to side up and down works
This is very common for the blackberry's. Sometimes the trackball gets full of lent and dirt which won't allow the wheels to move. The chrome ring around the ball just pops off and the track ball should come out. Try cleaning it with a small brush. If this doesn't fix the problem, then a new track ball can be purchased on ebay for less than $5
Dec 03, 2009 | RIM BlackBerry Curve 8310 Smartphone
My black berry curve; and its ball is not budging; what is wrong with it?
If the ball is not moving at all more than likely it has debris in it. You can use about 10-20psi of air pressure to blow out the track ball.
If the ball moves and it's not working it's either a bad trackball unit. Or the phones has gotten wet usually.
Jul 15, 2009 | RIM BlackBerry Pearl 8100
Bernina 1530
You may just need to clean it. Many times when people use hand lotion or other things oil etc. it gets on the ball and interferes with the board. Try cleaning the ball with cottonball and alcohol. It really makes a difference.
Hope this helps.
Rick
Mar 17, 2009 | Bernina 1008
The track ball on my blackberry 8310 stopped working.
No, but fortunately the trackball is not hard or expensive to replace. If you are technically savvy you can do this yourself. Just purchase a trackball on the internet. The trackball easily comes off if you put a small flat screw driver under the outer side of the chrome ring and pull if off. Let me know if you needed more help. Good luck
Mar 13, 2009 | RIM BlackBerry Curve 8310 Smartphone
Tracking ball moves but when pushed down nothing happends
you should have the trackball replaced or have the main-board check
Feb 25, 2009 | AT&T Blackberry Curve 8300 Smartphone
The ball won't scroll down
Pop the ring around the track ball out with a small blade or your finger nail. Three double prongs hold it in place (bottom and both sides, none on top). Turn device over and gently tap the back. Track ball will release once ring is removed. At this point you can view the track ball and see exactely what is causing the block. Clean if needed with q-tip or remove lint/debris/etc... Just did this with my 8830. Working perfectly now. - {would not scroll down at all prior to}
Nov 25, 2008 | RIM BlackBerry 8800
Olympus Camedia D 510 Lens cover not tight enough to keep power on.
The solution, by jimr929, to not touch the lens cover at all, works perfectly for me too, as mine is also a 2002 model.
rjbjboll----How did you remove the lens cover?
stillthere
Oct 24, 2008 | Olympus Camedia D-510 Zoom Digital Camera
Pearl roller ball
It might be a case where the track ball has some dirt or debris underneath it. First, turn the device off. Next, press down firmly on the track ball while at the same time rolling it in every direction. Hopefully that will knock loose any debris. Another tip to try is to wet your thumb with a little water and do the same thing.
If those two options don't work, you may try taking out the track ball and blowing out the slot with some compressed air. Below is a link that shows how to remove and clean the track ball:
http://www.blackberryforums.com/general-8100-series-discussion-pearl/113889-how-clean-trackball-your-pearl-8100-a.html
Oct 03, 2008 | RIM BlackBerry Pearl 8100
Track Ball
Your track ball may simply be dirty. Get a q-tip wet with rubbing alcohol and rub your track ball and repeat until the q-tip stays clean. Hope this helps!
Jul 02, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Dynamic American Dynamics ADTTE Keyboard, RS232, Touch Tracker, trackball control, desktop Logo
18 people viewed this question
Top Dynamic Home Security Experts
Lawrence Oravetz
Are you a Dynamic Home Security Expert? Answer questions, earn points and help others
