Question about Garmin DC 40 GPS Dog Tracking Collar
Shut off while in use now won't turn on
It was in use working fine and it just shut off.. I tried another battery from a different dc 40 collar and it' still won't power on or charge
3 Suggested Answers
SOURCE: garmin street poilot i3
try cleaning the contacts with some pure alcohol, the upper contacts check springs contact with batterys
Posted on Aug 28, 2008
  • 31 Answers
SOURCE: shuts off, won't charge battery
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Posted on Mar 30, 2009
Why would my DC 30 come up as a DC 40S?
units run the same firmware.
badged as different models for different features
Jun 04, 2014 | Garmin Dc30 Extra Dog Tracking Collar For...
Dc 30 tracker collar keeps shutting down, I have changed battery and recharged unit and it still only runs for about 1 min.
3 PointsProblem with Cars & Trucks
Dc 30 tracker collar keeps shutting down, I havecars and trucks,my car has no tracker., does yours, ,omg
Oct 12, 2013 | Cars & Trucks
NEC Versa p8210 Laptop Power Shut down fault
The beeping ounds like overheating, assume you cleaned out the laptop cpu fan and heat sink when you had it apart?
The shorting issue that you refer to, indicates that there is an internal fault in the circuit that carries the DC power to the board. I would dismantle the laptop and try to power it on on an insulated bench, to see if you can spot any arcing as the Adaptor is plugged in. Check the board and look for the inline ceramic fuse, use a multimeter set to the OHMS scale and test the integrity of the fuse to see if it is carrying a current (battery out and unplugged from mains obviously). Then look to see if there are any blown or burned capacitors and resistors on the board or any burned circuit traces.
Also try a different adaptor and check the output voltage of the old one
Jun 21, 2012 | Computers & Internet
My garmin dc 40 red light stays on solid?
update your collar..mine was doing the same.As soon as I updated it ,it worked fine
Aug 08, 2011 | Garmin DC 40 GPS Dog Tracking Collar
Hello! i bought 4 collar dc40 for astro 220. one of them have a problem: the light is red and fix: what happend?
UPDATE THE COLLAR,ONE OF MY COLLARS WAS DOING THE SAME. AS SOON AS I UPDATED IT ,IT WORKED FINE
Dec 07, 2010 | Garmin DC 40 GPS Dog Tracking Collar
My Toshiba Satellite AS205-5000, will not turn on nor does the fan come on. When the low battery sign came on, I plugged in the AC adapter to charge it, and it shut down and wasn't charging. After it shut...
You Need To Replace the DC Jack..this involves desoldering the old/faulty dc jack from the motherboard, then cleaning the board, then soldering a new dc jack in place of the old...
But First, Test Your AC Adapter - use a multimeter (available at any home improvement store for under $7)...
Nov 14, 2009 | Toshiba Satellite A60 Notebook
I HAVE A DELL INSPIRATION 1525 AND AND BOUGHT A NEW 9 CELL BATTERY BECAUSE IT WAS NOT HOLDING CHARGE, EVEN WITH THE NEW BATTERY ITS DISCHARGING WHILE PLUG IN AND IN USE WHAT MUST I DO.
There are a few possible problems. First of all, check out whether it works fine with a different adapter. If it works, then replace the adapter. If the same problem persists with a different adapter too, then try this. Shut down the laptop and carefully remove the battery, check whether any dust particles there, clean it and put the battery back and try charging it. It should work fine. You have not mentioned whether your laptop lasts for more than 1 hr inspite of it saying the battery level is 40%, if it lasts then, there is no problem in your laptops battery.
Jul 30, 2009 | Computers & Internet
Shut down prematurely
It turns out that the problem was the batteries. I put some good ones that I had in the camera and it started working just fine. Even though the others were showing that they at least partially working, maybe just not enough juice to really work. Anyway, with just about any problem - try new batteries first and see if there is any change or improvement.
Sep 10, 2008 | Gateway DC-M40 Digital Camera
Garmin DC 40 GPS Dog Tracking Collar Logo
35 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
