Question about Eppendorf 5402 Refrigerated Centrifuge
Error 2 on eppendorf centrifuge 5430R - Eppendorf 5402 Refrigerated Centrifuge
Eppendorf 5415r error 17
try here, not same model but probably close enough
http://oidec.net/eppendorf-centrifuge/eppendorf-centrifuge-5415d-error-17.html
Oct 21, 2017 | Computers & Internet
Error 2 in 5417R,how do i solve it?thanks
Error 2 on this model indicates that the imbalance sensor is tripped. If you run the unit with an empty rotor and it does not error, then it simply means that your load was imbalanced. Make sure to put vials into the unit opposite each other, as below.
If it displays "Error 2" with an empty rotor and you did not notice a vibration, then the imbalance sensor is broken and must be replaced. Do not attempt to run the centrifuge without the imbalance sensor, as serious injury may result.
I repair these machines, but you would have to ship it to me in Ohio, which would probably be very expensive.
Here is a rotor balance chart:
Aug 13, 2015 | Eppendorf Centrifuge 5417r Refrigerated...
Eppendorf Centrifuge 5430R lid does not open after pushing the 'Open' button in front display
Probably too late now but there is usually a small hole in the centrifuge where a thin shafts can be inserted to manually disengage the locking system.
Apr 19, 2014 | Science & Laboratory
5402 error 2
Dear Sir,
In a 5402 Eppendorf Centrifuge, Error 1 states primarily for an EEPROM error. EEPROM is a tiny memory chip that stores individual details of the centrifuge, mainly the microprocessor time base (for correct time set operations), the mains voltage (115 or 230 V, to inform and set the motor current levels), and the imbalance level adjustment for the imbalance sensor. When the centrifuge powers up, these data are readen, and if all OK, the centrifuge is ready to go. If one of them corrupts, especially the 115 or 230 Volt information, we get error 1 and no start allowed.
To check and reprogram this EEPROM we have to acess the service routine. This is done by by jumping together pins 1 and 5 of X8 conector, on the base of the electronic board, located behind the power cable panel in the back of the centrifuge. There are about 20 setting or check parameters, but usually 1 or 2 of the described above need to be reprogrammed. Please e-mail me for details: phdeletr@gmail.com.
Error 2 is Motor Tach (Speed sensor) error, caused usually if the cable pops off the electronic board. But the tach sensor itself, who stays in the bottom of the motor drive, could be broken or defective.
Regards,
Paulo H. F. Pimenta
Dec 13, 2013 | Eppendorf 5402 Refrigerated Centrifuge
Error 1 on the 5402 centrifuge how to repair problem
Dear Sir,
In a 5402 Eppendorf Centrifuge, Error 1 states primarily for an EEPROM error. EEPROM is a tiny memory chip that stores individual details of the centrifuge, mainly the microprocessor time base (for correct time set operations), the mains voltage (115 or 230 V, to inform and set the motor current levels), and the imbalance level adjustment for the imbalance sensor. When the centrifuge powers up, these data are readen, and if all OK, the centrifuge is ready to go. If one of them corrupts, especially the 115 or 230 Volt information, we get Error 1 and no start allowed.
phdeletr@gmail.com.
Regards,
Paulo H. F. Pimenta
Dec 11, 2013 | Eppendorf 5402 Refrigerated Centrifuge
Show error 1
Dear Sir,
Regards,
Paulo H. F. Pimenta
Dec 03, 2013 | Eppendorf 5402 Refrigerated Centrifuge
My centrifuge 5702 rotor mentions error 3
The Eppendorf manual states that Error 3 means that there was an anomaly in the speed sensing system. The corrective action is to leave the power on with the centrifuge not spinning for several minutes and the error should clear itself.
If the error persists, then the speed sensor is probably damaged, and the unit will need to be serviced by a qualified technician.
Apr 16, 2013 | Eppendorf North America Eppendorf 5702...
How can i calibrate the imbalance of eppendorf 5417c
Align the magnet on motor support. Put it a litle closer to the board.
The imbalance sensor sends a signal directly proportional to the intensity of the magnetic field strengh from magnet. Pop off the display board and locate pin 12 of 8AF C515C microcontroller, its an A/D input, reading the imbalance sensor voltage. If the voltage on it goes below 1,5 Volts, it latchs on imbalance or error 2. The correct setting point is with motor stopped, if you shake manually the motor you have errror 2. Otherwise not.
Feb 02, 2013 | Eppendorf 5417c Benchtop Centrifuge - Very...
Need service manual for Eppendorf 5417C Microcentrifuge
Eppendorf AG:
Please see our product page for the Eppendorf Centrifuge 5417 R. It has the manual for the Centrifuge 5417 C online as well: http://goo.gl/VCVVh.
If you have any further questions, please contact our technical support:
http://goo.gl/fmoEV
Kind regards,
Eppendorf Social Media Team
Hamburg, Germany
(socialmedia@eppendorf.de)
Oct 26, 2012 | Eppendorf 5417R Microcentrifuge
Eppendorf 5402 Refrigerated Centrifuge Logo
138 people viewed this question
Top Eppendorf Science & Laboratory Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you an Eppendorf Science and Laboratory Expert? Answer questions, earn points and help others
